Hello it seems that recent update (of 5.0?) made my router not working ?!
After re-flash with omnia-medkit-latest.tar.gz - this does not help ?!
Should I wait first ?! No rush !
We haven’t released any stable release, yet. We released just Turris OS 5.0 as RC version to its branch. It was for a long time in HBK and I haven’t seen any issues that it was not working. You can see it in our documentation Early access - Turris Documentation.
See threads:
Anyway, from your post, I don’t know what does not work. Can you please describe it more like Wi-Fi is not working/LAN is not working? Internet is not working? Some package which you installed does not work?
Yes I used 4 LED re-flash …
medkit file was from here :
flash - usb-stick has FAT32 and medkit file is *.tar.gz
Internet eth0 is not working - it seems that there was building-site yesterday at vodkafone/unitymedia … but this has nothing to do with it.
Normal eth0 - line is working without router.
Which version and branch of TOS you used until flash?
I think it updated normally before up to 4.0 - then it seems that somehow after recent update (at weekend or after recent weekend) - today was update ? - turris omnia seems not to re-boot correctly after plugging in.
You updated TOS from 3 to 4?
Yes - before weekend it was in state of 4.x - I dont recall when the update was - I think that was after October 2019 (?).
Should I use (try) different medkit file (for 5.0-testing?) ?
Where is this file ?
But article above is about update from TOS 3 to 4.
I am asking again for source of medkit file.
At moment these LEDs are on:
LED for Power
LED 0 (zero)
LED for web is on (after LED 4 (is off))
I have repeated re-flash with latest medikit from here:
https://repo.turris.cz/hbs/medkit/omnia-medkit-latest.tar.gz
But it does not work ?! Not sure if vodkafone has to do with it ?
Aaaah … too easy … am sorry. I am getting old.
Solution was to configure at ip adress : 192.168.1.1
This thread is solved. I have now version 4.0.5
Thank you. And no offense.
Swell. Good to hear.
Yes. Thank you.
Just as idea. - it would be good to add a tab here in homepage for “blogs” of developers of turris … for to announce, when next update will be on which day (we should be online then).
While last update, I did a failure - I did not notice that there was update running - and switched off the router. This way then update was frozen on the router and I then had to re-flash today. Just as idea.
It’s not enough?
Sorry - I have overseen that. I mean only little info is missing, on which day update starts … to know how to prepare oneself.
Again, it’s not enough?
Have again overseen, that date is printed (it is small and pale).
Sorry for my inconvenience, - then this is of course far more than good enough.
