Hi All,
i am a bit confused and dont know, what the issue is. From one day to another my guest wifi is not working.
My turris has the IP 192.168.2.1
I have wired a FritzRepeater on LAN4 with static IP 192.168.2.2 (no DHCP - workes as Lan Bridge)
On the FritzRep I have created a Guestwifi
When my Phone try to connect it takes a bit time and gets an IP 169.254.142.1 (255.255.0.0)
I dont understand where this come frome.
I thought it could be the fritz. So activate the turris guest (Guest DHCP is 192.168.100.100-150)
Same result, iPhone gets an 169.x.x.x. IP
can pleeeeease someone help… it makes me crazy.
txh
