Is the router include both 802.11n and 11ac wifi cards?
Hello
If the router includes both 802.11n and 11ac wifi cards ? how much is it ?
you can find the price on the indiegogo page… or did you mean something else?
and to answer your other question: it includes a Compex WLE200N2 for the 2.4GHz Band and an AC-capable Compex WLE900VX for 5GHz.
I found the router in indiegogo,there are 3 antennas . Are you sure the router can run in 2x2 MIMO 11n and 3x3 MIMO 11AC simultaneously;? In my mind, 5 antennas should be there.
they’re using signal mixers on 2 antennas
