How to switch from SFP WAN to EHERNET WAN?
I have Turris Omnia 3.11
I followed the documentation on turris and tried following command in /boot
ln -sf armada-385-turris-omnia-phy.dtb dtb
But it seems not working.
I think on older firmware 3.x it is automatically detected. Linking is required only on 4.x+. But I might be mistaken
I resett Turris Omnia 3.11but it did not work. Then I found the solution. I had to remove the SFP plug. After that it worked automatically.
