Suddenly my internal flash memory of 8gb is completely filled up. I have 1% left.
Last time I checked it was still 90% free, I haven’t changed anything at all on the router.
How would I be able to check what is clogging up everything?
Rebooting didn’t change anything.
This is the result, what do you make of it?
the /temp folder is probably my externally connected drive being:
/tmp/run/mountd/sda2
3.20 TB / 3.58 TB
6% (201.45 GB)
I think that you have filled flash with combination of /mnt and snapshots. Probably clean /mnt and remove some old snapshots. I hope that will help.
Also be aware that if you remove some big files and those files are in snapshot, they don’t really disappear from flash/drive, you also have to remove snapshot they are in to free space.
Yes. Schnapps creates snapshots automatically in two cases. On time base and before update. What snapshot you have to remove depends on when /mnt directory become so big.
In default /mnt is empty, no program in default writes to it as far as I know. See what’s inside, but most probably there will be some of you files, or files from programs you configured. So look what is in there and clean means remove those files.
