How long will one be able to order turris omnia?
For how long will i be able to oder additional omnia turris routers? Will there be a deadline or do just sell one batch?
https://en.blog.nic.cz/2016/09/30/and-theyre-gone/
despite the title - it sounds very promising and might answer your questions :slight_smile:
I missed the NAS option on Indiegogo. Does anyone know if at some point the NAS box will be available again ?
See the blog post that @nerdpunk wrote about. You will find out that they are considering it.
:blush: I skipped the paragraph about the first distributor, I shouldn’t have… Thanks for the reply anyways @white
