Just a note if somebody is adding mSata disk to omnia and finds them self wondering why one of the WiFi adapter is not working suddenly I know this might be common knowledge but hell, it was not mentioned in the video on CZ youtubeā¦
Issue:
After adding mSata disk as per tutorial video:
- Basic web setting shows 2 wifi interfaces but only the upper one is working ( 5Ghz )
- 2.4 Ghz ( the one that was moved ) is shown but wifi is goneā¦
Solution:
jump into ssh ( putty ) log into your omnia IP ( 192.168.1.1 ? ) with root as user and password.
Backup file: cp /etc/config/wireless /etc/config/wireless.old
Edit file: vim /etc/config/wireless
and remove block related to radio1, underneath is also radio2 just rename it to radio1 where it says radio2 ( two places )
Save, reboot and enjoy working configuration via web interface again
