Import (some) settings from OpenWRT?
I expect to receive my Turris Omnia tomorrow. Since I’m currently running OpenWRT (CHAOS CALMER (15.05.1, r48532)) on my router, I was wondering whether it would be possible to import at least some settings from there. Any thoughts?
I believe most of them. At least for me it was quite easy just copy paste .conf files.
Except dnsmasq, this is most tricky part for OpenWRTers, as this tool isnt used by default, and its replaced by knot/kresd on Omnia.
To be more precise, dnsmasq is used by default but not for DNS.
Thanks, both of you! I received the router yesterday and could indeed import many settings, although I ended up comparing some of the config files to the new defaults and importings individual settings just to be on the safe side.
