LTE connection status
Is there a way to view more details on the status of the LTE / 3G connection?
  • signal strenght, a bargraph would be nice
  • signal to noise ratio
  • is the connection 3G or LTE, details
  • speed (eg. dl 100 Mbit, ul 50 Mbit)
  • details about the cell of the mobile network
  • etc…
a entry in “Status - Realtime Graphs - Wireless” and “Network - Wireless” in the LuCI would be nice
I found a way to display some information on the connections status.
over SSH: issue the command: “uqmi -d /dev/cdc-wdm0 --get-signal-info”
in LuCI go to “System - Custom Commands” in the “Configure” tab add the command and a description.
I connected a USB 3.0 stick, it decreased my already weak signal (maybe it is the usb stick, idk).
So i connected it with a USB 2.0 extension cable to force it to USB 2.0.
USB 3 is known to have broad noise, here is the intel Whitepaper on this:
https://www-ssl.intel.com/content/www/us/en/io/universal-serial-bus/usb3-frequency-interference-paper.html
