My Turris Omnia is connecting to Internet via pppoe to OVH ISP.
So far so good, IPv6 working like a charm.
I added Failover to LTE following these tutorials:
https://www.turris.cz/doc/en/howto/lte_modem_install
Note: May I suggest that you recommend testing that the SIM card is properly installed with
uqmi -d /dev/cdc-wdm0 --get-pin-status
You should get:
{ "pin1_status": "verified", "pin1_verify_tries": 3, "pin1_unblock_tries": 10, "pin2_status": "not_verified", "pin2_verify_tries": 3, "pin2_unblock_tries": 10 }``` If SIM card is not well connected, you'll get
UIM uninitialized`
Because of Micro/Nano Sim adapter contact may be off and using scotch tape could do the trick.
It also worked like a charm.
My problem now is that I don’t have IPv6 anymore on PPPOE.
Any idea?
