I was looking to install some MQTT broker onto my Turris Omnia and noticed that moquitto
was already running with config in /tmp/fosquitto.generated.conf
- Is this used internally by Turris? What for?
- Can I (also) use it for my own topics?
- How do I reconfigure it? Apparently there’s a “generated” config, how to tweak and regenerate it? Mainly to make it listen on
br-lan
interface and also to configure bridging some topics to another MQTT broker. - Or am I better off running a separate copy of
mosquitto
? Should I install a separate package or is the “fosquitto” binary ok to use?
Thanks!
