Ahoj,
snažím se zkompilovat Turris OS, ale neustále mám problém s nejrůznějšími balíčky. Předešlé kompilační chyby se mi podařily vyřešit, následující problém však nikoliv. Kompilaci jsem spustil pomocí skriptu compile_omnia_fw.
install -m0755 /home/jakub/build/turris-os/build_dir/target-arm_cortex-a9+vfpv3_musl-1.1.15_eabi/lua-
5.1.5/ipkg-install/usr/bin/lua /home/jakub/build/turris-os/staging_dir/target-arm_cortex-a9+vfpv3_musl-
1.1.15_eabi/root-mvebu/tmp-lua/usr/bin/
SHELL= flock /home/jakub/build/turris-os/tmp/.root-copy.flock -c 'cp -fpR /home/jakub/build/turris-
os/staging_dir/target-arm_cortex-a9+vfpv3_musl-1.1.15_eabi/root-mvebu/tmp-lua/.
/home/v/build/turris-os/staging_dir/target-arm_cortex-a9+vfpv3_musl-1.1.15_eabi/root-mvebu/'
rm -rf /home/jakub/build/turris-os/staging_dir/target-arm_cortex-a9+vfpv3_musl-1.1.15_eabi/root-
mvebu/tmp-lua
touch /home/jakub/build/turris-os/staging_dir/target-arm_cortex-a9+vfpv3_musl-1.1.15_eabi/root-
mvebu/stamp/.lua_installed
if [ -f /home/jakub/build/turris-os/staging_dir/target-arm_cortex-a9+vfpv3_musl-
1.1.15_eabi/pkginfo/lua.default.install.clean ]; then rm -f /home/jakub/build/turris-os/staging_dir/target-
arm_cortex-a9+vfpv3_musl-1.1.15_eabi/pkginfo/lua.default.install /home/jakub/build/turris-
os/staging_dir/target-arm_cortex-a9+vfpv3_musl-1.1.15_eabi/pkginfo/lua.default.install.clean; fi; echo "lua"
make[3]: Leaving directory '/home/jakub/build/turris-os/package/utils/lua'
make[2]: Leaving directory '/home/jakub/build/turris-os'
package/Makefile:184: recipe for target '/home/jakub/build/turris-os/staging_dir/target-arm_cortex-
a9+vfpv3_musl-1.1.15_eabi/stamp/.package_compile' failed
make[1]: *** [/home/jakub/build/turris-os/staging_dir/target-arm_cortex-a9+vfpv3_musl-
1.1.15_eabi/stamp/.package_compile] Error 2
make[1]: Leaving directory '/home/jakub/build/turris-os'
/home/jakub/build/turris-os/include/toplevel.mk:181: recipe for target 'world' failed
make: *** [world] Error 2
Už jsem zkoušel balíček aktualizovat, ale také nepomohlo.
Děkuji předem za rady.
