Honeypot question
Ok, nOOb here. in the post 3.9 i had to make a fw rule to redirect the 22 to a spec local port. Now this haas thing is running, what should i change? according to the HAAS webiste, i just need to activate the honeypot in foris. So, do i need to remove that rule? I ask this since i can’t find find any data on haas.
best, Dikke
oh. great. So, should i keep the fw rule? Funny, since if you make a transition from one platform the the other, you would think that part would work, right?
So, better to switch this honey pot off, until further notice?
best, Dikke
