How to find out which WiFi card is which when they are the same?
Hi all!
Maybe stupid question, but how do I find out which wifi card is in which slot via LuCI, command line or reForis?
My goal is to connect them to the right antenna connector on the diplexer (2,4 or 5GHz) without to doing it step by step (*), as I did it when I was upgrading my own Omnia with Wifi 6 cards. After this setting you can find it out in wireless setting file in /etc/config (e.g.in case of reinstalling from medkit).
(*) steb by step:
Connect wifi card 1 -> boot -> setting up wifi network 1 -> shutdown -> connect wifi card 2 -> -> boot -> setting up wifi network 2
Is there an easier way how to find it out? I know there is lspci command, but I am not sure now, if it shows pci slot number. It should be fine if pci slot number will be shown in reForis or LuCI at least.
Thanks for any advice.
The cards should have their Mac address printed on them. I’d go tuisnway.
Mmm, maybe this should help.
