Help allowing guest network access to service on container
I run the Prosody xmpp server in an lxc container in Omnia. My old Openwrt router had a guest network that I was able to get clients on it to reach Prosody on the lan.
I am using the Turris guest network now and my old openwrt firewall config won’t allow guests to access the server. Network is unreachable.
Can someone please give me an idea on best way for guests to access a service on lan. I don’t mind if they have to go out and back in through the wan. I am just out of ideas. I was able to port forward but that also sucked up google talk causing it to fail.
regards
Found solution here.
https://forum.test.turris.cz/t/how-to-access-lan-ressources-from-guest-network/4801/20
Something I thought I tried but works now. I also told kres.d to use /etc/hosts with an entry for the server.
