Hi @peci1 thanks for the reply!
I got the Double MOX AP & Omnia Bundle from the crowdfund run.
So that would give the following spec:
MOX AP (access points with 2×2 MIMO 2,4/5 GHz dual-band switchable Wi-Fi)
I think this is now called the Mox Pocket Wi-Fi set.
I’ve checked my version and I’m on 3.x, time to update!
Unfortunately, that isn’t really working out for me.
I’ve created an ext4 usb drive with:
- omnia-medkit-latest.tar.gz
- omnia-medkit-latest.tar.gz.md5
- omnia-medkit-latest.tar.gz.sha256
- omnia-medkit-latest.tar.gz.sig
Which the omnia can read and mount in normal operation.
When I put the omnia in flash mode, it only briefly is in the “red” mode, and starts normal operation soon after (without updating).
Do you know what’s going on? Is there any additional info that would help with triage?
