Dec 18 18:19:02 turris snowflake-proxy[18473]: 2022/12/18 18:19:02 In the last 1h0m0s, there were 17 connections. Traffic Relayed β 177 MB, β 16 MB.
Dec 18 19:19:02 turris snowflake-proxy[18473]: 2022/12/18 19:19:02 In the last 1h0m0s, there were 17 connections. Traffic Relayed β 49 MB, β 4 MB.
I hope you added -capacity 10 (or another number). You should see at least something when you restart or start up snowflake-proxy, something like this:
Okay, then everything is correct. I just entered exactly this value (-capacity 10) and it is as you described.
After the jump to version 2.4.1 with TOS 6.1.0 it also works with the firewall, probably that was the reason.
Thank you, these settings and starting snowflake proxy with the following settings
snowflake-proxy -verbose -ephemeral-ports-range 32768:60999 made my connection unrestricted and now I donβt get the following error anymore βTimed out waiting for client to open data channel.β I used to have it,
I hope opening these ports donβt make a security problem.
Go to Backup / Flash Firmware > Configuration and add on a new line /etc/init.d/snowflake-proxy. This will save that file when you export a backup so you can restore it after a system upgrade.
Do not choose the value for capacity that high, as the man page of snowflake-proxy says the default value for -capacity is 10. So choosing a higher value than 10 increases the number of connections. SNOWFLAKE-PROXY(1)
I think the high load average might be caused by a memory problem which is already discussed on GitHub and there are already possible fixes and merge requests for further versions
