Hi
I tried to get SFP module work in Turris (Turris OS 3.11.23).
I got a suitable SFP module from my ISP provider.
I installed SFP module and fiber cable to Turris but I couldn’t get it working.
The network has been tested with another hardware and it worked.
Can anybody help me! How can I get SFP module working? Here are some pieces from the log
root@turris:~# sfpswitch.py -n -d
sfp det change detected: 0
SFP inserted, setting sfpdis=0
Going to probe EEPROM after init in 1 s.
SFP EEPROM: ['\x03', '\x04', '\x07', '\x00', '\x00', '\x00', '@', '\x00', '\x00', '\x00', '\x00', '\x01', '\r', '\x00', '\n', 'd', '\x00', '\x00', '\x00', '\x00', 'C', 'u', 's', 't', 'o', 'm', 'i', 't', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', '\x00', '\x00', '\x00', '\x00', 'U', 'B', '1', '3', '1', '0', '1', '4', '9', '0', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', '\x05', '\x1e', ' ', '\xcf', ' ', '\n', '\x00', '\x00', 'C', '2', '1', '0', '2', '2', '2', '9', '9', '3', '3', ' ', ' ', ' ', ' ', ' ', '2', '1', '0', '3', '2', '0', ' ', ' ', 'h', '\x90', '\x01', 'o', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', '\x00', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\n', 'e', 'q', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff', '\xff']
Mode selected: generic 1000BASE-X
Switching NIC mode to phy-sfp.
Current mode is already phy-sfp. Noop.
Mode not changed. Iface restart not needed.
root@turris:~# i2cdump -y 5 0x50
No size specified (using byte-data access)
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 03 04 07 00 00 00 40 00 00 00 00 01 0d 00 0a 64 ???...@....??.?d
10: 00 00 00 00 43 75 73 74 6f 6d 69 74 20 20 20 20 ....Customit
20: 20 20 20 20 00 00 00 00 55 42 31 33 31 30 31 34 ....UB131014
30: 39 30 20 20 20 20 20 20 20 20 20 20 05 1e 20 cf 90 ?? ?
40: 20 0a 00 00 43 32 31 30 32 32 32 39 39 33 33 20 ?..C2102229933
50: 20 20 20 20 32 31 30 33 32 30 20 20 68 90 01 6f 210320 h??o
60: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
70: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 00 .
80: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
90: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
a0: ff ff ff ff ff ff 0a 65 71 ff ff ff ff ff ff ff ......?eq.......
b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
c0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
d0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
e0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
f0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
