Thanks for replying. It says
root@LXC_NAME:~# ping www.google.de
bash: ping: command not found
Would have to install pingā¦ without an internet connectionā¦
You did previously install php and other packages correct? If so that means you did have a normal internet connection. Which means that you have made some configuration with the ethtool for example that disabled the internetconnection.
Try the following and post the output here.
ifconfig
Here you go:
eth0 Link encap:Ethernet HWaddr ca:03:4b:f4:04:eb
inet6 addr: fe80::c803:4bff:fef4:4eb/64 Scope:Link
inet6 addr: fdda:b184:b6ff:0:c803:4bff:fef4:4eb/64 Scope:Global
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:566 errors:0 dropped:0 overruns:0 frame:0
TX packets:60 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:41604 (40.6 KiB) TX bytes:5120 (5.0 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
I have a regular connection to the internet. Yes.
You have no connection. Eth0 should have hd a ipaddress given to.
eth0 Link encap:Ethernet HWaddr be:64:4a:c6:7b:62
inet addr:192.168.1.236 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::bc64:4aff:fec6:7b62/64 Scope:Link
inet6 addr: fd3a:601c:29d7:0:bc64:4aff:fec6:7b62/64 Scope:Global
RX packets:51 errors:0 dropped:0 overruns:0 frame:0
TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:5095 (5.0 KB) TX bytes:1288 (1.2 KB)
As you can see with mineā¦(using Ubuntu instead of debian jessie)ā¦i have the address 192.168.1.236
The good thing is eth0 is not disabled. Give me a second gonna take a look at some things.
EDIT: Post your āconfigā.
cat /srv/lxc/<LXC-NAME>/config
I had just created my Ubuntu LXC and this is how it should look like as the BASICS.
# Template used to create this container: /usr/share/lxc/templates/lxc-download
# Parameters passed to the template: --server api.turris.cz/lxc --no-validate --dist Ubuntu --release Xenial --arch armv7l
# For additional config options, please look at lxc.container.conf(5)
# Distribution configuration
lxc.arch = armv7l
# Container specific configuration
lxc.tty = 4
lxc.pts = 1024
lxc.rootfs = /srv/lxc/K-Router-LXC/rootfs
lxc.utsname = K-Router-LXC
# Network configuration
lxc.network.type = veth
lxc.network.link = br-lan
lxc.network.flags = up
lxc.network.name = eth0
Try also by any chanceā¦
ethtool -K br-lan tx on
@eugenio, has saidā¦
Command for bug dhcliend debian (to be run on turris shell):
ethtool -K br-lan tx off
So that would probably means that dhclient is turned off or not working. To this solution if there indeed is a bug that is messing things upā¦try a static ip-address instead of receiving one from the DHCP-Server.
root@turris:~# cat /srv/lxc/Debian_Jessie/config
# Parameters passed to the template: --server api.turris.cz/lxc --no-validate --dist Debian --release Jessie --arch armv7l
lxc.arch = armv7l
lxc.tty = 4
lxc.pts = 1024
lxc.rootfs = /srv/lxc/Debian_Jessie/rootfs
lxc.utsname = Debian_Jessie
The Debian lxc is not online, neither with tx on or off.
I have made a Debian_Jessie Containerā¦i am laughing my ass offā¦
no vi availableā¦or vim or nano XDā¦
I have managed to configure the ip-address in the /srv/lxc/Debian_Jessie/config on the Omnia it self
But i am struggling to change the dns XD because i have no editor to change things.
lxc.arch = armv7l
lxc.tty = 4
lxc.pts = 1024
lxc.network.ipv4 = 192.168.1.150/24
lxc.network.ipv4.gateway = 192.168.1.1
give me a sec.
Edit: I am not sure what is going on here, but Debian_Jessie is useless. It is like somebody telling you to configure his computerā¦but you cannot use mouse OR keyboardā¦=_=!. I have never experienced that even āviā-editor is not even available to change config files etc.
edit2: I am an idiot sometimes =_=!. ā¦i forgot things that i did earlierā¦
Okeā¦everything is solved ā¦for now :).
in your /srv/lxc/Debian_Jessie folder you have a ārootfsā folder. There edit etc/resolv.conf
Change it to
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 127.0.0.1
nameserver 8.8.8.8
nameserver 8.8.4.4
Restart your Debian_Jessie container and the update should work now. Keep in mind that you also have to have the /srv/lxc/Debian_Jessie/conf configured with a static ip-address like i have shown above.
Install the following applications
apt update
apt install vim nano
There seems to be local IPv6 connection (fdda:b184:b6ff:0:c803:4bff:fef4:4eb/64) so the container can talk to Omnia and other āIPv6ā devices in local network unless firewall blocks it.
There are no IPv4 address or public IPv6 address so Internet connections wonāt work.
@j0n4s82 did you do
dhclient -4 -r eth0
in the container, after
on the turris shell?
I completely missed that one. Although i must admit that i havenāt played that much often with ipv6.
Is there a possibility to have IPv6 connection on the container and then connect it to the ipv4 gateway of the Omnia and thus have a internet connection? Or having the IPv6 connection enabled on the Omnia as well, then this will automatically configure and give a internet connection to it, although the WAN connection is a IPv4?
This did the trick. Thank you. I am now able to run
apt-get update
and install further packages!! Thank you @Big_boss!!
root@LXC_NAME:~# apt-get remove isc-dhcp-client && apt-get install dhcpd5
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package 'isc-dhcp-client' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
E: Unable to locate package dhcpd5
@eugenio This is what happens when I try to apply your suggestion. Please explain.
It could be that it meant to be the
dhcpcd
instead of the dhcpd5
Here some info about itā¦
https://wiki.archlinux.org/index.php/dhcpcd
btw, you donāt have to type āapt-getā every time. Just āaptā does the job also.
@Big_boss Thank you senpai
Ok. Thank you. It is still unclear to me what the permanent solution is for the Debian connection problem. Is your suggestion permanent? I am asking especially because it says in the rootfs file DO NOT EDIT - IT WILL BE OVERWRITTEN
EDIT This suggestion to install dhcpd5 worked for me now. I used the commands from within my Debian container and got this output:
root@LXC_NAME:~# dpkg -i dhcpcd5_6.0.5-2_armhf.deb
Selecting previously unselected package dhcpcd5.
(Reading database ... 15595 files and directories currently installed.)
Preparing to unpack dhcpcd5_6.0.5-2_armhf.deb ...
Unpacking dhcpcd5 (6.0.5-2) ...
Setting up dhcpcd5 (6.0.5-2) ...
Processing triggers for man-db (2.7.0.2-5) ...
Processing triggers for systemd (215-17+deb8u5) ...
Youāre welcome j0n4s82-kun
Well the ātemporaryā solution was to just get things working for now.
You could now directly edit /etc/network/interfaces and configure a static ip-address to it.
so in /srv/lxc/Debian_Jessi/rootfs/etc/network/interfaces
Things for the eth0 should look like thisā¦
iface eth0 inet static
address 192.168.1.150
netmask 255.255.255.0
network 192.168.1.0
gateway 192.168.1.1
dns-nameservers 8.8.8.8 8.8.4.4
After configuring it do a
ifconfig eth0 down
ifconfig eth0 up
Also remove the previous settings you have configured. Although i am not sure if this solution would work, because when i tried then 2 weeks ago, it didnāt get the ip-address. You could try it though. You now know how to change things to make it work.
BTW, the ipaddress (192.168.1.150) doesnāt have to be thatā¦you can choose another oneā¦so (192.168.1.140 or 130 or 133 as long as it is not already been used by another host (laptop/phone/wifi-adapterā¦etc)
EDIT 2: He forgot to put a ācā between it. dpkg -i installs local packages like opkg install *.ipk in Omnia it self.
That should do the ājobā i guess. You could try if things are working correctly, by removing all previous changes to give a static ipaddress and dns. You then should get a ip-address directly from the DHCP-server-software (dnsmasq running on Turris Omnia it self).
DO PLEASE LET ME KNOW IF IT WORKED!!
So like this
dpkg -i -c dhcpcd5_6.0.5-2_armhf.deb
or the -c instead of the -i?
what it should be was
apt install dhcpcd5
he was missing the c between āpā and ādā before the ā5ā.
dpkg -i (package-name).deb is correct.
Edit: you downloaded this *.deb package? using Wget i guess. Why if i may ask?
@eugenio, when helping @j0n4s82 i stumbled upon thisā¦
lxc.arch = armv7l
lxc.tty = 4
lxc.pts = 1024
I have edited this file many times before, but i did not payed attention on certain parts of this script. Our āproblemā has been solved about the architecture.
lxc.arch = armv7l
So as long as we have *.deb packages that are meant for āarmv7lā then they should work i guess.
Because of this post. I didnāt think apt would work because the command with the typo didnāt install itā¦ It installed it all the same. EDIT And no, I used apt download
. It doesnāt make any sense I believe!? But it did the job. The typo confused me.
Thank you for your input @Big_boss and
Yes. Later today. AFK for now.
