Issues with Snapshots?
I am trying to leverage the snapshot feature on my Omnia and I’m running into different problems such as. Certain snapshots can’t be deleted, Snapshots automatically came back after having been successfully deleted. Intermittently roll back works and doesn’t work. It’s really weird. I actually did the 7 led internet firmware restore but that didn’t seem to resolve anything.
Is this some sort of a bug? Is it possible that i may have failing hardware? Or could I be using it wrong? I am accessing the snapshots from the reforis interface if that makes any difference. I am on the latest 101.1.1 TurrisOS code.
Any advice is appreciated.
Thanks
You are presenting a nonspecific version of TOS.
Example:
Turris OS version 5.1.10
Turris OS branch hbs
Kernel version 4.14.222
Do you work via menu Luci or terminal ?
Youre system is an internal memory of the router or mSATA SSD ( flash drive) ?
Hey Jarda
Here are the specs from the about page on my unit in the event that you wanted me to confirm this:
I have done some configuration from the menu, some from Luci, and some from the terminal. As far as the internal memory it is using whatever comes stock on the device. I have not added any aftermarket SSD or hooked up a flash drive.
Thanks
