@vcunat @miska I have been trying to figure this out since Turris 3.10 and I think I know now what is happening.
The problem I was seeing was that
dig aaaa aaaa.v6ns.test-ipv6.com
would return SERVFAIL after the router was rebooted. v6ns.test-ipv6.com is a host that only has a AAAA record, and no A record. If kresd was restarted after boot time, the same dig command would return the correct AAAA record.
Looking at the logs, I saw this output for kresd:
2018-07-04 00:39:40 info kresd[4272]: > net.ipv6 = false
This seem to come from this portion of /etc/init.d/kresd
, which seems to be some code designed to see if there’s working IPv6:
( sleep 15 # Wait for resolver to start working and system to boot up
if ! ip -6 r s | grep -q '^default' &&\
ping -c 1 api.turris.cz > /dev/null 2>&1 && \
! ping -6 -c 1 api.turris.cz > /dev/null 2>&1; then
echo "net.ipv6 = false" | socat - UNIX-CONNECT:$(sleep 5; ls -1 $DEFAULT_RUNDIR/tty/*) > /dev/null 2>&1
fi) &
I think that the sleep 15
here is the culprit, at least for me, 15 seconds is not enough for the router and resolver to come up with IPv6 available. I adjusted this to 30 seconds; the net.ipv6 = false
message disappeared from the logs and I no longer had the issue with dig and AAAA records.
Could you change the default timing here to be longer, or figure out if there’s a more reliable method than sleep?
