Yes, I’ve started syncthing. I’m currently just waiting for my newly ordered SSD to arrive (I’ll send the old one with the broken router to support)
I checked the traffic (thanks for the command) . It was listening to me on the port:
tcp 0 0 0 0.0.0.0:5232 0.0.0.0:* LISTEN 14608/python3
Even though radicale was disabled. After rebooting the router, it fixed it. If I run initd it starts listening on localhost, after shutting down the status disappears. However, I am currently getting error 501. If I stop initd and run radicale2 in ssh, I get no response (of course I get the port busy message again after running initd). At 192.168.1.1:5232 I am currently getting no response. Have you edited the directory under /srv in any specific way yet? Data is not being written there yet, so I still wondered about this problem, since the log spoke clearly:
turris radicale2[----]: Data directory '/srv/radicale2/data' does not exist. Startup failed !!!
I created the directory.
turris radicale2[16707]: [b6ffc560] ERROR: An exception occurred during server startup: [Errno 13] Permission denied: '/srv/radicale2'
turris haas-proxy-start[11212]: 2022-12-07T10:39:41 CRITICAL twisted 'channel open failed, direct-tcpip is not allowed'
turris radicale2[16742]: [b6f37560] ERROR: An exception occurred during server startup: [Errno 13] Permission denied: '/srv/radicale2'
So I set the permissions:
root@turris:~# chmod -R 0700 /srv/radicale2
root@turris:~# chown -R radicale2 /srv/radicale2
In the log it says:
turris radicale2[5249]: [b6f08560] INFO: Starting Radicale
turris radicale2[5249]: [b6f08560] INFO: Authentication type is 'htpasswd'
turris radicale2[5249]: [b6f08560] INFO: Storage type is 'multifilesystem'
turris radicale2[5249]: [b6f08560] INFO: Rights type is 'owner_only'
turris radicale2[5249]: [b6f08560] INFO: Web type is 'internal'
turris radicale2[5249]: [b6f08560] INFO: Listening to 'localhost' on port 5232
turris radicale2[5249]: [b6f08560] INFO: Radicale server ready
But no response, still getting 501, the web interface won’t open on GW.
