Hplip not built with scanner support
I have the following printer scanner combo:
vendor=0x03f0 [HP], product=0x6c11 [Photosmart C4400 series
Printing works fine, but I can not scan. On my laptop everything works fine.
On the turris it turns out that /etc/hp/hplip.conf was built without scanner support
Omnia:
[dirs]
home=/usr/share/hplip
run=/var/run
ppd=/usr/share/ppd/HP
ppdbase=/usr/share/ppd
doc=/usr/share/doc/hplip-3.16.11
html=/usr/share/doc/hplip-3.16.11
icon=/usr/share/applications
cupsbackend=/usr/lib/cups/backend
cupsfilter=/usr/lib/cups/filter
drv=/usr/share/cups/drv/hp
bin=/usr/bin
apparmor=/etc/apparmor.d
# Following values are determined at configure time and cannot be changed.
[configure]
network-build=no
libusb01-build=yes
pp-build=no
gui-build=no
scanner-build=no <<<<<<<<<<<<<<<<
Host:
[dirs]
run=/var/run
bin=/usr/bin
[configure]
network-build=yes
libusb01-build=no
pp-build=yes
gui-build=yes
scanner-build=yes <<<<<<<<<<<<<<<
Can you please fix this?
