Is somewhere a little tutorial, how to set up WLAN of turris ?!
What LED lights should be on, when WLAN is enabled ?
Thank you for answer.
If you mean WLAN0/WLAN1 that can be done via Foris or Luci and you can use PCI1/PCI2/PCI3 LEDs for indication about link/up/down (via luci/led-configuration + luci/rainbow).
If you mean VLAN : https://doc.turris.cz/doc/en/howto/vlan_settings_omnia
