Tak problém se znova objevil, zkoušel jsem stáhnout (aktualizovat) na dvou zařízeních (Tablet_Jarda a Sony_Xperia_Z3) offline mapy android aplikace Mapy.cz. Data se nestahují.n
Příkaz: /etc/resolver/resolver-debug.sh start
končí chybami
Debug stated
2018/05/25 18:29:04 socat[13668] E connect(5, AF=1 "/tmp/kresd/tty/12586", 22): No such file or directory
2018/05/25 18:29:04 socat[13676] E connect(5, AF=1 "/tmp/kresd/tty/", 17): Connection refused
2018/05/25 18:29:04 socat[13771] E connect(5, AF=1 "/tmp/kresd/tty/", 17): Connection refused
2018/05/25 18:29:04 socat[13780] E connect(5, AF=1 "/tmp/kresd/tty/", 17): Connection refused
Příkaz: /etc/resolver/resolver-debug.sh stop končí chybou
2018/05/25 18:31:22 socat[14745] E connect(5, AF=1 "/tmp/kresd/tty/14742", 22): No such file or directory
Log je pro velikost pokrácen a jde na podporu emailem
# /etc/resolver/resolver-debug.sh print-logs
Print logs
====Log====
Fri May 25 18:25:07 CEST 2018
2018-05-24 10:12:02 notice syslog-ng[16404]: syslog-ng starting up; version='3.10.1'
2018-05-24 10:13:01 info /usr/sbin/cron[16816]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:14:01 info /usr/sbin/cron[17229]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:14:01 info /usr/sbin/cron[17230]: (root) CMD (nethist_stats.lua)
2018-05-24 10:15:01 info /usr/sbin/cron[17530]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:15:01 info /usr/sbin/cron[17531]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 10:15:01 info /usr/sbin/cron[17527]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 10:15:01 info /usr/sbin/cron[17533]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 10:15:01 info /usr/sbin/cron[17532]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 10:15:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 10:15:49 info nikola[]: (v42) Establishing connection took 0.601200 seconds
2018-05-24 10:15:49 info nikola[]: (v42) Logrotate took 0.004634 seconds
2018-05-24 10:15:49 info nikola[]: (v42) Syslog parsing took 0.064418 seconds
2018-05-24 10:15:50 info nikola[]: (v42) Session init took 0.817916 seconds
2018-05-24 10:15:50 info nikola[]: (v42) Records parsed: 56
2018-05-24 10:15:50 info nikola[]: (v42) Records after filtering: 43
2018-05-24 10:15:50 info nikola[]: (v42) Records filtering took 0.010357 seconds
2018-05-24 10:15:50 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 10:15:50 info nikola[]: (v42) Sending records took 0.080567 seconds
2018-05-24 10:16:01 info /usr/sbin/cron[17889]: (root) CMD (nethist_stats.lua)
2018-05-24 10:16:01 info /usr/sbin/cron[17888]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:17:01 info /usr/sbin/cron[18092]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:18:01 info /usr/sbin/cron[18392]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 10:18:01 info /usr/sbin/cron[18393]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:18:01 info /usr/sbin/cron[18395]: (root) CMD (nethist_stats.lua)
2018-05-24 10:19:01 info /usr/sbin/cron[18685]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:20:01 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 10:20:01 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 10:20:01 info /usr/sbin/cron[18934]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:20:01 info /usr/sbin/cron[18938]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 10:20:01 info /usr/sbin/cron[18936]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 10:20:01 info /usr/sbin/cron[18937]: (root) CMD (nethist_stats.lua)
2018-05-24 10:21:01 info /usr/sbin/cron[19389]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:21:01 info /usr/sbin/cron[19388]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Global permanent pool: 3092/4096 (18)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Global batch pool: 0/4096 (0)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Global temporary pool: 156/4096 (3)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Buffer pool for uplink: 4/4096 (1)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Config pool: 4094/8192 (137)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Badconf: 48/4096 (1)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Bandwidth: 2744/4096 (6)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Count: 264/4096 (1)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Fake: 189120/217088 (161)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Fake log: 44/4096 (1)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Flow: 128/4096 (5)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Flow pool: 8598/12288 (178)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Flow conf pool: 839536/880640 (44873)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Fwup: 168/4096 (7)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 1: 0/4096 (0)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 2: 119742/126976 (6417)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Refused: 104/4096 (3)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Refuse pool 1: 0/4096 (0)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Refuse pool 2: 18718/20480 (799)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Sniff: 44/4096 (3)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Sniffer pool: 0/4096 (0)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats: Spoof: 224/4096 (1)
2018-05-24 10:21:21 info ucollect[4497]: Mempool stats done
2018-05-24 10:21:26 info ucollect[4497]: Sending 53 flows
2018-05-24 10:21:26 info ucollect[4497]: Sending 35 IPv4 refused connections and 0 IPv6 ones
2018-05-24 10:22:01 info /usr/sbin/cron[19818]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:22:01 info /usr/sbin/cron[19819]: (root) CMD (nethist_stats.lua)
2018-05-24 10:23:01 info /usr/sbin/cron[20121]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:24:01 info /usr/sbin/cron[20313]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 10:24:01 info /usr/sbin/cron[20314]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:24:01 info /usr/sbin/cron[20316]: (root) CMD (nethist_stats.lua)
2018-05-24 10:24:43 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 10:24:43 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 10:25:01 info /usr/sbin/cron[20559]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 10:25:01 info /usr/sbin/cron[20558]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 10:25:01 info /usr/sbin/cron[20557]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:25:59 info ucollect[4497]: Updating filter addresses from version 50904970 to version 50905010 (epoch 4)
2018-05-24 10:26:01 info /usr/sbin/cron[20858]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:26:01 info /usr/sbin/cron[20859]: (root) CMD (nethist_stats.lua)
2018-05-24 10:26:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50904970 to version 50905010 (epoch 4)
2018-05-24 10:26:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 10:27:01 info /usr/sbin/cron[21190]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:27:01 info /usr/sbin/cron[21189]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 10:28:01 info /usr/sbin/cron[21506]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:28:01 info /usr/sbin/cron[21507]: (root) CMD (nethist_stats.lua)
2018-05-24 10:29:01 info /usr/sbin/cron[21794]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:30:01 info /usr/sbin/cron[22011]: (root) CMD (/usr/bin/get-api-crl)
2018-05-24 10:30:01 info /usr/sbin/cron[22015]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 10:30:01 info /usr/sbin/cron[22018]: (root) CMD (nethist_stats.lua)
2018-05-24 10:30:01 info /usr/sbin/cron[22007]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 10:30:01 info /usr/sbin/cron[22017]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 10:30:01 info /usr/sbin/cron[22014]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 10:30:01 info /usr/sbin/cron[22016]: (root) CMD (/usr/share/haas/register.sh)
2018-05-24 10:30:01 info /usr/sbin/cron[22019]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:30:03 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 10:30:51 info nikola[]: (v42) Establishing connection took 0.609020 seconds
2018-05-24 10:30:51 info nikola[]: (v42) Logrotate took 0.004689 seconds
2018-05-24 10:30:51 info nikola[]: (v42) Syslog parsing took 0.054019 seconds
2018-05-24 10:30:52 info nikola[]: (v42) Session init took 0.759754 seconds
2018-05-24 10:30:52 info nikola[]: (v42) Records parsed: 50
2018-05-24 10:30:52 info nikola[]: (v42) Records after filtering: 37
2018-05-24 10:30:52 info nikola[]: (v42) Records filtering took 0.009720 seconds
2018-05-24 10:30:52 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 10:30:52 info nikola[]: (v42) Sending records took 0.094274 seconds
2018-05-24 10:31:01 info /usr/sbin/cron[22406]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:31:39 info dnsmasq-dhcp[5601]: DHCPINFORM(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 10:31:39 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 10:32:01 info /usr/sbin/cron[22760]: (root) CMD (nethist_stats.lua)
2018-05-24 10:32:01 info /usr/sbin/cron[22759]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:33:01 info /usr/sbin/cron[23031]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:33:01 info /usr/sbin/cron[23030]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 10:34:01 info /usr/sbin/cron[23397]: (root) CMD (nethist_stats.lua)
2018-05-24 10:34:01 info /usr/sbin/cron[23396]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:35:01 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 10:35:01 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 10:35:01 info /usr/sbin/cron[23715]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:35:01 info /usr/sbin/cron[23716]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 10:35:01 info /usr/sbin/cron[23719]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 10:36:01 info /usr/sbin/cron[24226]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 10:36:01 info /usr/sbin/cron[24225]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:36:01 info /usr/sbin/cron[24227]: (root) CMD (nethist_stats.lua)
2018-05-24 10:37:01 info /usr/sbin/cron[24603]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:38:01 info /usr/sbin/cron[24915]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:38:01 info /usr/sbin/cron[24917]: (root) CMD (nethist_stats.lua)
2018-05-24 10:38:02 info dnsmasq-dhcp[5601]: DHCPINFORM(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 10:38:02 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 10:38:02 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 10:39:01 info /usr/sbin/cron[25252]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:39:01 info /usr/sbin/cron[25251]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 10:40:01 info /usr/sbin/cron[25561]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:40:01 info /usr/sbin/cron[25563]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 10:40:01 info /usr/sbin/cron[25565]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 10:40:01 info /usr/sbin/cron[25567]: (root) CMD (nethist_stats.lua)
2018-05-24 10:41:01 info /usr/sbin/cron[25978]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:42:01 info /usr/sbin/cron[26329]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 10:42:01 info /usr/sbin/cron[26330]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:42:01 info /usr/sbin/cron[26333]: (root) CMD (nethist_stats.lua)
2018-05-24 10:43:01 info /usr/sbin/cron[26732]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:44:01 info /usr/sbin/cron[27174]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:44:01 info /usr/sbin/cron[27175]: (root) CMD (nethist_stats.lua)
2018-05-24 10:45:01 info /usr/sbin/cron[27544]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:45:01 info /usr/sbin/cron[27541]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 10:45:01 info /usr/sbin/cron[27546]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 10:45:01 info /usr/sbin/cron[27547]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 10:45:01 info /usr/sbin/cron[27548]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 10:45:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 10:45:56 info nikola[]: (v42) Establishing connection took 0.607445 seconds
2018-05-24 10:45:56 info nikola[]: (v42) Logrotate took 0.004659 seconds
2018-05-24 10:45:57 info nikola[]: (v42) Syslog parsing took 0.055972 seconds
2018-05-24 10:45:57 info nikola[]: (v42) Session init took 0.763872 seconds
2018-05-24 10:45:57 info nikola[]: (v42) Records parsed: 50
2018-05-24 10:45:57 info nikola[]: (v42) Records after filtering: 36
2018-05-24 10:45:57 info nikola[]: (v42) Records filtering took 0.009835 seconds
2018-05-24 10:45:57 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 10:45:57 info nikola[]: (v42) Sending records took 0.089651 seconds
2018-05-24 10:45:59 info ucollect[4497]: Updating filter addresses from version 50905010 to version 50905050 (epoch 4)
2018-05-24 10:46:01 info /usr/sbin/cron[27868]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:46:01 info /usr/sbin/cron[27869]: (root) CMD (nethist_stats.lua)
2018-05-24 10:46:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905010 to version 50905050 (epoch 4)
2018-05-24 10:46:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 10:47:01 info /usr/sbin/cron[28173]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:48:01 info /usr/sbin/cron[28479]: (root) CMD (nethist_stats.lua)
2018-05-24 10:48:01 info /usr/sbin/cron[28478]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 10:48:01 info /usr/sbin/cron[28480]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:49:01 info /usr/sbin/cron[28838]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:50:01 info /usr/sbin/cron[28942]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:50:01 info /usr/sbin/cron[28944]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 10:50:01 info /usr/sbin/cron[28946]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 10:50:01 info /usr/sbin/cron[28948]: (root) CMD (nethist_stats.lua)
2018-05-24 10:50:01 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 10:50:01 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 10:51:01 info /usr/sbin/cron[29074]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:51:01 info /usr/sbin/cron[29073]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 10:51:26 info ucollect[4497]: Sending 46 flows
2018-05-24 10:51:26 info ucollect[4497]: Sending 42 IPv4 refused connections and 0 IPv6 ones
2018-05-24 10:52:00 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 10:52:00 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 10:52:01 info /usr/sbin/cron[29212]: (root) CMD (nethist_stats.lua)
2018-05-24 10:52:01 info /usr/sbin/cron[29213]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:53:01 info /usr/sbin/cron[29313]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:54:01 info /usr/sbin/cron[29422]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 10:54:01 info /usr/sbin/cron[29425]: (root) CMD (nethist_stats.lua)
2018-05-24 10:54:01 info /usr/sbin/cron[29423]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:55:01 info /usr/sbin/cron[29563]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:55:01 info /usr/sbin/cron[29564]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 10:55:01 info /usr/sbin/cron[29568]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 10:56:01 info /usr/sbin/cron[29691]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:56:01 info /usr/sbin/cron[29692]: (root) CMD (nethist_stats.lua)
2018-05-24 10:57:01 info /usr/sbin/cron[29801]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:57:01 info /usr/sbin/cron[29800]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 10:58:01 info /usr/sbin/cron[29939]: (root) CMD (nethist_stats.lua)
2018-05-24 10:58:01 info /usr/sbin/cron[29938]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 10:59:01 info /usr/sbin/cron[30041]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:00:01 info /usr/sbin/cron[30151]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 11:00:01 info /usr/sbin/cron[30147]: (root) CMD (/usr/bin/get-api-crl)
2018-05-24 11:00:01 info /usr/sbin/cron[30154]: (root) CMD (/usr/share/server-uplink/contract_valid.sh)
2018-05-24 11:00:01 info /usr/sbin/cron[30156]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 11:00:01 info /usr/sbin/cron[30157]: (root) CMD (nethist_stats.lua)
2018-05-24 11:00:01 info /usr/sbin/cron[30143]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:00:01 info /usr/sbin/cron[30163]: (root) CMD (/usr/share/firewall/turris-download)
2018-05-24 11:00:01 info /usr/sbin/cron[30164]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:00:01 info /usr/sbin/cron[30160]: (root) CMD (netmetr --autostart --dwlhist --rwait 1800 &)
2018-05-24 11:00:01 info /usr/sbin/cron[30165]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 11:00:01 info /usr/sbin/cron[30168]: (root) CMD (/usr/share/server-uplink/registration_code.sh)
2018-05-24 11:00:01 err server_uplink[]: Failed to download contract status
2018-05-24 11:00:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 11:00:17 err server_uplink[]: Failed to get registration code
2018-05-24 11:00:56 info nikola[]: (v42) Establishing connection took 0.618562 seconds
2018-05-24 11:00:56 info nikola[]: (v42) Logrotate took 0.004683 seconds
2018-05-24 11:00:56 info nikola[]: (v42) Syslog parsing took 0.048882 seconds
2018-05-24 11:00:57 info nikola[]: (v42) Session init took 0.764186 seconds
2018-05-24 11:00:57 info nikola[]: (v42) Records parsed: 38
2018-05-24 11:00:57 info nikola[]: (v42) Records after filtering: 27
2018-05-24 11:00:57 info nikola[]: (v42) Records filtering took 0.009332 seconds
2018-05-24 11:00:57 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 11:00:57 info nikola[]: (v42) Sending records took 0.089888 seconds
2018-05-24 11:01:01 info /usr/sbin/cron[30385]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:01:01 info /usr/sbin/cron[30386]: (root) CMD (majordomo_db.sh genhour)
2018-05-24 11:02:01 info /usr/sbin/cron[30528]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:02:01 info /usr/sbin/cron[30529]: (root) CMD (nethist_stats.lua)
2018-05-24 11:03:01 info /usr/sbin/cron[30631]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:03:01 info /usr/sbin/cron[30632]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:04:01 info /usr/sbin/cron[30772]: (root) CMD (nethist_stats.lua)
2018-05-24 11:04:01 info /usr/sbin/cron[30771]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:04:01 info /usr/sbin/cron[30773]: (root) CMD (majordomo_locked_precache.sh)
2018-05-24 11:05:01 info /usr/sbin/cron[31397]: (root) CMD (/usr/share/firewall/turris)
2018-05-24 11:05:01 info /usr/sbin/cron[31399]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:05:01 info /usr/sbin/cron[31401]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 11:05:01 info /usr/sbin/cron[31406]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 11:05:01 info turris-firewall-rules[]: (v63) IPv4 WAN interface used - 'eth1'
2018-05-24 11:05:01 info turris-firewall-rules[]: (v63) IPv6 WAN interface used - 'lo'
2018-05-24 11:05:01 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 11:05:01 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 11:05:02 info turris-firewall-rules[]: (v63) 3524 ipv4 address(es) and 3 ipv6 address(es) were loaded (c83b72d5b03454292e5000b3967bc350), 0 rule(s) overriden, 0 rule(s) skipped
2018-05-24 11:05:31 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 11:05:31 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 11:05:59 info ucollect[4497]: Updating filter addresses from version 50905050 to version 50905090 (epoch 4)
2018-05-24 11:06:01 info /usr/sbin/cron[32417]: (root) CMD (nethist_stats.lua)
2018-05-24 11:06:01 info /usr/sbin/cron[32416]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:06:01 info /usr/sbin/cron[32418]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:06:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905050 to version 50905090 (epoch 4)
2018-05-24 11:06:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 11:07:01 info /usr/sbin/cron[32659]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:08:01 info /usr/sbin/cron[393]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:08:01 info /usr/sbin/cron[394]: (root) CMD (nethist_stats.lua)
2018-05-24 11:09:01 info /usr/sbin/cron[684]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:09:01 info /usr/sbin/cron[686]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:10:01 info /usr/sbin/cron[968]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:10:01 info /usr/sbin/cron[970]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 11:10:01 info /usr/sbin/cron[972]: (root) CMD (nethist_stats.lua)
2018-05-24 11:10:01 info /usr/sbin/cron[971]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 11:11:01 info /usr/sbin/cron[1193]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:12:01 info /usr/sbin/cron[1486]: (root) CMD (/usr/sbin/logrotate -s /tmp/logrotate.state /etc/logrotate.conf)
2018-05-24 11:12:01 info /usr/sbin/cron[1487]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:12:01 info /usr/sbin/cron[1488]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:12:01 info /usr/sbin/cron[1489]: (root) CMD (nethist_stats.lua)
2018-05-24 11:13:01 info /usr/sbin/cron[1920]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:14:01 info /usr/sbin/cron[2304]: (root) CMD (nethist_stats.lua)
2018-05-24 11:14:01 info /usr/sbin/cron[2303]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:15:01 info /usr/sbin/cron[2578]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:15:01 info /usr/sbin/cron[2581]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:15:01 info /usr/sbin/cron[2584]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 11:15:01 info /usr/sbin/cron[2582]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 11:15:01 info /usr/sbin/cron[2583]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 11:15:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 11:15:44 info nikola[]: (v42) Establishing connection took 0.616051 seconds
2018-05-24 11:15:44 info nikola[]: (v42) Logrotate took 0.004939 seconds
2018-05-24 11:15:44 info nikola[]: (v42) Syslog parsing took 0.048025 seconds
2018-05-24 11:15:45 info nikola[]: (v42) Session init took 0.756583 seconds
2018-05-24 11:15:45 info nikola[]: (v42) Records parsed: 38
2018-05-24 11:15:45 info nikola[]: (v42) Records after filtering: 27
2018-05-24 11:15:45 info nikola[]: (v42) Records filtering took 0.010110 seconds
2018-05-24 11:15:45 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 11:15:45 info nikola[]: (v42) Sending records took 0.081865 seconds
2018-05-24 11:16:01 info /usr/sbin/cron[2915]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:16:01 info /usr/sbin/cron[2916]: (root) CMD (nethist_stats.lua)
2018-05-24 11:17:01 info /usr/sbin/cron[3133]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:18:01 info /usr/sbin/cron[3479]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:18:01 info /usr/sbin/cron[3483]: (root) CMD (nethist_stats.lua)
2018-05-24 11:18:01 info /usr/sbin/cron[3481]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:18:48 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 11:18:48 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 11:19:01 info /usr/sbin/cron[3795]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:20:01 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 11:20:01 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 11:20:01 info /usr/sbin/cron[4020]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 11:20:01 info /usr/sbin/cron[4018]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:20:01 info /usr/sbin/cron[4023]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 11:20:01 info /usr/sbin/cron[4024]: (root) CMD (nethist_stats.lua)
2018-05-24 11:21:01 info /usr/sbin/cron[4528]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:21:01 info /usr/sbin/cron[4529]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Global permanent pool: 3092/4096 (18)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Global batch pool: 0/4096 (0)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Global temporary pool: 156/4096 (3)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Buffer pool for uplink: 4/4096 (1)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Config pool: 4094/8192 (137)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Badconf: 48/4096 (1)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Bandwidth: 2744/4096 (6)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Count: 264/4096 (1)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Fake: 189120/217088 (161)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Fake log: 577/4096 (24)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Flow: 128/4096 (5)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Flow pool: 6482/8192 (134)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Flow conf pool: 839968/884736 (44896)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Fwup: 168/4096 (7)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 1: 0/4096 (0)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 2: 120173/126976 (6439)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Refused: 104/4096 (3)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Refuse pool 1: 0/4096 (0)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Refuse pool 2: 12455/16384 (527)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Sniff: 44/4096 (3)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Sniffer pool: 0/4096 (0)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats: Spoof: 224/4096 (1)
2018-05-24 11:21:21 info ucollect[4497]: Mempool stats done
2018-05-24 11:21:26 info ucollect[4497]: Sending 40 flows
2018-05-24 11:21:26 info ucollect[4497]: Sending 31 IPv4 refused connections and 0 IPv6 ones
2018-05-24 11:22:01 info /usr/sbin/cron[5011]: (root) CMD (nethist_stats.lua)
2018-05-24 11:22:01 info /usr/sbin/cron[5012]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:23:01 info /usr/sbin/cron[5206]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:24:01 info /usr/sbin/cron[5402]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:24:01 info /usr/sbin/cron[5404]: (root) CMD (nethist_stats.lua)
2018-05-24 11:24:01 info /usr/sbin/cron[5403]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:25:01 info /usr/sbin/cron[5704]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:25:01 info /usr/sbin/cron[5703]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 11:25:01 info /usr/sbin/cron[5705]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 11:25:59 info ucollect[4497]: Updating filter addresses from version 50905090 to version 50905130 (epoch 4)
2018-05-24 11:26:01 info /usr/sbin/cron[6019]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:26:01 info /usr/sbin/cron[6020]: (root) CMD (nethist_stats.lua)
2018-05-24 11:26:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905090 to version 50905130 (epoch 4)
2018-05-24 11:26:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 11:27:01 info /usr/sbin/cron[6366]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:27:01 info /usr/sbin/cron[6367]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:28:01 info /usr/sbin/cron[6690]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:28:01 info /usr/sbin/cron[6691]: (root) CMD (nethist_stats.lua)
2018-05-24 11:29:01 info /usr/sbin/cron[6944]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:30:01 info /usr/sbin/cron[7159]: (root) CMD (/usr/bin/get-api-crl)
2018-05-24 11:30:01 info /usr/sbin/cron[7161]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 11:30:01 info /usr/sbin/cron[7163]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 11:30:01 info /usr/sbin/cron[7155]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:30:01 info /usr/sbin/cron[7162]: (root) CMD (nethist_stats.lua)
2018-05-24 11:30:01 info /usr/sbin/cron[7164]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:30:01 info /usr/sbin/cron[7165]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 11:30:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 11:30:46 info nikola[]: (v42) Establishing connection took 0.607572 seconds
2018-05-24 11:30:46 info nikola[]: (v42) Logrotate took 0.005120 seconds
2018-05-24 11:30:46 info nikola[]: (v42) Syslog parsing took 0.046983 seconds
2018-05-24 11:30:46 info nikola[]: (v42) Session init took 0.760341 seconds
2018-05-24 11:30:46 info nikola[]: (v42) Records parsed: 35
2018-05-24 11:30:46 info nikola[]: (v42) Records after filtering: 26
2018-05-24 11:30:46 info nikola[]: (v42) Records filtering took 0.008466 seconds
2018-05-24 11:30:46 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 11:30:46 info nikola[]: (v42) Sending records took 0.093201 seconds
2018-05-24 11:31:01 info /usr/sbin/cron[7626]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:31:59 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 11:31:59 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 11:32:01 info /usr/sbin/cron[7876]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:32:01 info /usr/sbin/cron[7877]: (root) CMD (nethist_stats.lua)
2018-05-24 11:33:01 info /usr/sbin/cron[8273]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:33:01 info /usr/sbin/cron[8272]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:34:01 info /usr/sbin/cron[8581]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:34:01 info /usr/sbin/cron[8582]: (root) CMD (nethist_stats.lua)
2018-05-24 11:35:01 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 11:35:01 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 11:35:01 info /usr/sbin/cron[8977]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 11:35:01 info /usr/sbin/cron[8976]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:35:01 info /usr/sbin/cron[8978]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 11:36:01 info /usr/sbin/cron[9474]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:36:01 info /usr/sbin/cron[9475]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:36:01 info /usr/sbin/cron[9476]: (root) CMD (nethist_stats.lua)
2018-05-24 11:37:01 info /usr/sbin/cron[9764]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:38:01 info /usr/sbin/cron[10030]: (root) CMD (nethist_stats.lua)
2018-05-24 11:38:01 info /usr/sbin/cron[10029]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:38:09 info dnsmasq-dhcp[5601]: DHCPINFORM(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 11:38:09 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 11:39:01 info /usr/sbin/cron[10401]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:39:01 info /usr/sbin/cron[10402]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:40:01 info /usr/sbin/cron[10774]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 11:40:01 info /usr/sbin/cron[10773]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 11:40:01 info /usr/sbin/cron[10775]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:40:01 info /usr/sbin/cron[10779]: (root) CMD (nethist_stats.lua)
2018-05-24 11:41:01 info /usr/sbin/cron[11158]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:42:01 info /usr/sbin/cron[11502]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:42:01 info /usr/sbin/cron[11504]: (root) CMD (nethist_stats.lua)
2018-05-24 11:42:01 info /usr/sbin/cron[11503]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:43:01 info /usr/sbin/cron[12025]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:44:01 info /usr/sbin/cron[12377]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:44:01 info /usr/sbin/cron[12378]: (root) CMD (nethist_stats.lua)
2018-05-24 11:44:18 info dnsmasq-dhcp[5601]: DHCPDISCOVER(br-lan) 18:8e:d5:00:12:d0
2018-05-24 11:44:18 info dnsmasq-dhcp[5601]: DHCPOFFER(br-lan) 192.168.2.113 18:8e:d5:00:12:d0
2018-05-24 11:44:18 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.113 18:8e:d5:00:12:d0
2018-05-24 11:44:18 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.113 18:8e:d5:00:12:d0 TV_Philips_32PFL7406
2018-05-24 11:44:19 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 11:44:19 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 11:44:19 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 2 times, suppressed by syslog-ng on Omnia
2018-05-24 11:44:19 info dhcp_host_domain_ng.py[]: DHCP add new hostname [TV_Philips_32PFL7406,192.168.2.113]
2018-05-24 11:44:19 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 11:44:19 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 11:44:21 info dnsmasq-dhcp[5601]: DHCPDISCOVER(br-lan) 00:0e:9e:05:23:2b
2018-05-24 11:44:21 info dnsmasq-dhcp[5601]: DHCPOFFER(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 11:44:21 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 11:44:21 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 11:44:21 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 11:44:21 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 11:44:21 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 3 times, suppressed by syslog-ng on Omnia
2018-05-24 11:44:21 info dhcp_host_domain_ng.py[]: DHCP add new hostname [Topfield_SRP-2411,192.168.2.111]
2018-05-24 11:44:21 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 11:44:21 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 11:44:32 info dnsmasq-dhcp[5601]: DHCPDISCOVER(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 11:44:32 info dnsmasq-dhcp[5601]: DHCPOFFER(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 11:44:32 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 11:44:32 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 11:44:32 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 11:44:32 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 11:44:32 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 4 times, suppressed by syslog-ng on Omnia
2018-05-24 11:44:32 info dhcp_host_domain_ng.py[]: DHCP add new hostname [Fujitsu_kuchyn,192.168.2.120]
2018-05-24 11:44:32 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 11:44:32 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 11:45:01 info /usr/sbin/cron[12719]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:45:01 info /usr/sbin/cron[12722]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:45:01 info /usr/sbin/cron[12724]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 11:45:01 info /usr/sbin/cron[12723]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 11:45:01 info /usr/sbin/cron[12725]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 11:45:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 11:45:07 info nikola[]: (v42) Establishing connection took 0.652681 seconds
2018-05-24 11:45:07 info nikola[]: (v42) Logrotate took 0.005191 seconds
2018-05-24 11:45:07 info nikola[]: (v42) Syslog parsing took 0.055060 seconds
2018-05-24 11:45:08 info nikola[]: (v42) Session init took 0.770660 seconds
2018-05-24 11:45:08 info nikola[]: (v42) Records parsed: 45
2018-05-24 11:45:08 info nikola[]: (v42) Records after filtering: 30
2018-05-24 11:45:08 info nikola[]: (v42) Records filtering took 0.009939 seconds
2018-05-24 11:45:08 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 11:45:08 info nikola[]: (v42) Sending records took 0.085450 seconds
2018-05-24 11:45:33 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 11:45:33 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 11:45:59 info ucollect[4497]: Updating filter addresses from version 50905130 to version 50905170 (epoch 4)
2018-05-24 11:46:01 info /usr/sbin/cron[13088]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:46:01 info /usr/sbin/cron[13089]: (root) CMD (nethist_stats.lua)
2018-05-24 11:46:03 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905130 to version 50905170 (epoch 4)
2018-05-24 11:46:08 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 11:47:01 info /usr/sbin/cron[13328]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:48:01 info /usr/sbin/cron[13719]: (root) CMD (nethist_stats.lua)
2018-05-24 11:48:01 info /usr/sbin/cron[13718]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:48:01 info /usr/sbin/cron[13720]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:49:01 info /usr/sbin/cron[14066]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:50:01 info /usr/sbin/cron[14169]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:50:01 info /usr/sbin/cron[14171]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 11:50:01 info /usr/sbin/cron[14175]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 11:50:01 info /usr/sbin/cron[14173]: (root) CMD (nethist_stats.lua)
2018-05-24 11:50:01 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 11:50:01 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 11:51:01 info /usr/sbin/cron[14298]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:51:01 info /usr/sbin/cron[14299]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:51:26 info ucollect[4497]: Sending 49 flows
2018-05-24 11:51:26 info ucollect[4497]: Sending 41 IPv4 refused connections and 0 IPv6 ones
2018-05-24 11:52:01 info /usr/sbin/cron[14437]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:52:01 info /usr/sbin/cron[14438]: (root) CMD (nethist_stats.lua)
2018-05-24 11:53:01 info /usr/sbin/cron[14539]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:54:01 info /usr/sbin/cron[14643]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:54:01 info /usr/sbin/cron[14644]: (root) CMD (nethist_stats.lua)
2018-05-24 11:54:01 info /usr/sbin/cron[14642]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:55:01 info /usr/sbin/cron[14782]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:55:01 info /usr/sbin/cron[14783]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 11:55:01 info /usr/sbin/cron[14784]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 11:56:01 info /usr/sbin/cron[14908]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:56:01 info /usr/sbin/cron[14909]: (root) CMD (nethist_stats.lua)
2018-05-24 11:57:01 info /usr/sbin/cron[15013]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 11:57:01 info /usr/sbin/cron[15014]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:58:01 info /usr/sbin/cron[15154]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:58:01 info /usr/sbin/cron[15155]: (root) CMD (nethist_stats.lua)
2018-05-24 11:59:01 info /usr/sbin/cron[15259]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 11:59:23 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 11:59:23 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 11:59:31 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 11:59:31 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 11:59:36 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 11:59:36 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 12:00:01 info /usr/sbin/cron[15365]: (root) CMD (/usr/bin/get-api-crl)
2018-05-24 12:00:01 info /usr/sbin/cron[15370]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 12:00:01 info /usr/sbin/cron[15373]: (root) CMD (/usr/bin/updater-supervisor -d --rand-sleep)
2018-05-24 12:00:01 info /usr/sbin/cron[15374]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 12:00:01 info /usr/sbin/cron[15375]: (root) CMD (nethist_stats.lua)
2018-05-24 12:00:01 info /usr/sbin/cron[15361]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:00:01 info /usr/sbin/cron[15382]: (root) CMD (/usr/share/firewall/turris-download)
2018-05-24 12:00:01 info /usr/sbin/cron[15383]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:00:01 info /usr/sbin/cron[15376]: (root) CMD (netmetr --autostart --dwlhist --rwait 1800 &)
2018-05-24 12:00:01 info /usr/sbin/cron[15378]: (root) CMD (/usr/share/server-uplink/registration_code.sh)
2018-05-24 12:00:01 info /usr/sbin/cron[15384]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 12:00:01 info /usr/sbin/cron[15385]: (root) CMD (/usr/share/server-uplink/contract_valid.sh)
2018-05-24 12:00:02 err server_uplink[]: Failed to download contract status
2018-05-24 12:00:03 info updater-supervisor[]: Suspending updater start for 2654 seconds
2018-05-24 12:00:03 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 12:00:25 info nikola[]: (v42) Establishing connection took 0.622631 seconds
2018-05-24 12:00:25 info nikola[]: (v42) Logrotate took 0.004808 seconds
2018-05-24 12:00:25 info nikola[]: (v42) Syslog parsing took 0.059522 seconds
2018-05-24 12:00:26 info nikola[]: (v42) Session init took 0.796597 seconds
2018-05-24 12:00:26 info nikola[]: (v42) Records parsed: 57
2018-05-24 12:00:26 info nikola[]: (v42) Records after filtering: 42
2018-05-24 12:00:26 info nikola[]: (v42) Records filtering took 0.010591 seconds
2018-05-24 12:00:26 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 12:00:26 info nikola[]: (v42) Sending records took 0.222336 seconds
2018-05-24 12:01:01 info /usr/sbin/cron[15590]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:01:01 info /usr/sbin/cron[15591]: (root) CMD (majordomo_db.sh genhour)
2018-05-24 12:01:01 info /usr/sbin/cron[15592]: (root) CMD ((cat /tmp/nethist.stats | sort ; echo "uptime = $(cat /proc/uptime | cut -d. -f1)" ) | logger -p info -t nethist ; rm /tmp/nethist.stats)
2018-05-24 12:01:01 info nethist[]: fs_avg = 26096299.014737
2018-05-24 12:01:01 info nethist[]: fs_max = 26096688
2018-05-24 12:01:01 info nethist[]: fs_min = 26096256
2018-05-24 12:01:01 info nethist[]: fs_samples = 1425
2018-05-24 12:01:01 info nethist[]: fs_sum = 37187226096
2018-05-24 12:01:01 info nethist[]: last_timestamp = 1527155988
2018-05-24 12:01:01 info nethist[]: load_avg = 0.21757192982456
2018-05-24 12:01:01 info nethist[]: load_max = 0.92
2018-05-24 12:01:01 info nethist[]: load_min = 0.07
2018-05-24 12:01:01 info nethist[]: load_samples = 1425
2018-05-24 12:01:01 info nethist[]: load_sum = 310.04
2018-05-24 12:01:01 info nethist[]: mem_buffers_avg = 731657.30245614
2018-05-24 12:01:01 info nethist[]: mem_buffers_max = 741288
2018-05-24 12:01:01 info nethist[]: mem_buffers_min = 721224
2018-05-24 12:01:01 info nethist[]: mem_buffers_samples = 1425
2018-05-24 12:01:01 info nethist[]: mem_buffers_sum = 1042611656
2018-05-24 12:01:01 info nethist[]: mem_cached_avg = 1052
2018-05-24 12:01:01 info nethist[]: mem_cached_max = 1052
2018-05-24 12:01:01 info nethist[]: mem_cached_min = 1052
2018-05-24 12:01:01 info nethist[]: mem_cached_samples = 1425
2018-05-24 12:01:01 info nethist[]: mem_cached_sum = 1499100
2018-05-24 12:01:01 info nethist[]: mem_free_avg = 224765.96210526
2018-05-24 12:01:01 info nethist[]: mem_free_max = 270760
2018-05-24 12:01:01 info nethist[]: mem_free_min = 182816
2018-05-24 12:01:01 info nethist[]: mem_free_samples = 1425
2018-05-24 12:01:01 info nethist[]: mem_free_sum = 320291496
2018-05-24 12:01:01 info nethist[]: mem_total_avg = 1030984
2018-05-24 12:01:01 info nethist[]: mem_total_max = 1030984
2018-05-24 12:01:01 info nethist[]: mem_total_min = 1030984
2018-05-24 12:01:01 info nethist[]: mem_total_samples = 1425
2018-05-24 12:01:01 info nethist[]: mem_total_sum = 1469152200
2018-05-24 12:01:01 info nethist[]: temp_board_avg = nan
2018-05-24 12:01:01 info nethist[]: temp_board_max = 0
2018-05-24 12:01:01 info nethist[]: temp_board_samples = 0
2018-05-24 12:01:01 info nethist[]: temp_board_sum = 0
2018-05-24 12:01:01 info nethist[]: temp_cpu_avg = nan
2018-05-24 12:01:01 info nethist[]: temp_cpu_max = 0
2018-05-24 12:01:01 info nethist[]: temp_cpu_samples = 0
2018-05-24 12:01:01 info nethist[]: temp_cpu_sum = 0
2018-05-24 12:01:01 info nethist[]: uptime = 146422
2018-05-24 12:02:01 info /usr/sbin/cron[15742]: (root) CMD (nethist_stats.lua)
2018-05-24 12:02:01 info /usr/sbin/cron[15741]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:02:02 err server_uplink[]: Failed to get registration code
2018-05-24 12:02:09 err turris-firewall-rules[]: (v63) Failed to download https://api.turris.cz/firewall/turris-ipsets.gz.sign
2018-05-24 12:03:01 info /usr/sbin/cron[15847]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:03:01 info /usr/sbin/cron[15846]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:04:01 info /usr/sbin/cron[15994]: (root) CMD (majordomo_locked_precache.sh)
2018-05-24 12:04:01 info /usr/sbin/cron[15993]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:04:01 info /usr/sbin/cron[15996]: (root) CMD (nethist_stats.lua)
2018-05-24 12:05:01 info /usr/sbin/cron[16620]: (root) CMD (/usr/share/firewall/turris)
2018-05-24 12:05:01 info /usr/sbin/cron[16623]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:05:01 info /usr/sbin/cron[16626]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 12:05:01 info /usr/sbin/cron[16624]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 12:05:01 info /usr/sbin/cron[16625]: (root) CMD ( schnapps cleanup)
2018-05-24 12:05:01 info turris-firewall-rules[]: (v63) IPv4 WAN interface used - 'eth1'
2018-05-24 12:05:01 info turris-firewall-rules[]: (v63) IPv6 WAN interface used - 'lo'
2018-05-24 12:05:01 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 12:05:01 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 12:05:02 info turris-firewall-rules[]: (v63) 3524 ipv4 address(es) and 3 ipv6 address(es) were loaded (c83b72d5b03454292e5000b3967bc350), 0 rule(s) overriden, 0 rule(s) skipped
2018-05-24 12:05:59 info ucollect[4497]: Updating filter addresses from version 50905170 to version 50905210 (epoch 4)
2018-05-24 12:06:01 info /usr/sbin/cron[17719]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:06:01 info /usr/sbin/cron[17720]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:06:01 info /usr/sbin/cron[17724]: (root) CMD (nethist_stats.lua)
2018-05-24 12:06:03 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905170 to version 50905210 (epoch 4)
2018-05-24 12:06:08 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 12:07:01 info /usr/sbin/cron[17962]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:08:01 info /usr/sbin/cron[18157]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:08:01 info /usr/sbin/cron[18158]: (root) CMD (nethist_stats.lua)
2018-05-24 12:09:01 info /usr/sbin/cron[18398]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:09:01 info /usr/sbin/cron[18399]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:09:53 info hostapd[]: wlan0: STA c4:3a:be:95:6a:75 IEEE 802.11: authenticated
2018-05-24 12:09:53 info hostapd[]: wlan0: STA c4:3a:be:95:6a:75 IEEE 802.11: associated (aid 1)
2018-05-24 12:09:53 info hostapd[]: wlan0: STA c4:3a:be:95:6a:75 RADIUS: starting accounting session DA1DF5779EAC9877
2018-05-24 12:09:53 info hostapd[]: wlan0: STA c4:3a:be:95:6a:75 WPA: pairwise key handshake completed (RSN)
2018-05-24 12:09:53 info dnsmasq-dhcp[5601]: DHCPDISCOVER(br-lan) c4:3a:be:95:6a:75
2018-05-24 12:09:53 info dnsmasq-dhcp[5601]: DHCPOFFER(br-lan) 192.168.2.105 c4:3a:be:95:6a:75
2018-05-24 12:09:53 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.105 c4:3a:be:95:6a:75
2018-05-24 12:09:53 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.105 c4:3a:be:95:6a:75 Sony_Xperia_Z3
2018-05-24 12:09:53 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 12:09:53 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 12:09:53 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 5 times, suppressed by syslog-ng on Omnia
2018-05-24 12:09:53 info dhcp_host_domain_ng.py[]: DHCP add new hostname [Sony_Xperia_Z3,192.168.2.105]
2018-05-24 12:09:53 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 12:09:53 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 12:10:01 info /usr/sbin/cron[18687]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:10:01 info /usr/sbin/cron[18690]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 12:10:01 info /usr/sbin/cron[18689]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 12:10:01 info /usr/sbin/cron[18691]: (root) CMD (nethist_stats.lua)
2018-05-24 12:11:01 info /usr/sbin/cron[18906]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:12:01 info /usr/sbin/cron[19165]: (root) CMD (nethist_stats.lua)
2018-05-24 12:12:01 info /usr/sbin/cron[19164]: (root) CMD (/usr/sbin/logrotate -s /tmp/logrotate.state /etc/logrotate.conf)
2018-05-24 12:12:01 info /usr/sbin/cron[19166]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:12:01 info /usr/sbin/cron[19170]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:12:43 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 12:12:43 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 12:12:43 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 12:12:43 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 12:13:01 info /usr/sbin/cron[19610]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:14:01 info /usr/sbin/cron[20005]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:14:01 info /usr/sbin/cron[20006]: (root) CMD (nethist_stats.lua)
2018-05-24 12:14:19 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 12:14:19 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 12:14:19 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 3 times, suppressed by syslog-ng on Omnia
2018-05-24 12:14:19 warning dhcp_host_domain_ng.py[]: Del_lease, hosname check failed
2018-05-24 12:14:19 info dhcp_host_domain_ng.py[]: DHCP delete hostname [del,TV_Philips_32PFL7406,192.168.2.113]
2018-05-24 12:14:19 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 12:14:19 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 12:14:25 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 12:14:25 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 12:15:01 info /usr/sbin/cron[20288]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:15:01 info /usr/sbin/cron[20291]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:15:01 info /usr/sbin/cron[20295]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 12:15:01 info /usr/sbin/cron[20294]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 12:15:01 info /usr/sbin/cron[20292]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 12:15:03 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 12:15:20 info nikola[]: (v42) Establishing connection took 0.600738 seconds
2018-05-24 12:15:20 info nikola[]: (v42) Logrotate took 0.004783 seconds
2018-05-24 12:15:20 info nikola[]: (v42) Syslog parsing took 0.053284 seconds
2018-05-24 12:15:21 info nikola[]: (v42) Session init took 0.762425 seconds
2018-05-24 12:15:21 info nikola[]: (v42) Records parsed: 52
2018-05-24 12:15:21 info nikola[]: (v42) Records after filtering: 38
2018-05-24 12:15:21 info nikola[]: (v42) Records filtering took 0.010445 seconds
2018-05-24 12:15:21 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 12:15:21 info nikola[]: (v42) Sending records took 0.085022 seconds
2018-05-24 12:16:01 info /usr/sbin/cron[20627]: (root) CMD (nethist_stats.lua)
2018-05-24 12:16:01 info /usr/sbin/cron[20626]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:17:01 info /usr/sbin/cron[20832]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:18:01 info /usr/sbin/cron[21129]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:18:01 info /usr/sbin/cron[21130]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:18:01 info /usr/sbin/cron[21138]: (root) CMD (nethist_stats.lua)
2018-05-24 12:19:01 info /usr/sbin/cron[21415]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:20:01 info /usr/sbin/cron[21670]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:20:01 info /usr/sbin/cron[21672]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 12:20:01 info /usr/sbin/cron[21674]: (root) CMD (nethist_stats.lua)
2018-05-24 12:20:01 info /usr/sbin/cron[21676]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 12:20:01 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 12:20:01 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 12:21:01 info /usr/sbin/cron[22121]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:21:01 info /usr/sbin/cron[22122]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Global permanent pool: 3092/4096 (18)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Global batch pool: 0/4096 (0)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Global temporary pool: 156/4096 (3)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Buffer pool for uplink: 4/4096 (1)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Config pool: 4094/8192 (137)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Badconf: 48/4096 (1)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Bandwidth: 2744/4096 (6)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Count: 264/4096 (1)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Fake: 189120/217088 (161)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Fake log: 2116/4096 (75)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Flow: 128/4096 (5)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Flow pool: 6419/8192 (133)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Flow conf pool: 840475/884736 (44924)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Fwup: 168/4096 (7)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 1: 0/4096 (0)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 2: 120675/126976 (6465)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Refused: 104/4096 (3)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Refuse pool 1: 0/4096 (0)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Refuse pool 2: 85265/90112 (3604)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Sniff: 44/4096 (3)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Sniffer pool: 0/4096 (0)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats: Spoof: 224/4096 (1)
2018-05-24 12:21:21 info ucollect[4497]: Mempool stats done
2018-05-24 12:21:26 info ucollect[4497]: Sending 40 flows
2018-05-24 12:21:26 info ucollect[4497]: Sending 33 IPv4 refused connections and 0 IPv6 ones
2018-05-24 12:22:01 info /usr/sbin/cron[22653]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:22:01 info /usr/sbin/cron[22654]: (root) CMD (nethist_stats.lua)
2018-05-24 12:23:01 info /usr/sbin/cron[22853]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:24:01 info /usr/sbin/cron[23036]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:24:01 info /usr/sbin/cron[23037]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:24:01 info /usr/sbin/cron[23038]: (root) CMD (nethist_stats.lua)
2018-05-24 12:24:53 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.105 c4:3a:be:95:6a:75
2018-05-24 12:24:53 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.105 c4:3a:be:95:6a:75 Sony_Xperia_Z3
2018-05-24 12:25:01 info /usr/sbin/cron[23296]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:25:01 info /usr/sbin/cron[23295]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 12:25:01 info /usr/sbin/cron[23298]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 12:25:59 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 12:25:59 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 12:25:59 info ucollect[4497]: Updating filter addresses from version 50905210 to version 50905250 (epoch 4)
2018-05-24 12:26:01 info /usr/sbin/cron[23605]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:26:01 info /usr/sbin/cron[23606]: (root) CMD (nethist_stats.lua)
2018-05-24 12:26:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905210 to version 50905250 (epoch 4)
2018-05-24 12:26:06 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 12:26:06 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 12:26:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 12:27:01 info /usr/sbin/cron[23939]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:27:01 info /usr/sbin/cron[23940]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:28:01 info /usr/sbin/cron[24277]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:28:01 info /usr/sbin/cron[24278]: (root) CMD (nethist_stats.lua)
2018-05-24 12:29:01 info /usr/sbin/cron[24523]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:29:28 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 12:29:28 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 12:30:01 info /usr/sbin/cron[24732]: (root) CMD (/usr/bin/get-api-crl)
2018-05-24 12:30:01 info /usr/sbin/cron[24727]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:30:01 info /usr/sbin/cron[24737]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 12:30:01 info /usr/sbin/cron[24738]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 12:30:01 info /usr/sbin/cron[24739]: (root) CMD (nethist_stats.lua)
2018-05-24 12:30:01 info /usr/sbin/cron[24735]: (root) CMD (/usr/share/haas/register.sh)
2018-05-24 12:30:01 info /usr/sbin/cron[24742]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 12:30:01 info /usr/sbin/cron[24743]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:30:03 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 12:30:06 info nikola[]: (v42) Establishing connection took 0.614478 seconds
2018-05-24 12:30:06 info nikola[]: (v42) Logrotate took 0.006261 seconds
2018-05-24 12:30:06 info nikola[]: (v42) Syslog parsing took 0.048413 seconds
2018-05-24 12:30:07 info nikola[]: (v42) Session init took 0.776447 seconds
2018-05-24 12:30:07 info nikola[]: (v42) Records parsed: 34
2018-05-24 12:30:07 info nikola[]: (v42) Records after filtering: 22
2018-05-24 12:30:07 info nikola[]: (v42) Records filtering took 0.008774 seconds
2018-05-24 12:30:07 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 12:30:07 info nikola[]: (v42) Sending records took 0.099087 seconds
2018-05-24 12:31:01 info /usr/sbin/cron[25160]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:32:01 info /usr/sbin/cron[25475]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:32:01 info /usr/sbin/cron[25476]: (root) CMD (nethist_stats.lua)
2018-05-24 12:33:01 info /usr/sbin/cron[25847]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:33:01 info /usr/sbin/cron[25848]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:34:01 info /usr/sbin/cron[26109]: (root) CMD (nethist_stats.lua)
2018-05-24 12:34:01 info /usr/sbin/cron[26108]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:35:01 info /usr/sbin/cron[26425]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:35:01 info /usr/sbin/cron[26427]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 12:35:01 info /usr/sbin/cron[26426]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 12:35:01 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 12:35:01 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 12:36:01 info /usr/sbin/cron[26937]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:36:01 info /usr/sbin/cron[26938]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:36:01 info /usr/sbin/cron[26939]: (root) CMD (nethist_stats.lua)
2018-05-24 12:37:01 info /usr/sbin/cron[27310]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:38:01 info /usr/sbin/cron[27627]: (root) CMD (nethist_stats.lua)
2018-05-24 12:38:01 info /usr/sbin/cron[27626]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:38:02 info dnsmasq-dhcp[5601]: DHCPINFORM(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 12:38:02 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 12:39:01 info /usr/sbin/cron[27959]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:39:01 info /usr/sbin/cron[27958]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:39:17 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 12:39:17 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 12:39:36 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 12:39:36 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 12:39:53 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.105 c4:3a:be:95:6a:75
2018-05-24 12:39:53 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.105 c4:3a:be:95:6a:75 Sony_Xperia_Z3
2018-05-24 12:40:01 info /usr/sbin/cron[28268]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:40:01 info /usr/sbin/cron[28267]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 12:40:01 info /usr/sbin/cron[28270]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 12:40:01 info /usr/sbin/cron[28269]: (root) CMD (nethist_stats.lua)
2018-05-24 12:41:01 info /usr/sbin/cron[28667]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:42:01 info /usr/sbin/cron[28977]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:42:01 info /usr/sbin/cron[28978]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:42:01 info /usr/sbin/cron[28979]: (root) CMD (nethist_stats.lua)
2018-05-24 12:43:01 info /usr/sbin/cron[29401]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:44:01 info /usr/sbin/cron[29856]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:44:01 info /usr/sbin/cron[29857]: (root) CMD (nethist_stats.lua)
2018-05-24 12:44:17 info updater-supervisor[]: Running pkgupdate
2018-05-24 12:44:23 warning updater[29956]: planner.lua:344 (pkg_plan): Requested package luci-i18n-ddns-en that is missing, ignoring as requested.
2018-05-24 12:44:24 info updater-supervisor[]: pkgupdate reported no errors
2018-05-24 12:44:30 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 12:44:30 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 12:45:01 info /usr/sbin/cron[30337]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 12:45:01 info /usr/sbin/cron[30338]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:45:01 info /usr/sbin/cron[30339]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:45:01 info /usr/sbin/cron[30340]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 12:45:01 info /usr/sbin/cron[30341]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 12:45:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 12:45:47 info nikola[]: (v42) Establishing connection took 0.601950 seconds
2018-05-24 12:45:48 info nikola[]: (v42) Logrotate took 0.004873 seconds
2018-05-24 12:45:48 info nikola[]: (v42) Syslog parsing took 0.058576 seconds
2018-05-24 12:45:48 info nikola[]: (v42) Session init took 0.776419 seconds
2018-05-24 12:45:48 info nikola[]: (v42) Records parsed: 52
2018-05-24 12:45:48 info nikola[]: (v42) Records after filtering: 39
2018-05-24 12:45:48 info nikola[]: (v42) Records filtering took 0.010641 seconds
2018-05-24 12:45:48 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 12:45:48 info nikola[]: (v42) Sending records took 0.088960 seconds
2018-05-24 12:45:59 info ucollect[4497]: Updating filter addresses from version 50905250 to version 50905290 (epoch 4)
2018-05-24 12:46:01 info /usr/sbin/cron[30672]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:46:01 info /usr/sbin/cron[30673]: (root) CMD (nethist_stats.lua)
2018-05-24 12:46:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905250 to version 50905290 (epoch 4)
2018-05-24 12:46:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 12:47:01 info /usr/sbin/cron[30976]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:48:01 info /usr/sbin/cron[31268]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:48:01 info /usr/sbin/cron[31269]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:48:01 info /usr/sbin/cron[31272]: (root) CMD (nethist_stats.lua)
2018-05-24 12:49:01 info /usr/sbin/cron[31637]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:50:01 info /usr/sbin/cron[31740]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 12:50:01 info /usr/sbin/cron[31742]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 12:50:01 info /usr/sbin/cron[31737]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:50:01 info /usr/sbin/cron[31741]: (root) CMD (nethist_stats.lua)
2018-05-24 12:50:01 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 12:50:01 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 12:51:01 info /usr/sbin/cron[31869]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:51:01 info /usr/sbin/cron[31870]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:51:26 info ucollect[4497]: Sending 53 flows
2018-05-24 12:51:26 info ucollect[4497]: Sending 39 IPv4 refused connections and 0 IPv6 ones
2018-05-24 12:52:01 info /usr/sbin/cron[32009]: (root) CMD (nethist_stats.lua)
2018-05-24 12:52:01 info /usr/sbin/cron[32008]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:52:46 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 12:52:46 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 12:53:01 info /usr/sbin/cron[32111]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:53:09 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 12:53:09 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 12:54:01 info /usr/sbin/cron[32215]: (root) CMD (nethist_stats.lua)
2018-05-24 12:54:01 info /usr/sbin/cron[32214]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:54:01 info /usr/sbin/cron[32216]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:54:54 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.105 c4:3a:be:95:6a:75
2018-05-24 12:54:54 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.105 c4:3a:be:95:6a:75 Sony_Xperia_Z3
2018-05-24 12:55:01 info /usr/sbin/cron[32358]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 12:55:01 info /usr/sbin/cron[32357]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:55:01 info /usr/sbin/cron[32359]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 12:56:01 info /usr/sbin/cron[32488]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:56:01 info /usr/sbin/cron[32489]: (root) CMD (nethist_stats.lua)
2018-05-24 12:56:50 info hostapd[]: wlan0: STA c0:11:73:18:3f:8d IEEE 802.11: authenticated
2018-05-24 12:56:50 info hostapd[]: wlan0: STA c0:11:73:18:3f:8d IEEE 802.11: associated (aid 2)
2018-05-24 12:56:50 info hostapd[]: wlan0: STA c0:11:73:18:3f:8d RADIUS: starting accounting session F507327BB9C0B4A8
2018-05-24 12:56:50 info hostapd[]: wlan0: STA c0:11:73:18:3f:8d WPA: pairwise key handshake completed (RSN)
2018-05-24 12:56:50 info dnsmasq-dhcp[5601]: DHCPDISCOVER(br-lan) c0:11:73:18:3f:8d
2018-05-24 12:56:50 info dnsmasq-dhcp[5601]: DHCPOFFER(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 12:56:51 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 12:56:51 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 12:56:51 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 12:56:51 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 12:56:51 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 5 times, suppressed by syslog-ng on Omnia
2018-05-24 12:56:51 info dhcp_host_domain_ng.py[]: DHCP add new hostname [Tablet_Jirina,192.168.2.115]
2018-05-24 12:56:51 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 12:56:51 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 12:57:01 info /usr/sbin/cron[32600]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 12:57:01 info /usr/sbin/cron[32601]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:58:01 info /usr/sbin/cron[32739]: (root) CMD (nethist_stats.lua)
2018-05-24 12:58:01 info /usr/sbin/cron[32738]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 12:59:01 info /usr/sbin/cron[375]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:00:01 info /usr/sbin/cron[518]: (root) CMD (/usr/bin/get-api-crl)
2018-05-24 13:00:01 info /usr/sbin/cron[491]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:00:01 info /usr/sbin/cron[525]: (root) CMD (nethist_stats.lua)
2018-05-24 13:00:01 info /usr/sbin/cron[529]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 13:00:01 info /usr/sbin/cron[524]: (root) CMD (/usr/share/server-uplink/contract_valid.sh)
2018-05-24 13:00:01 info /usr/sbin/cron[530]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 13:00:01 info /usr/sbin/cron[531]: (root) CMD (netmetr --autostart --dwlhist --rwait 1800 &)
2018-05-24 13:00:01 info /usr/sbin/cron[528]: (root) CMD (/usr/share/server-uplink/registration_code.sh)
2018-05-24 13:00:01 info /usr/sbin/cron[533]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 13:00:01 info /usr/sbin/cron[545]: (root) CMD (/usr/share/firewall/turris-download)
2018-05-24 13:00:01 info /usr/sbin/cron[547]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:00:02 err server_uplink[]: Failed to download contract status
2018-05-24 13:00:03 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 13:00:24 info nikola[]: (v42) Establishing connection took 0.613426 seconds
2018-05-24 13:00:24 info nikola[]: (v42) Logrotate took 0.004730 seconds
2018-05-24 13:00:24 info nikola[]: (v42) Syslog parsing took 0.059812 seconds
2018-05-24 13:00:25 info nikola[]: (v42) Session init took 0.769621 seconds
2018-05-24 13:00:25 info nikola[]: (v42) Records parsed: 48
2018-05-24 13:00:25 info nikola[]: (v42) Records after filtering: 35
2018-05-24 13:00:25 info nikola[]: (v42) Records filtering took 0.009681 seconds
2018-05-24 13:00:25 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 13:00:25 info nikola[]: (v42) Sending records took 0.083020 seconds
2018-05-24 13:01:01 info /usr/sbin/cron[748]: (root) CMD (majordomo_db.sh genhour)
2018-05-24 13:01:01 info /usr/sbin/cron[747]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:02:01 info /usr/sbin/cron[891]: (root) CMD (nethist_stats.lua)
2018-05-24 13:02:01 info /usr/sbin/cron[890]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:02:09 err turris-firewall-rules[]: (v63) Failed to download https://api.turris.cz/firewall/turris-ipsets.gz.sign
2018-05-24 13:03:01 info /usr/sbin/cron[1008]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:03:01 info /usr/sbin/cron[1009]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:03:59 warning []: Unable to use //tmp//yin2yang.xsl (No such file or directory).
2018-05-24 13:03:59 warning []: YANG format data models will not be available via get-schema.
2018-05-24 13:03:59 warning []: Unable to get tty (Not a tty) to get the client's hostname (session 1191).
2018-05-24 13:04:01 info /usr/sbin/cron[1203]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:04:01 info /usr/sbin/cron[1205]: (root) CMD (nethist_stats.lua)
2018-05-24 13:04:01 info /usr/sbin/cron[1204]: (root) CMD (majordomo_locked_precache.sh)
2018-05-24 13:04:04 info ucollect[4497]: Started task Ping as PID 1326 and fd 24
2018-05-24 13:04:27 info ucollect[4497]: Finished task Ping, success 1
2018-05-24 13:04:27 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 13:05:01 info /usr/sbin/cron[1951]: (root) CMD (/usr/share/firewall/turris)
2018-05-24 13:05:01 info /usr/sbin/cron[1953]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:05:01 info /usr/sbin/cron[1955]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 13:05:01 info /usr/sbin/cron[1954]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 13:05:01 info turris-firewall-rules[]: (v63) IPv4 WAN interface used - 'eth1'
2018-05-24 13:05:01 info turris-firewall-rules[]: (v63) IPv6 WAN interface used - 'lo'
2018-05-24 13:05:01 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 13:05:01 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 13:05:02 info turris-firewall-rules[]: (v63) 3524 ipv4 address(es) and 3 ipv6 address(es) were loaded (c83b72d5b03454292e5000b3967bc350), 0 rule(s) overriden, 0 rule(s) skipped
2018-05-24 13:05:59 info ucollect[4497]: Updating filter addresses from version 50905290 to version 50905330 (epoch 4)
2018-05-24 13:06:01 info /usr/sbin/cron[4219]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:06:01 info /usr/sbin/cron[4221]: (root) CMD (nethist_stats.lua)
2018-05-24 13:06:01 info /usr/sbin/cron[4220]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:06:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905290 to version 50905330 (epoch 4)
2018-05-24 13:06:06 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 13:06:06 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 13:06:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 13:06:33 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 13:06:33 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 13:07:01 info /usr/sbin/cron[6248]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:07:36 err foris-controller[5270]: busybox: applet not found
2018-05-24 13:08:01 info /usr/sbin/cron[8203]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:08:01 info /usr/sbin/cron[8204]: (root) CMD (nethist_stats.lua)
2018-05-24 13:09:01 info /usr/sbin/cron[8986]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:09:01 info /usr/sbin/cron[8987]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:09:54 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.105 c4:3a:be:95:6a:75
2018-05-24 13:09:54 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.105 c4:3a:be:95:6a:75 Sony_Xperia_Z3
2018-05-24 13:10:01 info /usr/sbin/cron[9573]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:10:01 info /usr/sbin/cron[9575]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 13:10:01 info /usr/sbin/cron[9577]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 13:10:01 info /usr/sbin/cron[9576]: (root) CMD (nethist_stats.lua)
2018-05-24 13:11:01 info /usr/sbin/cron[10112]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:11:15 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 13:11:15 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 13:12:01 info /usr/sbin/cron[10357]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:12:01 info /usr/sbin/cron[10359]: (root) CMD (/usr/sbin/logrotate -s /tmp/logrotate.state /etc/logrotate.conf)
2018-05-24 13:12:01 info /usr/sbin/cron[10361]: (root) CMD (nethist_stats.lua)
2018-05-24 13:12:01 info /usr/sbin/cron[10360]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:13:01 info /usr/sbin/cron[10777]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:14:01 info /usr/sbin/cron[11191]: (root) CMD (nethist_stats.lua)
2018-05-24 13:14:01 info /usr/sbin/cron[11190]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:14:31 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 13:14:31 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 13:14:31 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 3 times, suppressed by syslog-ng on Omnia
2018-05-24 13:14:31 warning dhcp_host_domain_ng.py[]: Del_lease, hosname check failed
2018-05-24 13:14:31 info dhcp_host_domain_ng.py[]: DHCP delete hostname [del,Topfield_SRP-2411,192.168.2.111]
2018-05-24 13:14:31 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 13:14:31 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 13:15:01 info /usr/sbin/cron[11495]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:15:01 info /usr/sbin/cron[11498]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:15:01 info /usr/sbin/cron[11502]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 13:15:01 info /usr/sbin/cron[11503]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 13:15:01 info /usr/sbin/cron[11500]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 13:15:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 13:15:23 info nikola[]: (v42) Establishing connection took 0.651757 seconds
2018-05-24 13:15:23 info nikola[]: (v42) Logrotate took 0.004497 seconds
2018-05-24 13:15:23 info nikola[]: (v42) Syslog parsing took 0.054975 seconds
2018-05-24 13:15:24 info nikola[]: (v42) Session init took 0.756606 seconds
2018-05-24 13:15:24 info nikola[]: (v42) Records parsed: 46
2018-05-24 13:15:24 info nikola[]: (v42) Records after filtering: 33
2018-05-24 13:15:24 info nikola[]: (v42) Records filtering took 0.009774 seconds
2018-05-24 13:15:24 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 13:15:24 info nikola[]: (v42) Sending records took 0.088492 seconds
2018-05-24 13:16:01 info /usr/sbin/cron[11852]: (root) CMD (nethist_stats.lua)
2018-05-24 13:16:01 info /usr/sbin/cron[11851]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:16:19 info hostapd[]: wlan0: STA bc:76:5e:28:f9:75 IEEE 802.11: authenticated
2018-05-24 13:16:19 info hostapd[]: wlan0: STA bc:76:5e:28:f9:75 IEEE 802.11: associated (aid 3)
2018-05-24 13:16:19 info hostapd[]: wlan0: STA bc:76:5e:28:f9:75 RADIUS: starting accounting session E18732EF2D55D1BA
2018-05-24 13:16:19 info hostapd[]: wlan0: STA bc:76:5e:28:f9:75 WPA: pairwise key handshake completed (RSN)
2018-05-24 13:16:20 info dnsmasq-dhcp[5601]: DHCPDISCOVER(br-lan) bc:76:5e:28:f9:75
2018-05-24 13:16:20 info dnsmasq-dhcp[5601]: DHCPOFFER(br-lan) 192.168.2.106 bc:76:5e:28:f9:75
2018-05-24 13:16:20 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.106 bc:76:5e:28:f9:75
2018-05-24 13:16:20 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.106 bc:76:5e:28:f9:75 Tablet_Jarda
2018-05-24 13:16:20 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 13:16:20 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 13:16:20 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 5 times, suppressed by syslog-ng on Omnia
2018-05-24 13:16:20 info dhcp_host_domain_ng.py[]: DHCP add new hostname [Tablet_Jarda,192.168.2.106]
2018-05-24 13:16:20 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 13:16:20 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 13:17:01 info /usr/sbin/cron[12061]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:18:01 info /usr/sbin/cron[12357]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:18:01 info /usr/sbin/cron[12358]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:18:01 info /usr/sbin/cron[12359]: (root) CMD (nethist_stats.lua)
2018-05-24 13:19:01 info /usr/sbin/cron[12634]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:20:01 info /usr/sbin/cron[12899]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 13:20:01 info /usr/sbin/cron[12900]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 13:20:01 info /usr/sbin/cron[12897]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:20:01 info /usr/sbin/cron[12904]: (root) CMD (nethist_stats.lua)
2018-05-24 13:20:01 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 13:20:01 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 13:20:07 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 13:20:07 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 13:20:09 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 13:20:09 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 13:21:01 info /usr/sbin/cron[13351]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:21:01 info /usr/sbin/cron[13352]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Global permanent pool: 3092/4096 (18)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Global batch pool: 0/4096 (0)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Global temporary pool: 156/4096 (3)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Buffer pool for uplink: 4/4096 (1)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Config pool: 4094/8192 (137)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Badconf: 48/4096 (1)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Bandwidth: 2744/4096 (6)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Count: 264/4096 (1)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Fake: 189120/217088 (161)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Fake log: 1942/4096 (75)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Flow: 128/4096 (5)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Flow pool: 8984/12288 (186)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Flow conf pool: 841145/884736 (44960)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Fwup: 168/4096 (7)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 1: 0/4096 (0)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 2: 121409/131072 (6504)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Refused: 104/4096 (3)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Refuse pool 1: 0/4096 (0)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Refuse pool 2: 70196/73728 (2983)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Sniff: 44/4096 (3)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Sniffer pool: 0/4096 (0)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats: Spoof: 224/4096 (1)
2018-05-24 13:21:21 info ucollect[4497]: Mempool stats done
2018-05-24 13:21:26 info ucollect[4497]: Sending 56 flows
2018-05-24 13:21:26 info ucollect[4497]: Sending 37 IPv4 refused connections and 0 IPv6 ones
2018-05-24 13:22:01 info /usr/sbin/cron[13781]: (root) CMD (nethist_stats.lua)
2018-05-24 13:22:01 info /usr/sbin/cron[13780]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:23:01 info /usr/sbin/cron[14083]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:24:01 info /usr/sbin/cron[14268]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:24:01 info /usr/sbin/cron[14269]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:24:01 info /usr/sbin/cron[14270]: (root) CMD (nethist_stats.lua)
2018-05-24 13:24:54 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.105 c4:3a:be:95:6a:75
2018-05-24 13:24:54 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.105 c4:3a:be:95:6a:75 Sony_Xperia_Z3
2018-05-24 13:25:01 info /usr/sbin/cron[14477]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:25:01 info /usr/sbin/cron[14478]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 13:25:01 info /usr/sbin/cron[14480]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 13:25:39 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 13:25:39 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 13:25:59 info ucollect[4497]: Updating filter addresses from version 50905330 to version 50905370 (epoch 4)
2018-05-24 13:26:01 info /usr/sbin/cron[14800]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:26:01 info /usr/sbin/cron[14801]: (root) CMD (nethist_stats.lua)
2018-05-24 13:26:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905330 to version 50905370 (epoch 4)
2018-05-24 13:26:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 13:27:01 info /usr/sbin/cron[15122]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:27:01 info /usr/sbin/cron[15121]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:28:01 info /usr/sbin/cron[15461]: (root) CMD (nethist_stats.lua)
2018-05-24 13:28:01 info /usr/sbin/cron[15462]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:29:01 info /usr/sbin/cron[15728]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:30:01 info /usr/sbin/cron[15954]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:30:01 info /usr/sbin/cron[15959]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 13:30:01 info /usr/sbin/cron[15962]: (root) CMD (/usr/bin/get-api-crl)
2018-05-24 13:30:01 info /usr/sbin/cron[15964]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 13:30:01 info /usr/sbin/cron[15963]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:30:01 info /usr/sbin/cron[15958]: (root) CMD (nethist_stats.lua)
2018-05-24 13:30:01 info /usr/sbin/cron[15965]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 13:30:03 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 13:30:44 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.106 bc:76:5e:28:f9:75
2018-05-24 13:30:44 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.106 bc:76:5e:28:f9:75 Tablet_Jarda
2018-05-24 13:30:55 info nikola[]: (v42) Establishing connection took 0.604619 seconds
2018-05-24 13:30:55 info nikola[]: (v42) Logrotate took 0.005275 seconds
2018-05-24 13:30:55 info nikola[]: (v42) Syslog parsing took 0.051856 seconds
2018-05-24 13:30:56 info nikola[]: (v42) Session init took 0.765658 seconds
2018-05-24 13:30:56 info nikola[]: (v42) Records parsed: 52
2018-05-24 13:30:56 info nikola[]: (v42) Records after filtering: 38
2018-05-24 13:30:56 info nikola[]: (v42) Records filtering took 0.010344 seconds
2018-05-24 13:30:56 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 13:30:56 info nikola[]: (v42) Sending records took 0.091387 seconds
2018-05-24 13:31:01 info /usr/sbin/cron[16333]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:32:01 info /usr/sbin/cron[16691]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:32:01 info /usr/sbin/cron[16692]: (root) CMD (nethist_stats.lua)
2018-05-24 13:33:01 info /usr/sbin/cron[16958]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:33:01 info /usr/sbin/cron[16957]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:33:42 info hostapd[]: wlan0: STA c4:3a:be:95:6a:75 IEEE 802.11: disassociated
2018-05-24 13:33:43 info hostapd[]: wlan0: STA c4:3a:be:95:6a:75 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
2018-05-24 13:33:43 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 13:33:43 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 13:34:01 info /usr/sbin/cron[17320]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:34:01 info /usr/sbin/cron[17321]: (root) CMD (nethist_stats.lua)
2018-05-24 13:34:12 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 13:34:12 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 13:35:01 info /usr/sbin/cron[17620]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:35:01 info /usr/sbin/cron[17621]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 13:35:01 info /usr/sbin/cron[17622]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 13:35:02 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 13:35:02 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 13:36:01 info /usr/sbin/cron[18109]: (root) CMD (nethist_stats.lua)
2018-05-24 13:36:01 info /usr/sbin/cron[18108]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:36:01 info /usr/sbin/cron[18110]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:37:01 info /usr/sbin/cron[18524]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:38:01 info /usr/sbin/cron[18857]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:38:01 info /usr/sbin/cron[18858]: (root) CMD (nethist_stats.lua)
2018-05-24 13:38:03 info dnsmasq-dhcp[5601]: DHCPINFORM(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 13:38:03 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 13:39:01 info /usr/sbin/cron[19140]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:39:01 info /usr/sbin/cron[19141]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:40:01 info /usr/sbin/cron[19483]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:40:01 info /usr/sbin/cron[19485]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 13:40:01 info /usr/sbin/cron[19489]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 13:40:01 info /usr/sbin/cron[19487]: (root) CMD (nethist_stats.lua)
2018-05-24 13:40:03 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 13:40:03 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 13:41:01 info /usr/sbin/cron[19896]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:42:01 info /usr/sbin/cron[20193]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:42:01 info /usr/sbin/cron[20194]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:42:01 info /usr/sbin/cron[20195]: (root) CMD (nethist_stats.lua)
2018-05-24 13:43:01 info /usr/sbin/cron[20622]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:44:01 info /usr/sbin/cron[21089]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:44:01 info /usr/sbin/cron[21090]: (root) CMD (nethist_stats.lua)
2018-05-24 13:45:01 info /usr/sbin/cron[21452]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:45:01 info /usr/sbin/cron[21455]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:45:01 info /usr/sbin/cron[21457]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 13:45:01 info /usr/sbin/cron[21459]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 13:45:01 info /usr/sbin/cron[21456]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 13:45:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 13:45:08 info nikola[]: (v42) Establishing connection took 0.631314 seconds
2018-05-24 13:45:08 info nikola[]: (v42) Logrotate took 0.004643 seconds
2018-05-24 13:45:08 info nikola[]: (v42) Syslog parsing took 0.043448 seconds
2018-05-24 13:45:09 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.106 bc:76:5e:28:f9:75
2018-05-24 13:45:09 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.106 bc:76:5e:28:f9:75 Tablet_Jarda
2018-05-24 13:45:09 info nikola[]: (v42) Session init took 0.771741 seconds
2018-05-24 13:45:09 info nikola[]: (v42) Records parsed: 30
2018-05-24 13:45:09 info nikola[]: (v42) Records after filtering: 19
2018-05-24 13:45:09 info nikola[]: (v42) Records filtering took 0.007887 seconds
2018-05-24 13:45:09 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 13:45:09 info nikola[]: (v42) Sending records took 0.087801 seconds
2018-05-24 13:45:59 info ucollect[4497]: Updating filter addresses from version 50905370 to version 50905410 (epoch 4)
2018-05-24 13:46:01 info /usr/sbin/cron[21794]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:46:01 info /usr/sbin/cron[21795]: (root) CMD (nethist_stats.lua)
2018-05-24 13:46:03 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905370 to version 50905410 (epoch 4)
2018-05-24 13:46:08 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 13:47:01 info /usr/sbin/cron[22103]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:47:42 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 13:47:42 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 13:48:01 info /usr/sbin/cron[22323]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:48:01 info /usr/sbin/cron[22324]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:48:01 info /usr/sbin/cron[22325]: (root) CMD (nethist_stats.lua)
2018-05-24 13:48:09 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 13:48:09 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 13:49:01 info /usr/sbin/cron[22744]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:50:01 info /usr/sbin/cron[22849]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:50:01 info /usr/sbin/cron[22853]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 13:50:01 info /usr/sbin/cron[22851]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 13:50:02 info /usr/sbin/cron[22852]: (root) CMD (nethist_stats.lua)
2018-05-24 13:50:02 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 13:50:02 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 13:51:01 info /usr/sbin/cron[22978]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:51:01 info /usr/sbin/cron[22979]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:51:26 info ucollect[4497]: Sending 67 flows
2018-05-24 13:51:26 info ucollect[4497]: Sending 39 IPv4 refused connections and 0 IPv6 ones
2018-05-24 13:52:01 info /usr/sbin/cron[23118]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:52:01 info /usr/sbin/cron[23119]: (root) CMD (nethist_stats.lua)
2018-05-24 13:53:01 info /usr/sbin/cron[23221]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:54:01 info /usr/sbin/cron[23323]: (root) CMD (nethist_stats.lua)
2018-05-24 13:54:01 info /usr/sbin/cron[23322]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:54:01 info /usr/sbin/cron[23324]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:54:27 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 13:54:27 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 13:54:55 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 13:54:55 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 13:54:55 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 3 times, suppressed by syslog-ng on Omnia
2018-05-24 13:54:55 warning dhcp_host_domain_ng.py[]: Del_lease, hosname check failed
2018-05-24 13:54:55 info dhcp_host_domain_ng.py[]: DHCP delete hostname [del,Sony_Xperia_Z3,192.168.2.105]
2018-05-24 13:54:55 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 13:54:55 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 13:55:01 info /usr/sbin/cron[23472]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 13:55:01 info /usr/sbin/cron[23471]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:55:01 info /usr/sbin/cron[23474]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 13:56:01 info /usr/sbin/cron[23600]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:56:01 info /usr/sbin/cron[23601]: (root) CMD (nethist_stats.lua)
2018-05-24 13:56:37 info ucollect[4497]: Started task Ping as PID 23658 and fd 24
2018-05-24 13:56:41 info ucollect[4497]: Finished task Ping, success 1
2018-05-24 13:56:41 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 13:57:01 info /usr/sbin/cron[23721]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:57:01 info /usr/sbin/cron[23720]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 13:58:01 info /usr/sbin/cron[23856]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 13:58:01 info /usr/sbin/cron[23857]: (root) CMD (nethist_stats.lua)
2018-05-24 13:59:01 info /usr/sbin/cron[23961]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:00:01 info /usr/sbin/cron[24069]: (root) CMD (/usr/bin/get-api-crl)
2018-05-24 14:00:01 info /usr/sbin/cron[24064]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:00:01 info /usr/sbin/cron[24080]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 14:00:01 info /usr/sbin/cron[24075]: (root) CMD (/usr/share/server-uplink/registration_code.sh)
2018-05-24 14:00:01 info /usr/sbin/cron[24078]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:00:01 info /usr/sbin/cron[24081]: (root) CMD (nethist_stats.lua)
2018-05-24 14:00:01 info /usr/sbin/cron[24079]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 14:00:01 info /usr/sbin/cron[24074]: (root) CMD (/usr/share/server-uplink/contract_valid.sh)
2018-05-24 14:00:01 info /usr/sbin/cron[24089]: (root) CMD (netmetr --autostart --dwlhist --rwait 1800 &)
2018-05-24 14:00:01 info /usr/sbin/cron[24090]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 14:00:01 info /usr/sbin/cron[24092]: (root) CMD (/usr/share/firewall/turris-download)
2018-05-24 14:00:01 err server_uplink[]: Failed to download contract status
2018-05-24 14:00:03 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 14:00:15 info nikola[]: (v42) Establishing connection took 0.611042 seconds
2018-05-24 14:00:15 info nikola[]: (v42) Logrotate took 0.004566 seconds
2018-05-24 14:00:15 info nikola[]: (v42) Syslog parsing took 0.060296 seconds
2018-05-24 14:00:16 info nikola[]: (v42) Session init took 0.765119 seconds
2018-05-24 14:00:16 info nikola[]: (v42) Records parsed: 61
2018-05-24 14:00:16 info nikola[]: (v42) Records after filtering: 46
2018-05-24 14:00:16 info nikola[]: (v42) Records filtering took 0.011155 seconds
2018-05-24 14:00:16 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 14:00:16 info nikola[]: (v42) Sending records took 0.117451 seconds
2018-05-24 14:01:01 info /usr/sbin/cron[24289]: (root) CMD (majordomo_db.sh genhour)
2018-05-24 14:01:01 info /usr/sbin/cron[24288]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:01:30 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 14:01:30 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 14:01:30 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 14:01:30 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 14:02:01 err server_uplink[]: Failed to get registration code
2018-05-24 14:02:01 info /usr/sbin/cron[24433]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:02:01 info /usr/sbin/cron[24434]: (root) CMD (nethist_stats.lua)
2018-05-24 14:02:09 err turris-firewall-rules[]: (v63) Failed to download https://api.turris.cz/firewall/turris-ipsets.gz.sign
2018-05-24 14:03:01 info /usr/sbin/cron[24547]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:03:01 info /usr/sbin/cron[24546]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:04:01 info /usr/sbin/cron[24686]: (root) CMD (nethist_stats.lua)
2018-05-24 14:04:01 info /usr/sbin/cron[24688]: (root) CMD (majordomo_locked_precache.sh)
2018-05-24 14:04:01 info /usr/sbin/cron[24687]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:04:13 info hostapd[]: wlan0: STA c4:3a:be:95:6a:75 IEEE 802.11: authenticated
2018-05-24 14:04:13 info hostapd[]: wlan0: STA c4:3a:be:95:6a:75 IEEE 802.11: associated (aid 1)
2018-05-24 14:04:13 info hostapd[]: wlan0: STA c4:3a:be:95:6a:75 RADIUS: starting accounting session 112ED5EB6079CA5E
2018-05-24 14:04:13 info hostapd[]: wlan0: STA c4:3a:be:95:6a:75 WPA: pairwise key handshake completed (RSN)
2018-05-24 14:04:13 info dnsmasq-dhcp[5601]: DHCPDISCOVER(br-lan) c4:3a:be:95:6a:75
2018-05-24 14:04:13 info dnsmasq-dhcp[5601]: DHCPOFFER(br-lan) 192.168.2.105 c4:3a:be:95:6a:75
2018-05-24 14:04:13 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.105 c4:3a:be:95:6a:75
2018-05-24 14:04:13 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.105 c4:3a:be:95:6a:75 Sony_Xperia_Z3
2018-05-24 14:04:14 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 14:04:14 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 14:04:14 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 5 times, suppressed by syslog-ng on Omnia
2018-05-24 14:04:14 info dhcp_host_domain_ng.py[]: DHCP add new hostname [Sony_Xperia_Z3,192.168.2.105]
2018-05-24 14:04:14 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 14:04:14 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 14:05:01 info /usr/sbin/cron[25319]: (root) CMD (/usr/share/firewall/turris)
2018-05-24 14:05:01 info /usr/sbin/cron[25321]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:05:01 info /usr/sbin/cron[25323]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 14:05:01 info /usr/sbin/cron[25322]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 14:05:01 info turris-firewall-rules[]: (v63) IPv4 WAN interface used - 'eth1'
2018-05-24 14:05:01 info turris-firewall-rules[]: (v63) IPv6 WAN interface used - 'lo'
2018-05-24 14:05:02 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 14:05:02 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 14:05:02 info turris-firewall-rules[]: (v63) 3524 ipv4 address(es) and 3 ipv6 address(es) were loaded (c83b72d5b03454292e5000b3967bc350), 0 rule(s) overriden, 0 rule(s) skipped
2018-05-24 14:05:59 info ucollect[4497]: Updating filter addresses from version 50905410 to version 50905450 (epoch 4)
2018-05-24 14:06:01 info /usr/sbin/cron[26185]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:06:01 info /usr/sbin/cron[26186]: (root) CMD (nethist_stats.lua)
2018-05-24 14:06:01 info /usr/sbin/cron[26184]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:06:37 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905410 to version 50905450 (epoch 4)
2018-05-24 14:06:42 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 14:07:01 info /usr/sbin/cron[26578]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:08:01 info /usr/sbin/cron[26774]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:08:01 info /usr/sbin/cron[26775]: (root) CMD (nethist_stats.lua)
2018-05-24 14:08:51 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 14:08:51 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 14:09:01 info /usr/sbin/cron[27016]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:09:01 info /usr/sbin/cron[27017]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:10:01 info /usr/sbin/cron[27296]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:10:01 info /usr/sbin/cron[27299]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 14:10:01 info /usr/sbin/cron[27298]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 14:10:01 info /usr/sbin/cron[27300]: (root) CMD (nethist_stats.lua)
2018-05-24 14:11:01 info /usr/sbin/cron[27514]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:12:01 info /usr/sbin/cron[27777]: (root) CMD (nethist_stats.lua)
2018-05-24 14:12:01 info /usr/sbin/cron[27776]: (root) CMD (/usr/sbin/logrotate -s /tmp/logrotate.state /etc/logrotate.conf)
2018-05-24 14:12:01 info /usr/sbin/cron[27774]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:12:01 info /usr/sbin/cron[27781]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:13:01 info /usr/sbin/cron[28240]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:14:01 info /usr/sbin/cron[28619]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:14:01 info /usr/sbin/cron[28620]: (root) CMD (nethist_stats.lua)
2018-05-24 14:15:01 info /usr/sbin/cron[28890]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:15:01 info /usr/sbin/cron[28893]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:15:01 info /usr/sbin/cron[28896]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 14:15:01 info /usr/sbin/cron[28894]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 14:15:01 info /usr/sbin/cron[28895]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 14:15:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 14:15:10 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 14:15:10 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 14:15:10 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 3 times, suppressed by syslog-ng on Omnia
2018-05-24 14:15:10 warning dhcp_host_domain_ng.py[]: Del_lease, hosname check failed
2018-05-24 14:15:10 info dhcp_host_domain_ng.py[]: DHCP delete hostname [del,Tablet_Jarda,192.168.2.106]
2018-05-24 14:15:10 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 14:15:10 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 14:15:18 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 14:15:18 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 14:15:23 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 14:15:23 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 14:15:33 info nikola[]: (v42) Establishing connection took 0.610282 seconds
2018-05-24 14:15:33 info nikola[]: (v42) Logrotate took 0.004934 seconds
2018-05-24 14:15:33 info nikola[]: (v42) Syslog parsing took 0.048096 seconds
2018-05-24 14:15:34 info nikola[]: (v42) Session init took 0.768625 seconds
2018-05-24 14:15:34 info nikola[]: (v42) Records parsed: 42
2018-05-24 14:15:34 info nikola[]: (v42) Records after filtering: 31
2018-05-24 14:15:34 info nikola[]: (v42) Records filtering took 0.009480 seconds
2018-05-24 14:15:34 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 14:15:34 info nikola[]: (v42) Sending records took 0.093164 seconds
2018-05-24 14:16:01 info /usr/sbin/cron[29234]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:16:01 info /usr/sbin/cron[29235]: (root) CMD (nethist_stats.lua)
2018-05-24 14:17:01 info /usr/sbin/cron[29447]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:18:01 info /usr/sbin/cron[29766]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:18:01 info /usr/sbin/cron[29767]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:18:01 info /usr/sbin/cron[29771]: (root) CMD (nethist_stats.lua)
2018-05-24 14:19:01 info /usr/sbin/cron[30062]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:19:14 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.105 c4:3a:be:95:6a:75
2018-05-24 14:19:14 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.105 c4:3a:be:95:6a:75 Sony_Xperia_Z3
2018-05-24 14:20:01 info /usr/sbin/cron[30281]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:20:01 info /usr/sbin/cron[30283]: (root) CMD (nethist_stats.lua)
2018-05-24 14:20:01 info /usr/sbin/cron[30282]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 14:20:01 info /usr/sbin/cron[30284]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 14:20:02 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 14:20:02 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 14:21:01 info /usr/sbin/cron[30795]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:21:01 info /usr/sbin/cron[30796]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Global permanent pool: 3092/4096 (18)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Global batch pool: 0/4096 (0)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Global temporary pool: 156/4096 (3)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Buffer pool for uplink: 4/4096 (1)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Config pool: 4094/8192 (137)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Badconf: 48/4096 (1)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Bandwidth: 2744/4096 (6)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Count: 264/4096 (1)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Fake: 189120/217088 (161)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Fake log: 44/4096 (1)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Flow: 128/4096 (5)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Flow pool: 7862/8192 (164)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Flow conf pool: 841982/884736 (45005)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Fwup: 168/4096 (7)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 1: 0/4096 (0)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 2: 121774/131072 (6523)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Refused: 104/4096 (3)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Refuse pool 1: 0/4096 (0)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Refuse pool 2: 55668/57344 (2382)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Sniff: 44/4096 (3)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Sniffer pool: 0/4096 (0)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats: Spoof: 224/4096 (1)
2018-05-24 14:21:21 info ucollect[4497]: Mempool stats done
2018-05-24 14:21:26 info ucollect[4497]: Sending 48 flows
2018-05-24 14:21:26 info ucollect[4497]: Sending 30 IPv4 refused connections and 0 IPv6 ones
2018-05-24 14:22:01 info /usr/sbin/cron[31278]: (root) CMD (nethist_stats.lua)
2018-05-24 14:22:01 info /usr/sbin/cron[31277]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:23:01 info /usr/sbin/cron[31479]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:23:16 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 14:23:16 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 14:24:00 info hostapd[]: wlan0: STA bc:76:5e:28:f9:75 IEEE 802.11: authenticated
2018-05-24 14:24:00 info hostapd[]: wlan0: STA bc:76:5e:28:f9:75 IEEE 802.11: associated (aid 3)
2018-05-24 14:24:00 info hostapd[]: wlan0: STA bc:76:5e:28:f9:75 RADIUS: starting accounting session F4F8E043C500F549
2018-05-24 14:24:00 info hostapd[]: wlan0: STA bc:76:5e:28:f9:75 WPA: pairwise key handshake completed (RSN)
2018-05-24 14:24:00 info dnsmasq-dhcp[5601]: DHCPDISCOVER(br-lan) bc:76:5e:28:f9:75
2018-05-24 14:24:00 info dnsmasq-dhcp[5601]: DHCPOFFER(br-lan) 192.168.2.106 bc:76:5e:28:f9:75
2018-05-24 14:24:00 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.106 bc:76:5e:28:f9:75
2018-05-24 14:24:00 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.106 bc:76:5e:28:f9:75 Tablet_Jarda
2018-05-24 14:24:01 info /usr/sbin/cron[31662]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:24:01 info /usr/sbin/cron[31661]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:24:01 info /usr/sbin/cron[31665]: (root) CMD (nethist_stats.lua)
2018-05-24 14:24:01 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 14:24:01 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 14:24:01 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 5 times, suppressed by syslog-ng on Omnia
2018-05-24 14:24:01 info dhcp_host_domain_ng.py[]: DHCP add new hostname [Tablet_Jarda,192.168.2.106]
2018-05-24 14:24:01 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 14:24:01 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 14:25:01 info /usr/sbin/cron[31960]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:25:01 info /usr/sbin/cron[31961]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 14:25:01 info /usr/sbin/cron[31959]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 14:26:00 info ucollect[4497]: Updating filter addresses from version 50905450 to version 50905491 (epoch 4)
2018-05-24 14:26:01 info /usr/sbin/cron[32269]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:26:01 info /usr/sbin/cron[32270]: (root) CMD (nethist_stats.lua)
2018-05-24 14:26:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905450 to version 50905491 (epoch 4)
2018-05-24 14:26:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 14:27:01 info /usr/sbin/cron[32602]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:27:01 info /usr/sbin/cron[32603]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:28:01 info /usr/sbin/cron[458]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:28:01 info /usr/sbin/cron[459]: (root) CMD (nethist_stats.lua)
2018-05-24 14:28:54 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 14:28:54 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 14:29:01 info /usr/sbin/cron[747]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:29:15 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 14:29:15 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 14:30:01 info /usr/sbin/cron[995]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:30:01 info /usr/sbin/cron[996]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 14:30:01 info /usr/sbin/cron[997]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:30:01 info /usr/sbin/cron[990]: (root) CMD (/usr/bin/get-api-crl)
2018-05-24 14:30:01 info /usr/sbin/cron[1000]: (root) CMD (nethist_stats.lua)
2018-05-24 14:30:01 info /usr/sbin/cron[999]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 14:30:01 info /usr/sbin/cron[1002]: (root) CMD (/usr/share/haas/register.sh)
2018-05-24 14:30:01 info /usr/sbin/cron[1004]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 14:30:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 14:30:34 info nikola[]: (v42) Establishing connection took 0.616825 seconds
2018-05-24 14:30:34 info nikola[]: (v42) Logrotate took 0.004778 seconds
2018-05-24 14:30:34 info nikola[]: (v42) Syslog parsing took 0.054340 seconds
2018-05-24 14:30:35 info nikola[]: (v42) Session init took 0.767478 seconds
2018-05-24 14:30:35 info nikola[]: (v42) Records parsed: 46
2018-05-24 14:30:35 info nikola[]: (v42) Records after filtering: 34
2018-05-24 14:30:35 info nikola[]: (v42) Records filtering took 0.009325 seconds
2018-05-24 14:30:35 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 14:30:35 info nikola[]: (v42) Sending records took 0.095951 seconds
2018-05-24 14:31:01 info /usr/sbin/cron[1449]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:32:01 info /usr/sbin/cron[1701]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:32:01 info /usr/sbin/cron[1702]: (root) CMD (nethist_stats.lua)
2018-05-24 14:32:52 info hostapd[]: wlan0: STA c4:3a:be:95:6a:75 IEEE 802.11: disassociated
2018-05-24 14:32:53 info hostapd[]: wlan0: STA c4:3a:be:95:6a:75 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
2018-05-24 14:33:01 info /usr/sbin/cron[2109]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:33:01 info /usr/sbin/cron[2108]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:34:01 info /usr/sbin/cron[2409]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:34:01 info /usr/sbin/cron[2408]: (root) CMD (nethist_stats.lua)
2018-05-24 14:35:01 info /usr/sbin/cron[2804]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:35:01 info /usr/sbin/cron[2806]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 14:35:01 info /usr/sbin/cron[2805]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 14:35:02 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 14:35:02 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 14:36:01 info /usr/sbin/cron[3328]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:36:01 info /usr/sbin/cron[3329]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:36:01 info /usr/sbin/cron[3330]: (root) CMD (nethist_stats.lua)
2018-05-24 14:37:01 info /usr/sbin/cron[3620]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:37:40 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 14:37:40 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 14:38:01 info /usr/sbin/cron[3886]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:38:01 info /usr/sbin/cron[3887]: (root) CMD (nethist_stats.lua)
2018-05-24 14:38:02 info dnsmasq-dhcp[5601]: DHCPINFORM(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 14:38:02 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 14:38:25 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.106 bc:76:5e:28:f9:75
2018-05-24 14:38:25 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.106 bc:76:5e:28:f9:75 Tablet_Jarda
2018-05-24 14:39:01 info /usr/sbin/cron[4300]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:39:01 info /usr/sbin/cron[4301]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:40:01 info /usr/sbin/cron[4633]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:40:01 info /usr/sbin/cron[4635]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 14:40:01 info /usr/sbin/cron[4636]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 14:40:01 info /usr/sbin/cron[4638]: (root) CMD (nethist_stats.lua)
2018-05-24 14:41:01 info /usr/sbin/cron[5020]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:42:01 info /usr/sbin/cron[5401]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:42:01 info /usr/sbin/cron[5402]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:42:01 info /usr/sbin/cron[5405]: (root) CMD (nethist_stats.lua)
2018-05-24 14:42:35 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 14:42:35 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 14:42:37 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 14:42:37 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 14:43:01 info /usr/sbin/cron[5955]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:44:01 info /usr/sbin/cron[6391]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:44:01 info /usr/sbin/cron[6392]: (root) CMD (nethist_stats.lua)
2018-05-24 14:45:01 info /usr/sbin/cron[6634]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:45:01 info /usr/sbin/cron[6637]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:45:01 info /usr/sbin/cron[6638]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 14:45:01 info /usr/sbin/cron[6641]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 14:45:01 info /usr/sbin/cron[6642]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 14:45:03 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 14:45:46 info nikola[]: (v42) Establishing connection took 0.645660 seconds
2018-05-24 14:45:46 info nikola[]: (v42) Logrotate took 0.004645 seconds
2018-05-24 14:45:46 info nikola[]: (v42) Syslog parsing took 0.051064 seconds
2018-05-24 14:45:47 info nikola[]: (v42) Session init took 0.770617 seconds
2018-05-24 14:45:47 info nikola[]: (v42) Records parsed: 44
2018-05-24 14:45:47 info nikola[]: (v42) Records after filtering: 30
2018-05-24 14:45:47 info nikola[]: (v42) Records filtering took 0.010194 seconds
2018-05-24 14:45:47 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 14:45:47 info nikola[]: (v42) Sending records took 0.084462 seconds
2018-05-24 14:45:59 info ucollect[4497]: Updating filter addresses from version 50905491 to version 50905531 (epoch 4)
2018-05-24 14:46:01 info /usr/sbin/cron[7014]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:46:01 info /usr/sbin/cron[7015]: (root) CMD (nethist_stats.lua)
2018-05-24 14:46:03 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905491 to version 50905531 (epoch 4)
2018-05-24 14:46:08 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 14:47:01 info /usr/sbin/cron[7256]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:48:01 info /usr/sbin/cron[7633]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:48:01 info /usr/sbin/cron[7634]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:48:01 info /usr/sbin/cron[7635]: (root) CMD (nethist_stats.lua)
2018-05-24 14:49:01 info /usr/sbin/cron[7985]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:49:15 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 14:49:15 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 14:49:15 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 3 times, suppressed by syslog-ng on Omnia
2018-05-24 14:49:15 warning dhcp_host_domain_ng.py[]: Del_lease, hosname check failed
2018-05-24 14:49:15 info dhcp_host_domain_ng.py[]: DHCP delete hostname [del,Sony_Xperia_Z3,192.168.2.105]
2018-05-24 14:49:15 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 14:49:15 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 14:50:01 info /usr/sbin/cron[8095]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:50:01 info /usr/sbin/cron[8097]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 14:50:01 info /usr/sbin/cron[8100]: (root) CMD (nethist_stats.lua)
2018-05-24 14:50:01 info /usr/sbin/cron[8101]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 14:50:02 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 14:50:02 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 14:50:18 info hostapd[]: wlan0: STA c4:3a:be:95:6a:75 IEEE 802.11: authenticated
2018-05-24 14:50:18 info hostapd[]: wlan0: STA c4:3a:be:95:6a:75 IEEE 802.11: associated (aid 1)
2018-05-24 14:50:18 info hostapd[]: wlan0: STA c4:3a:be:95:6a:75 RADIUS: starting accounting session 7EE73C4AE606E163
2018-05-24 14:50:18 info hostapd[]: wlan0: STA c4:3a:be:95:6a:75 WPA: pairwise key handshake completed (RSN)
2018-05-24 14:50:18 info dnsmasq-dhcp[5601]: DHCPDISCOVER(br-lan) c4:3a:be:95:6a:75
2018-05-24 14:50:18 info dnsmasq-dhcp[5601]: DHCPOFFER(br-lan) 192.168.2.105 c4:3a:be:95:6a:75
2018-05-24 14:50:18 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.105 c4:3a:be:95:6a:75
2018-05-24 14:50:18 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.105 c4:3a:be:95:6a:75 Sony_Xperia_Z3
2018-05-24 14:50:19 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 14:50:19 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 14:50:19 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 5 times, suppressed by syslog-ng on Omnia
2018-05-24 14:50:19 info dhcp_host_domain_ng.py[]: DHCP add new hostname [Sony_Xperia_Z3,192.168.2.105]
2018-05-24 14:50:19 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 14:50:19 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 14:51:01 info /usr/sbin/cron[8232]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:51:01 info /usr/sbin/cron[8233]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:51:26 info ucollect[4497]: Sending 64 flows
2018-05-24 14:51:26 info ucollect[4497]: Sending 41 IPv4 refused connections and 0 IPv6 ones
2018-05-24 14:52:01 info /usr/sbin/cron[8371]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:52:01 info /usr/sbin/cron[8372]: (root) CMD (nethist_stats.lua)
2018-05-24 14:52:05 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 14:52:05 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 14:53:01 info /usr/sbin/cron[8473]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:54:01 info /usr/sbin/cron[8575]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:54:01 info /usr/sbin/cron[8576]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:54:01 info /usr/sbin/cron[8577]: (root) CMD (nethist_stats.lua)
2018-05-24 14:55:01 info /usr/sbin/cron[8716]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:55:01 info /usr/sbin/cron[8715]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 14:55:01 info /usr/sbin/cron[8717]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 14:56:01 info /usr/sbin/cron[8844]: (root) CMD (nethist_stats.lua)
2018-05-24 14:56:01 info /usr/sbin/cron[8845]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:56:07 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 14:56:07 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 14:56:37 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 14:56:37 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 14:57:01 info /usr/sbin/cron[8947]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:57:01 info /usr/sbin/cron[8946]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 14:58:01 info /usr/sbin/cron[9103]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 14:58:01 info /usr/sbin/cron[9104]: (root) CMD (nethist_stats.lua)
2018-05-24 14:59:01 info /usr/sbin/cron[9227]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:00:01 info /usr/sbin/cron[9355]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:00:01 info /usr/sbin/cron[9361]: (root) CMD (/usr/share/server-uplink/contract_valid.sh)
2018-05-24 15:00:01 info /usr/sbin/cron[9362]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 15:00:01 info /usr/sbin/cron[9352]: (root) CMD (/usr/share/firewall/turris-download)
2018-05-24 15:00:01 info /usr/sbin/cron[9366]: (root) CMD (nethist_stats.lua)
2018-05-24 15:00:01 info /usr/sbin/cron[9365]: (root) CMD (/usr/share/server-uplink/registration_code.sh)
2018-05-24 15:00:01 info /usr/sbin/cron[9368]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:00:01 info /usr/sbin/cron[9369]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 15:00:01 info /usr/sbin/cron[9363]: (root) CMD (/usr/bin/get-api-crl)
2018-05-24 15:00:01 info /usr/sbin/cron[9374]: (root) CMD (netmetr --autostart --dwlhist --rwait 1800 &)
2018-05-24 15:00:01 info /usr/sbin/cron[9375]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 15:00:01 err server_uplink[]: Failed to download contract status
2018-05-24 15:00:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 15:00:18 err server_uplink[]: Failed to get registration code
2018-05-24 15:00:35 info nikola[]: (v42) Establishing connection took 0.602986 seconds
2018-05-24 15:00:35 info nikola[]: (v42) Logrotate took 0.005828 seconds
2018-05-24 15:00:35 info nikola[]: (v42) Syslog parsing took 0.052661 seconds
2018-05-24 15:00:36 info nikola[]: (v42) Session init took 0.756900 seconds
2018-05-24 15:00:36 info nikola[]: (v42) Records parsed: 48
2018-05-24 15:00:36 info nikola[]: (v42) Records after filtering: 33
2018-05-24 15:00:36 info nikola[]: (v42) Records filtering took 0.009809 seconds
2018-05-24 15:00:36 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 15:00:36 info nikola[]: (v42) Sending records took 0.084488 seconds
2018-05-24 15:01:01 info /usr/sbin/cron[9614]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:01:01 info /usr/sbin/cron[9615]: (root) CMD (majordomo_db.sh genhour)
2018-05-24 15:02:01 info /usr/sbin/cron[9774]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:02:01 info /usr/sbin/cron[9776]: (root) CMD (nethist_stats.lua)
2018-05-24 15:03:01 info /usr/sbin/cron[9879]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:03:01 info /usr/sbin/cron[9878]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:04:01 info /usr/sbin/cron[10017]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:04:01 info /usr/sbin/cron[10020]: (root) CMD (nethist_stats.lua)
2018-05-24 15:04:01 info /usr/sbin/cron[10018]: (root) CMD (majordomo_locked_precache.sh)
2018-05-24 15:05:01 info /usr/sbin/cron[10644]: (root) CMD (/usr/share/firewall/turris)
2018-05-24 15:05:01 info /usr/sbin/cron[10646]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:05:01 info /usr/sbin/cron[10647]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 15:05:01 info /usr/sbin/cron[10648]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 15:05:01 info turris-firewall-rules[]: (v63) IPv4 WAN interface used - 'eth1'
2018-05-24 15:05:01 info turris-firewall-rules[]: (v63) IPv6 WAN interface used - 'lo'
2018-05-24 15:05:02 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 15:05:02 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 15:05:02 info turris-firewall-rules[]: (v63) 3524 ipv4 address(es) and 3 ipv6 address(es) were loaded (c83b72d5b03454292e5000b3967bc350), 0 rule(s) overriden, 0 rule(s) skipped
2018-05-24 15:05:19 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.105 c4:3a:be:95:6a:75
2018-05-24 15:05:19 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.105 c4:3a:be:95:6a:75 Sony_Xperia_Z3
2018-05-24 15:05:49 info hostapd[]: wlan0: STA c4:3a:be:95:6a:75 IEEE 802.11: disassociated
2018-05-24 15:05:50 info hostapd[]: wlan0: STA c4:3a:be:95:6a:75 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
2018-05-24 15:05:59 info ucollect[4497]: Updating filter addresses from version 50905531 to version 50905570 (epoch 4)
2018-05-24 15:06:01 info /usr/sbin/cron[11662]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:06:01 info /usr/sbin/cron[11663]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:06:01 info /usr/sbin/cron[11665]: (root) CMD (nethist_stats.lua)
2018-05-24 15:06:30 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 15:06:30 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 15:07:01 info /usr/sbin/cron[11902]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:08:01 info /usr/sbin/cron[12099]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:08:01 info /usr/sbin/cron[12100]: (root) CMD (nethist_stats.lua)
2018-05-24 15:08:26 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 15:08:26 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 15:08:26 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 3 times, suppressed by syslog-ng on Omnia
2018-05-24 15:08:26 warning dhcp_host_domain_ng.py[]: Del_lease, hosname check failed
2018-05-24 15:08:26 info dhcp_host_domain_ng.py[]: DHCP delete hostname [del,Tablet_Jarda,192.168.2.106]
2018-05-24 15:08:26 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 15:08:26 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 15:09:01 info /usr/sbin/cron[12349]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:09:01 info /usr/sbin/cron[12350]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:10:01 info /usr/sbin/cron[12631]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:10:01 info /usr/sbin/cron[12630]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 15:10:01 info /usr/sbin/cron[12632]: (root) CMD (nethist_stats.lua)
2018-05-24 15:10:01 info /usr/sbin/cron[12636]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 15:10:07 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 15:10:07 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 15:10:40 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 15:10:40 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 15:11:01 info /usr/sbin/cron[12851]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:12:01 info /usr/sbin/cron[13210]: (root) CMD (/usr/sbin/logrotate -s /tmp/logrotate.state /etc/logrotate.conf)
2018-05-24 15:12:01 info /usr/sbin/cron[13211]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:12:01 info /usr/sbin/cron[13212]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:12:01 info /usr/sbin/cron[13218]: (root) CMD (nethist_stats.lua)
2018-05-24 15:13:01 info /usr/sbin/cron[13572]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:14:01 info /usr/sbin/cron[13952]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:14:01 info /usr/sbin/cron[13954]: (root) CMD (nethist_stats.lua)
2018-05-24 15:15:01 info /usr/sbin/cron[14232]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:15:01 info /usr/sbin/cron[14235]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:15:01 info /usr/sbin/cron[14237]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 15:15:01 info /usr/sbin/cron[14240]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 15:15:01 info /usr/sbin/cron[14241]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 15:15:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 15:15:27 info nikola[]: (v42) Establishing connection took 0.649239 seconds
2018-05-24 15:15:27 info nikola[]: (v42) Logrotate took 0.005569 seconds
2018-05-24 15:15:28 info nikola[]: (v42) Syslog parsing took 0.049840 seconds
2018-05-24 15:15:28 info nikola[]: (v42) Session init took 0.797318 seconds
2018-05-24 15:15:28 info nikola[]: (v42) Records parsed: 36
2018-05-24 15:15:28 info nikola[]: (v42) Records after filtering: 24
2018-05-24 15:15:28 info nikola[]: (v42) Records filtering took 0.008919 seconds
2018-05-24 15:15:28 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 15:15:28 info nikola[]: (v42) Sending records took 0.093213 seconds
2018-05-24 15:16:01 info /usr/sbin/cron[14562]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:16:01 info /usr/sbin/cron[14564]: (root) CMD (nethist_stats.lua)
2018-05-24 15:17:01 info /usr/sbin/cron[14773]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:18:01 info /usr/sbin/cron[15092]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:18:01 info /usr/sbin/cron[15093]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:18:01 info /usr/sbin/cron[15095]: (root) CMD (nethist_stats.lua)
2018-05-24 15:19:01 info /usr/sbin/cron[15408]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:20:01 info /usr/sbin/cron[15640]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:20:01 info /usr/sbin/cron[15642]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 15:20:01 info /usr/sbin/cron[15646]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 15:20:01 info /usr/sbin/cron[15647]: (root) CMD (nethist_stats.lua)
2018-05-24 15:20:02 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 15:20:02 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 15:20:54 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 15:20:54 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 15:21:01 info /usr/sbin/cron[16138]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:21:01 info /usr/sbin/cron[16137]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Global permanent pool: 3092/4096 (18)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Global batch pool: 0/4096 (0)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Global temporary pool: 156/4096 (3)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Buffer pool for uplink: 4/4096 (1)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Config pool: 4094/8192 (137)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Badconf: 48/4096 (1)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Bandwidth: 2744/4096 (6)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Count: 264/4096 (1)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Fake: 189120/217088 (161)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Fake log: 1697/4096 (64)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Flow: 128/4096 (5)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Flow pool: 15793/16384 (327)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Flow conf pool: 842878/884736 (45053)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Fwup: 168/4096 (7)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 1: 0/4096 (0)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 2: 121910/131072 (6531)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Refused: 104/4096 (3)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Refuse pool 1: 0/4096 (0)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Refuse pool 2: 55629/57344 (2379)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Sniff: 44/4096 (3)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Sniffer pool: 0/4096 (0)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats: Spoof: 224/4096 (1)
2018-05-24 15:21:21 info ucollect[4497]: Mempool stats done
2018-05-24 15:21:26 info ucollect[4497]: Sending 102 flows
2018-05-24 15:21:26 info ucollect[4497]: Sending 38 IPv4 refused connections and 0 IPv6 ones
2018-05-24 15:22:01 info /usr/sbin/cron[16629]: (root) CMD (nethist_stats.lua)
2018-05-24 15:22:01 info /usr/sbin/cron[16628]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:23:01 info /usr/sbin/cron[16823]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:23:16 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 15:23:16 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 15:24:01 info /usr/sbin/cron[17004]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:24:01 info /usr/sbin/cron[17006]: (root) CMD (nethist_stats.lua)
2018-05-24 15:24:01 info /usr/sbin/cron[17005]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:24:27 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 15:24:27 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 15:25:01 info /usr/sbin/cron[17297]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 15:25:01 info /usr/sbin/cron[17296]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:25:01 info /usr/sbin/cron[17298]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 15:25:59 info ucollect[4497]: Updating filter addresses from version 50905570 to version 50905611 (epoch 4)
2018-05-24 15:26:01 info /usr/sbin/cron[17621]: (root) CMD (nethist_stats.lua)
2018-05-24 15:26:01 info /usr/sbin/cron[17622]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:26:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905531 to version 50905611 (epoch 4)
2018-05-24 15:26:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 15:27:01 info /usr/sbin/cron[17940]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:27:01 info /usr/sbin/cron[17941]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:28:01 info /usr/sbin/cron[18260]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:28:01 info /usr/sbin/cron[18261]: (root) CMD (nethist_stats.lua)
2018-05-24 15:29:01 info /usr/sbin/cron[18505]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:30:01 info /usr/sbin/cron[18746]: (root) CMD (/usr/bin/get-api-crl)
2018-05-24 15:30:01 info /usr/sbin/cron[18742]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:30:01 info /usr/sbin/cron[18748]: (root) CMD (nethist_stats.lua)
2018-05-24 15:30:01 info /usr/sbin/cron[18749]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 15:30:01 info /usr/sbin/cron[18752]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 15:30:01 info /usr/sbin/cron[18753]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 15:30:01 info /usr/sbin/cron[18755]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:30:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 15:30:26 info nikola[]: (v42) Establishing connection took 0.610214 seconds
2018-05-24 15:30:26 info nikola[]: (v42) Logrotate took 0.004687 seconds
2018-05-24 15:30:26 info nikola[]: (v42) Syslog parsing took 0.046217 seconds
2018-05-24 15:30:26 info nikola[]: (v42) Session init took 0.759848 seconds
2018-05-24 15:30:26 info nikola[]: (v42) Records parsed: 41
2018-05-24 15:30:27 info nikola[]: (v42) Records after filtering: 27
2018-05-24 15:30:27 info nikola[]: (v42) Records filtering took 0.009477 seconds
2018-05-24 15:30:27 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 15:30:27 info nikola[]: (v42) Sending records took 0.083813 seconds
2018-05-24 15:31:01 info /usr/sbin/cron[19197]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:31:20 info dnsmasq-dhcp[5601]: DHCPINFORM(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 15:31:20 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 15:32:01 info /usr/sbin/cron[19438]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:32:01 info /usr/sbin/cron[19439]: (root) CMD (nethist_stats.lua)
2018-05-24 15:33:01 info /usr/sbin/cron[19844]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:33:01 info /usr/sbin/cron[19845]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:34:01 info /usr/sbin/cron[20166]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:34:01 info /usr/sbin/cron[20168]: (root) CMD (nethist_stats.lua)
2018-05-24 15:35:01 info /usr/sbin/cron[20550]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:35:01 info /usr/sbin/cron[20551]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 15:35:01 info /usr/sbin/cron[20554]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 15:35:02 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 15:35:02 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 15:35:19 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 15:35:19 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 15:35:20 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 15:35:20 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 15:35:20 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 2 times, suppressed by syslog-ng on Omnia
2018-05-24 15:35:20 warning dhcp_host_domain_ng.py[]: Del_lease, hosname check failed
2018-05-24 15:35:20 info dhcp_host_domain_ng.py[]: DHCP delete hostname [del,Sony_Xperia_Z3,192.168.2.105]
2018-05-24 15:35:20 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 15:35:20 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 15:36:01 info /usr/sbin/cron[21044]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:36:01 info /usr/sbin/cron[21045]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:36:01 info /usr/sbin/cron[21048]: (root) CMD (nethist_stats.lua)
2018-05-24 15:37:01 info /usr/sbin/cron[21428]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:37:14 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 15:37:14 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 15:38:01 info /usr/sbin/cron[21667]: (root) CMD (nethist_stats.lua)
2018-05-24 15:38:01 info /usr/sbin/cron[21666]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:38:02 info dnsmasq-dhcp[5601]: DHCPINFORM(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 15:38:02 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 15:38:19 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 15:38:19 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 15:39:01 info /usr/sbin/cron[22022]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:39:01 info /usr/sbin/cron[22023]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:40:01 info /usr/sbin/cron[22397]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:40:01 info /usr/sbin/cron[22400]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 15:40:01 info /usr/sbin/cron[22399]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 15:40:01 info /usr/sbin/cron[22401]: (root) CMD (nethist_stats.lua)
2018-05-24 15:41:01 info /usr/sbin/cron[22765]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:42:01 info /usr/sbin/cron[23145]: (root) CMD (nethist_stats.lua)
2018-05-24 15:42:01 info /usr/sbin/cron[23144]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:42:01 info /usr/sbin/cron[23146]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:43:01 info /usr/sbin/cron[23613]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:44:01 info /usr/sbin/cron[24044]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:44:01 info /usr/sbin/cron[24045]: (root) CMD (nethist_stats.lua)
2018-05-24 15:45:01 info /usr/sbin/cron[24279]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:45:01 info /usr/sbin/cron[24282]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:45:01 info /usr/sbin/cron[24284]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 15:45:01 info /usr/sbin/cron[24285]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 15:45:01 info /usr/sbin/cron[24286]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 15:45:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 15:45:52 info nikola[]: (v42) Establishing connection took 0.626820 seconds
2018-05-24 15:45:52 info nikola[]: (v42) Logrotate took 0.006011 seconds
2018-05-24 15:45:52 info nikola[]: (v42) Syslog parsing took 0.045074 seconds
2018-05-24 15:45:53 info nikola[]: (v42) Session init took 0.755036 seconds
2018-05-24 15:45:53 info nikola[]: (v42) Records parsed: 37
2018-05-24 15:45:53 info nikola[]: (v42) Records after filtering: 24
2018-05-24 15:45:53 info nikola[]: (v42) Records filtering took 0.008535 seconds
2018-05-24 15:45:53 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 15:45:53 info nikola[]: (v42) Sending records took 0.080610 seconds
2018-05-24 15:45:59 info ucollect[4497]: Updating filter addresses from version 50905611 to version 50905651 (epoch 4)
2018-05-24 15:46:01 info /usr/sbin/cron[24658]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:46:01 info /usr/sbin/cron[24659]: (root) CMD (nethist_stats.lua)
2018-05-24 15:46:03 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905611 to version 50905651 (epoch 4)
2018-05-24 15:46:08 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 15:47:01 info /usr/sbin/cron[24901]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:48:01 info /usr/sbin/cron[25278]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:48:01 info /usr/sbin/cron[25279]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:48:01 info /usr/sbin/cron[25282]: (root) CMD (nethist_stats.lua)
2018-05-24 15:49:01 info /usr/sbin/cron[25629]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:49:44 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 15:49:44 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 15:50:01 info /usr/sbin/cron[25731]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:50:01 info /usr/sbin/cron[25733]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 15:50:01 info /usr/sbin/cron[25737]: (root) CMD (nethist_stats.lua)
2018-05-24 15:50:01 info /usr/sbin/cron[25736]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 15:50:02 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 15:50:02 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 15:50:55 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 15:50:55 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 15:51:01 info /usr/sbin/cron[25862]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:51:01 info /usr/sbin/cron[25863]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:51:26 info ucollect[4497]: Sending 57 flows
2018-05-24 15:51:26 info ucollect[4497]: Sending 42 IPv4 refused connections and 0 IPv6 ones
2018-05-24 15:52:01 info /usr/sbin/cron[26004]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:52:01 info /usr/sbin/cron[26005]: (root) CMD (nethist_stats.lua)
2018-05-24 15:52:12 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 15:52:12 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 15:53:01 info /usr/sbin/cron[26105]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:54:01 info /usr/sbin/cron[26208]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:54:01 info /usr/sbin/cron[26211]: (root) CMD (nethist_stats.lua)
2018-05-24 15:54:01 info /usr/sbin/cron[26209]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:54:12 info dnsmasq-dhcp[5601]: DHCPDISCOVER(br-lan) 18:8e:d5:00:12:d0
2018-05-24 15:54:12 info dnsmasq-dhcp[5601]: DHCPOFFER(br-lan) 192.168.2.113 18:8e:d5:00:12:d0
2018-05-24 15:54:12 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.113 18:8e:d5:00:12:d0
2018-05-24 15:54:12 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.113 18:8e:d5:00:12:d0 TV_Philips_32PFL7406
2018-05-24 15:54:13 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 15:54:13 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 15:54:13 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 4 times, suppressed by syslog-ng on Omnia
2018-05-24 15:54:13 info dhcp_host_domain_ng.py[]: DHCP add new hostname [TV_Philips_32PFL7406,192.168.2.113]
2018-05-24 15:54:13 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 15:54:13 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 15:54:20 info dnsmasq-dhcp[5601]: DHCPDISCOVER(br-lan) 00:0e:9e:05:23:2b
2018-05-24 15:54:20 info dnsmasq-dhcp[5601]: DHCPOFFER(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 15:54:20 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 15:54:20 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 15:54:20 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 15:54:20 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 15:54:20 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 5 times, suppressed by syslog-ng on Omnia
2018-05-24 15:54:20 info dhcp_host_domain_ng.py[]: DHCP add new hostname [Topfield_SRP-2411,192.168.2.111]
2018-05-24 15:54:20 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 15:54:20 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 15:55:01 info /usr/sbin/cron[26364]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:55:01 info /usr/sbin/cron[26365]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 15:55:01 info /usr/sbin/cron[26366]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 15:56:01 info /usr/sbin/cron[26481]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:56:01 info /usr/sbin/cron[26482]: (root) CMD (nethist_stats.lua)
2018-05-24 15:56:25 err ucollect[4497]: Too many pings not answered on api.turris.cz:5679, reconnecting
2018-05-24 15:56:25 info ucollect[4497]: Reconnecting to api.turris.cz:5679 now
2018-05-24 15:56:25 info ucollect[4497]: Socat started
2018-05-24 15:56:25 err ucollect[4497]: Error from socat: 2018/05/24 15:56:25 socat[26531] E connect(5, AF=10 [2001:1488:ac15:ff80:0000:0000:0000:0101]:5679, 28): Permission denied
2018-05-24 15:56:25 warning ucollect[4497]: Remote closed the uplink api.turris.cz:5679, reconnecting
2018-05-24 15:56:25 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 15:56:25 warning ucollect[4497]: Reconnecting too often, waiting a little while
2018-05-24 15:56:25 info ucollect[4497]: Going to reconnect to api.turris.cz:5679 after 2 seconds
2018-05-24 15:56:27 info ucollect[4497]: Reconnecting to api.turris.cz:5679 now
2018-05-24 15:56:27 info ucollect[4497]: Socat started
2018-05-24 15:56:29 err ucollect[4497]: Error from socat: 2018/05/24 15:56:29 socat[26534] E connect(5, AF=2 217.31.192.101:5679, 16): Host is unreachable
2018-05-24 15:56:29 warning ucollect[4497]: Remote closed the uplink api.turris.cz:5679, reconnecting
2018-05-24 15:56:29 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 15:56:29 info ucollect[4497]: Reconnecting to api.turris.cz:5679 now
2018-05-24 15:56:29 info ucollect[4497]: Socat started
2018-05-24 15:56:29 err ucollect[4497]: Error from socat: 2018/05/24 15:56:29 socat[26537] E connect(5, AF=10 [2001:1488:ac15:ff80:0000:0000:0000:0101]:5679, 28): Permission denied
2018-05-24 15:56:29 warning ucollect[4497]: Reconnecting too often, waiting a little while
2018-05-24 15:56:29 info ucollect[4497]: Going to reconnect to api.turris.cz:5679 after 4 seconds
2018-05-24 15:56:33 info ucollect[4497]: Reconnecting to api.turris.cz:5679 now
2018-05-24 15:56:33 info ucollect[4497]: Socat started
2018-05-24 15:56:35 err ucollect[4497]: Error from socat: 2018/05/24 15:56:35 socat[26550] E connect(5, AF=2 217.31.192.101:5679, 16): Host is unreachable
2018-05-24 15:56:35 warning ucollect[4497]: Remote closed the uplink api.turris.cz:5679, reconnecting
2018-05-24 15:56:35 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 15:56:35 info ucollect[4497]: Reconnecting to api.turris.cz:5679 now
2018-05-24 15:56:35 info ucollect[4497]: Socat started
2018-05-24 15:56:35 err ucollect[4497]: Error from socat: 2018/05/24 15:56:35 socat[26553] E connect(5, AF=10 [2001:1488:ac15:ff80:0000:0000:0000:0101]:5679, 28): Permission denied
2018-05-24 15:56:35 warning ucollect[4497]: Reconnecting too often, waiting a little while
2018-05-24 15:56:35 info ucollect[4497]: Going to reconnect to api.turris.cz:5679 after 8 seconds
2018-05-24 15:56:43 info ucollect[4497]: Reconnecting to api.turris.cz:5679 now
2018-05-24 15:56:43 info ucollect[4497]: Socat started
2018-05-24 15:56:44 err ucollect[4497]: Error from socat: 2018/05/24 15:56:44 socat[26562] E connect(5, AF=2 217.31.192.101:5679, 16): Host is unreachable
2018-05-24 15:56:44 warning ucollect[4497]: Remote closed the uplink api.turris.cz:5679, reconnecting
2018-05-24 15:56:44 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 15:56:44 info ucollect[4497]: Reconnecting to api.turris.cz:5679 now
2018-05-24 15:56:44 warning ucollect[4497]: Reconnecting too often, waiting a little while
2018-05-24 15:56:44 info ucollect[4497]: Going to reconnect to api.turris.cz:5679 after 16 seconds
2018-05-24 15:57:00 info ucollect[4497]: Reconnecting to api.turris.cz:5679 now
2018-05-24 15:57:00 info ucollect[4497]: Socat started
2018-05-24 15:57:00 err ucollect[4497]: Error from socat: 2018/05/24 15:57:00 socat[26590] E connect(5, AF=10 [2001:1488:ac15:ff80:0000:0000:0000:0101]:5679, 28): Permission denied
2018-05-24 15:57:00 warning ucollect[4497]: Remote closed the uplink api.turris.cz:5679, reconnecting
2018-05-24 15:57:00 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 15:57:00 warning ucollect[4497]: Reconnecting too often, waiting a little while
2018-05-24 15:57:00 info ucollect[4497]: Going to reconnect to api.turris.cz:5679 after 32 seconds
2018-05-24 15:57:01 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 15:57:01 info /usr/sbin/cron[26595]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 15:57:01 info /usr/sbin/cron[26596]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:57:32 info ucollect[4497]: Reconnecting to api.turris.cz:5679 now
2018-05-24 15:57:32 info ucollect[4497]: Socat started
2018-05-24 15:57:34 info ucollect[4497]: Activating plugin Count
2018-05-24 15:57:34 info ucollect[4497]: Activating plugin Sniff
2018-05-24 15:57:34 info ucollect[4497]: Activating plugin Flow
2018-05-24 15:57:34 info ucollect[4497]: Activating plugin Refused
2018-05-24 15:57:34 info ucollect[4497]: Activating plugin Bandwidth
2018-05-24 15:57:34 info ucollect[4497]: Activating plugin Fake
2018-05-24 15:57:34 info ucollect[4497]: Activating plugin Fwup
2018-05-24 15:57:34 info ucollect[4497]: Activating plugin Spoof
2018-05-24 15:57:34 info ucollect[4497]: Received configuration 49828441 (max. 5000 flows, 1800000 ms timeout)
2018-05-24 15:57:34 info ucollect[4497]: Refused config version not changed from 3
2018-05-24 15:58:01 info /usr/sbin/cron[26743]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 15:58:01 info /usr/sbin/cron[26744]: (root) CMD (nethist_stats.lua)
2018-05-24 15:59:01 info /usr/sbin/cron[26844]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:00:01 info /usr/sbin/cron[26954]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 16:00:01 info /usr/sbin/cron[26957]: (root) CMD (/usr/bin/updater-supervisor -d --rand-sleep)
2018-05-24 16:00:01 info /usr/sbin/cron[26949]: (root) CMD (/usr/bin/get-api-crl)
2018-05-24 16:00:01 info /usr/sbin/cron[26959]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 16:00:01 info /usr/sbin/cron[26960]: (root) CMD (nethist_stats.lua)
2018-05-24 16:00:01 info /usr/sbin/cron[26945]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:00:01 info /usr/sbin/cron[26961]: (root) CMD (netmetr --autostart --dwlhist --rwait 1800 &)
2018-05-24 16:00:01 info /usr/sbin/cron[26966]: (root) CMD (/usr/share/firewall/turris-download)
2018-05-24 16:00:01 info /usr/sbin/cron[26968]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:00:01 info /usr/sbin/cron[26969]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 16:00:01 info /usr/sbin/cron[26971]: (root) CMD (/usr/share/server-uplink/contract_valid.sh)
2018-05-24 16:00:01 info /usr/sbin/cron[26972]: (root) CMD (/usr/share/server-uplink/registration_code.sh)
2018-05-24 16:00:02 err server_uplink[]: Failed to download contract status
2018-05-24 16:00:03 info updater-supervisor[]: Suspending updater start for 5657 seconds
2018-05-24 16:00:03 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 16:00:41 info nikola[]: (v42) Establishing connection took 0.617629 seconds
2018-05-24 16:00:41 info nikola[]: (v42) Logrotate took 0.004673 seconds
2018-05-24 16:00:41 info nikola[]: (v42) Syslog parsing took 0.058172 seconds
2018-05-24 16:00:42 info nikola[]: (v42) Session init took 0.763966 seconds
2018-05-24 16:00:42 info nikola[]: (v42) Records parsed: 55
2018-05-24 16:00:42 info nikola[]: (v42) Records after filtering: 44
2018-05-24 16:00:42 info nikola[]: (v42) Records filtering took 0.010466 seconds
2018-05-24 16:00:42 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 16:00:42 info nikola[]: (v42) Sending records took 0.103337 seconds
2018-05-24 16:01:01 info /usr/sbin/cron[27176]: (root) CMD (majordomo_db.sh genhour)
2018-05-24 16:01:01 info /usr/sbin/cron[27177]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:02:01 info /usr/sbin/cron[27321]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:02:01 info /usr/sbin/cron[27322]: (root) CMD (nethist_stats.lua)
2018-05-24 16:02:01 err server_uplink[]: Failed to get registration code
2018-05-24 16:02:09 err turris-firewall-rules[]: (v63) Failed to download https://api.turris.cz/firewall/turris-ipsets.gz.sign
2018-05-24 16:03:01 info /usr/sbin/cron[27428]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:03:01 info /usr/sbin/cron[27429]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:04:01 info /usr/sbin/cron[27564]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:04:01 info /usr/sbin/cron[27566]: (root) CMD (majordomo_locked_precache.sh)
2018-05-24 16:04:01 info /usr/sbin/cron[27569]: (root) CMD (nethist_stats.lua)
2018-05-24 16:04:08 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 16:04:08 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 16:04:32 err ucollect[4497]: Too many pings not answered on api.turris.cz:5679, reconnecting
2018-05-24 16:04:32 info ucollect[4497]: Reconnecting to api.turris.cz:5679 now
2018-05-24 16:04:32 info ucollect[4497]: Socat started
2018-05-24 16:04:32 err ucollect[4497]: Error from socat: 2018/05/24 16:04:32 socat[27673] E connect(5, AF=10 [2001:1488:ac15:ff80:0000:0000:0000:0101]:5679, 28): Permission denied
2018-05-24 16:04:32 warning ucollect[4497]: Remote closed the uplink api.turris.cz:5679, reconnecting
2018-05-24 16:04:32 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 16:04:32 warning ucollect[4497]: Reconnecting too often, waiting a little while
2018-05-24 16:04:32 info ucollect[4497]: Going to reconnect to api.turris.cz:5679 after 2 seconds
2018-05-24 16:04:33 info hostapd[]: wlan0: STA bc:76:5e:28:f9:75 IEEE 802.11: authenticated
2018-05-24 16:04:33 info hostapd[]: wlan0: STA bc:76:5e:28:f9:75 IEEE 802.11: associated (aid 1)
2018-05-24 16:04:33 info hostapd[]: wlan0: STA bc:76:5e:28:f9:75 RADIUS: starting accounting session 667BD46EE01F0684
2018-05-24 16:04:33 info hostapd[]: wlan0: STA bc:76:5e:28:f9:75 WPA: pairwise key handshake completed (RSN)
2018-05-24 16:04:33 info dnsmasq-dhcp[5601]: DHCPDISCOVER(br-lan) bc:76:5e:28:f9:75
2018-05-24 16:04:33 info dnsmasq-dhcp[5601]: DHCPOFFER(br-lan) 192.168.2.106 bc:76:5e:28:f9:75
2018-05-24 16:04:33 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.106 bc:76:5e:28:f9:75
2018-05-24 16:04:33 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.106 bc:76:5e:28:f9:75 Tablet_Jarda
2018-05-24 16:04:33 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 16:04:33 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 16:04:33 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 6 times, suppressed by syslog-ng on Omnia
2018-05-24 16:04:33 info dhcp_host_domain_ng.py[]: DHCP add new hostname [Tablet_Jarda,192.168.2.106]
2018-05-24 16:04:33 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 16:04:33 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 16:04:34 info ucollect[4497]: Reconnecting to api.turris.cz:5679 now
2018-05-24 16:04:34 info ucollect[4497]: Socat started
2018-05-24 16:04:35 err ucollect[4497]: Error from socat: 2018/05/24 16:04:35 socat[27684] E connect(5, AF=2 217.31.192.101:5679, 16): Host is unreachable
2018-05-24 16:04:35 warning ucollect[4497]: Remote closed the uplink api.turris.cz:5679, reconnecting
2018-05-24 16:04:35 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 16:04:35 info ucollect[4497]: Reconnecting to api.turris.cz:5679 now
2018-05-24 16:04:35 warning ucollect[4497]: Reconnecting too often, waiting a little while
2018-05-24 16:04:35 info ucollect[4497]: Going to reconnect to api.turris.cz:5679 after 4 seconds
2018-05-24 16:04:39 info ucollect[4497]: Reconnecting to api.turris.cz:5679 now
2018-05-24 16:04:39 info ucollect[4497]: Socat started
2018-05-24 16:04:39 err ucollect[4497]: Error from socat: 2018/05/24 16:04:39 socat[27700] E connect(5, AF=10 [2001:1488:ac15:ff80:0000:0000:0000:0101]:5679, 28): Permission denied
2018-05-24 16:04:39 warning ucollect[4497]: Remote closed the uplink api.turris.cz:5679, reconnecting
2018-05-24 16:04:39 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 16:04:39 warning ucollect[4497]: Reconnecting too often, waiting a little while
2018-05-24 16:04:39 info ucollect[4497]: Going to reconnect to api.turris.cz:5679 after 8 seconds
2018-05-24 16:04:44 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 16:04:44 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 16:04:47 info ucollect[4497]: Reconnecting to api.turris.cz:5679 now
2018-05-24 16:04:47 info ucollect[4497]: Socat started
2018-05-24 16:04:50 err ucollect[4497]: Error from socat: 2018/05/24 16:04:50 socat[27713] E connect(5, AF=2 217.31.192.101:5679, 16): Host is unreachable
2018-05-24 16:04:50 warning ucollect[4497]: Remote closed the uplink api.turris.cz:5679, reconnecting
2018-05-24 16:04:50 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 16:04:50 info ucollect[4497]: Reconnecting to api.turris.cz:5679 now
2018-05-24 16:04:50 info ucollect[4497]: Socat started
2018-05-24 16:04:50 err ucollect[4497]: Error from socat: 2018/05/24 16:04:50 socat[27717] E connect(5, AF=10 [2001:1488:ac15:ff80:0000:0000:0000:0101]:5679, 28): Permission denied
2018-05-24 16:04:50 warning ucollect[4497]: Reconnecting too often, waiting a little while
2018-05-24 16:04:50 info ucollect[4497]: Going to reconnect to api.turris.cz:5679 after 16 seconds
2018-05-24 16:04:55 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 16:05:01 info /usr/sbin/cron[27748]: (root) CMD (/usr/share/firewall/turris)
2018-05-24 16:05:01 info /usr/sbin/cron[27750]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:05:01 info /usr/sbin/cron[27751]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 16:05:01 info /usr/sbin/cron[27752]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 16:05:01 info turris-firewall-rules[]: (v63) IPv4 WAN interface used - 'eth1'
2018-05-24 16:05:01 info turris-firewall-rules[]: (v63) IPv6 WAN interface used - 'lo'
2018-05-24 16:05:02 info turris-firewall-rules[]: (v63) 3524 ipv4 address(es) and 3 ipv6 address(es) were loaded (c83b72d5b03454292e5000b3967bc350), 0 rule(s) overriden, 0 rule(s) skipped
2018-05-24 16:05:06 info ucollect[4497]: Reconnecting to api.turris.cz:5679 now
2018-05-24 16:05:06 info ucollect[4497]: Socat started
2018-05-24 16:05:07 info ucollect[4497]: Activating plugin Count
2018-05-24 16:05:07 info ucollect[4497]: Activating plugin Sniff
2018-05-24 16:05:07 info ucollect[4497]: Activating plugin Flow
2018-05-24 16:05:07 info ucollect[4497]: Activating plugin Refused
2018-05-24 16:05:07 info ucollect[4497]: Activating plugin Bandwidth
2018-05-24 16:05:07 info ucollect[4497]: Activating plugin Fake
2018-05-24 16:05:07 info ucollect[4497]: Activating plugin Fwup
2018-05-24 16:05:07 info ucollect[4497]: Activating plugin Spoof
2018-05-24 16:05:07 info ucollect[4497]: Received configuration 49828441 (max. 5000 flows, 1800000 ms timeout)
2018-05-24 16:05:07 info ucollect[4497]: Refused config version not changed from 3
2018-05-24 16:05:59 info ucollect[4497]: Updating filter addresses from version 50905651 to version 50905690 (epoch 4)
2018-05-24 16:06:01 info /usr/sbin/cron[28448]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:06:01 info /usr/sbin/cron[28449]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:06:01 info /usr/sbin/cron[28450]: (root) CMD (nethist_stats.lua)
2018-05-24 16:06:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905651 to version 50905690 (epoch 4)
2018-05-24 16:06:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 16:07:01 info /usr/sbin/cron[28951]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:08:01 info /usr/sbin/cron[29352]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:08:01 info /usr/sbin/cron[29353]: (root) CMD (nethist_stats.lua)
2018-05-24 16:09:01 info /usr/sbin/cron[29645]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:09:01 info /usr/sbin/cron[29646]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:09:13 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.113 18:8e:d5:00:12:d0
2018-05-24 16:09:13 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.113 18:8e:d5:00:12:d0 TV_Philips_32PFL7406
2018-05-24 16:09:22 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 16:09:22 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 16:10:01 info /usr/sbin/cron[29818]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:10:01 info /usr/sbin/cron[29820]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 16:10:01 info /usr/sbin/cron[29824]: (root) CMD (nethist_stats.lua)
2018-05-24 16:10:02 info /usr/sbin/cron[29825]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 16:11:01 info /usr/sbin/cron[29979]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:12:01 info /usr/sbin/cron[30193]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:12:01 info /usr/sbin/cron[30196]: (root) CMD (nethist_stats.lua)
2018-05-24 16:12:01 info /usr/sbin/cron[30195]: (root) CMD (/usr/sbin/logrotate -s /tmp/logrotate.state /etc/logrotate.conf)
2018-05-24 16:12:01 info /usr/sbin/cron[30197]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:13:01 info /usr/sbin/cron[30481]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:14:01 info /usr/sbin/cron[30679]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:14:01 info /usr/sbin/cron[30680]: (root) CMD (nethist_stats.lua)
2018-05-24 16:14:04 info dnsmasq-dhcp[5601]: DHCPDISCOVER(br-lan) b0:e8:92:37:5f:b4
2018-05-24 16:14:04 info dnsmasq-dhcp[5601]: DHCPOFFER(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 16:14:04 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 16:14:04 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 16:14:04 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 16:14:04 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 16:14:04 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 5 times, suppressed by syslog-ng on Omnia
2018-05-24 16:14:04 warning dhcp_host_domain_ng.py[]: Del_lease, hosname check failed
2018-05-24 16:14:04 info dhcp_host_domain_ng.py[]: DHCP remove old hostname [old,Epson_XP-700_printer,192.168.2.118]
2018-05-24 16:14:04 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 16:14:04 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 16:15:01 info /usr/sbin/cron[30882]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:15:01 info /usr/sbin/cron[30885]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:15:01 info /usr/sbin/cron[30889]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 16:15:01 info /usr/sbin/cron[30887]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 16:15:01 info /usr/sbin/cron[30890]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 16:15:03 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 16:16:00 info nikola[]: (v42) Establishing connection took 0.647920 seconds
2018-05-24 16:16:00 info nikola[]: (v42) Logrotate took 0.004779 seconds
2018-05-24 16:16:00 info nikola[]: (v42) Syslog parsing took 0.058564 seconds
2018-05-24 16:16:01 info nikola[]: (v42) Session init took 0.797303 seconds
2018-05-24 16:16:01 info nikola[]: (v42) Records parsed: 49
2018-05-24 16:16:01 info nikola[]: (v42) Records after filtering: 40
2018-05-24 16:16:01 info nikola[]: (v42) Records filtering took 0.010443 seconds
2018-05-24 16:16:01 info /usr/sbin/cron[31342]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:16:01 info /usr/sbin/cron[31343]: (root) CMD (nethist_stats.lua)
2018-05-24 16:16:01 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 16:16:01 info nikola[]: (v42) Sending records took 0.091912 seconds
2018-05-24 16:17:01 info /usr/sbin/cron[31663]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:17:36 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 16:17:36 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 16:17:36 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 16:17:36 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 16:17:36 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 5 times, suppressed by syslog-ng on Omnia
2018-05-24 16:17:36 warning dhcp_host_domain_ng.py[]: Del_lease, hosname check failed
2018-05-24 16:17:36 info dhcp_host_domain_ng.py[]: DHCP remove old hostname [old,Fujitsu_kuchyn,192.168.2.120]
2018-05-24 16:17:36 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 16:17:36 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 16:18:01 info /usr/sbin/cron[32034]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:18:01 info /usr/sbin/cron[32036]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:18:01 info /usr/sbin/cron[32038]: (root) CMD (nethist_stats.lua)
2018-05-24 16:18:07 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 16:18:07 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 16:18:32 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 16:18:32 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 16:18:59 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.106 bc:76:5e:28:f9:75
2018-05-24 16:18:59 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.106 bc:76:5e:28:f9:75 Tablet_Jarda
2018-05-24 16:19:01 info /usr/sbin/cron[32326]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:20:01 info /usr/sbin/cron[32577]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:20:01 info /usr/sbin/cron[32579]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 16:20:01 info /usr/sbin/cron[32583]: (root) CMD (nethist_stats.lua)
2018-05-24 16:20:01 info /usr/sbin/cron[32584]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 16:21:01 info /usr/sbin/cron[356]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:21:01 info /usr/sbin/cron[355]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Global permanent pool: 3108/4096 (19)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Global batch pool: 0/4096 (0)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Global temporary pool: 156/4096 (3)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Buffer pool for uplink: 4/4096 (1)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Config pool: 4094/8192 (137)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Badconf: 48/4096 (1)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Bandwidth: 2744/4096 (6)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Count: 264/4096 (1)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Fake: 189120/217088 (161)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Fake log: 239/4096 (10)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Flow: 128/4096 (5)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Flow pool: 5049/8192 (104)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Flow conf pool: 844153/888832 (45123)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Fwup: 168/4096 (7)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 1: 0/4096 (0)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 2: 122246/131072 (6549)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Refused: 104/4096 (3)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Refuse pool 1: 0/4096 (0)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Refuse pool 2: 76649/77824 (3203)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Sniff: 44/4096 (3)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Sniffer pool: 0/4096 (0)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats: Spoof: 224/4096 (1)
2018-05-24 16:21:21 info ucollect[4497]: Mempool stats done
2018-05-24 16:21:26 info ucollect[4497]: Sending 31 flows
2018-05-24 16:21:26 info ucollect[4497]: Sending 164 IPv4 refused connections and 0 IPv6 ones
2018-05-24 16:22:01 info /usr/sbin/cron[755]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:22:01 info /usr/sbin/cron[756]: (root) CMD (nethist_stats.lua)
2018-05-24 16:23:01 info /usr/sbin/cron[1030]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:24:01 info /usr/sbin/cron[1257]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:24:01 info /usr/sbin/cron[1258]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:24:01 info /usr/sbin/cron[1259]: (root) CMD (nethist_stats.lua)
2018-05-24 16:24:13 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.113 18:8e:d5:00:12:d0
2018-05-24 16:24:13 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.113 18:8e:d5:00:12:d0 TV_Philips_32PFL7406
2018-05-24 16:24:23 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 16:24:23 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 16:25:01 info /usr/sbin/cron[1758]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 16:25:01 info /usr/sbin/cron[1757]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:25:01 info /usr/sbin/cron[1759]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 16:25:59 info ucollect[4497]: Updating filter addresses from version 50905690 to version 50905730 (epoch 4)
2018-05-24 16:26:01 info /usr/sbin/cron[2241]: (root) CMD (nethist_stats.lua)
2018-05-24 16:26:01 info /usr/sbin/cron[2240]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:26:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905690 to version 50905730 (epoch 4)
2018-05-24 16:26:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 16:27:01 info /usr/sbin/cron[2441]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:27:01 info /usr/sbin/cron[2442]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:28:01 info /usr/sbin/cron[2650]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:28:01 info /usr/sbin/cron[2651]: (root) CMD (nethist_stats.lua)
2018-05-24 16:29:01 info /usr/sbin/cron[2865]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:29:04 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 16:29:04 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 16:30:01 info /usr/sbin/cron[3149]: (root) CMD (/usr/bin/get-api-crl)
2018-05-24 16:30:01 info /usr/sbin/cron[3144]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:30:01 info /usr/sbin/cron[3154]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 16:30:01 info /usr/sbin/cron[3156]: (root) CMD (nethist_stats.lua)
2018-05-24 16:30:01 info /usr/sbin/cron[3157]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 16:30:01 info /usr/sbin/cron[3159]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 16:30:01 info /usr/sbin/cron[3155]: (root) CMD (/usr/share/haas/register.sh)
2018-05-24 16:30:01 info /usr/sbin/cron[3158]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:30:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 16:30:26 info nikola[]: (v42) Establishing connection took 0.630375 seconds
2018-05-24 16:30:26 info nikola[]: (v42) Logrotate took 0.005444 seconds
2018-05-24 16:30:26 info nikola[]: (v42) Syslog parsing took 0.045599 seconds
2018-05-24 16:30:26 info nikola[]: (v42) Session init took 0.766446 seconds
2018-05-24 16:30:26 info nikola[]: (v42) Records parsed: 32
2018-05-24 16:30:26 info nikola[]: (v42) Records after filtering: 21
2018-05-24 16:30:26 info nikola[]: (v42) Records filtering took 0.008314 seconds
2018-05-24 16:30:26 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 16:30:26 info nikola[]: (v42) Sending records took 0.079393 seconds
2018-05-24 16:31:01 info /usr/sbin/cron[3576]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:31:33 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 16:31:33 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 16:32:01 info /usr/sbin/cron[3853]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:32:01 info /usr/sbin/cron[3854]: (root) CMD (nethist_stats.lua)
2018-05-24 16:32:35 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 16:32:35 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 16:32:58 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 16:32:58 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 16:33:01 info /usr/sbin/cron[4116]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:33:01 info /usr/sbin/cron[4117]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:34:01 info /usr/sbin/cron[4361]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:34:01 info /usr/sbin/cron[4362]: (root) CMD (nethist_stats.lua)
2018-05-24 16:35:01 info /usr/sbin/cron[4632]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:35:01 info /usr/sbin/cron[4635]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 16:35:01 info /usr/sbin/cron[4637]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 16:36:01 info /usr/sbin/cron[4976]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:36:01 info /usr/sbin/cron[4977]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:36:01 info /usr/sbin/cron[4981]: (root) CMD (nethist_stats.lua)
2018-05-24 16:37:01 info /usr/sbin/cron[5252]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:38:01 info /usr/sbin/cron[5712]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:38:01 info /usr/sbin/cron[5711]: (root) CMD (nethist_stats.lua)
2018-05-24 16:38:43 info dnsmasq-dhcp[5601]: DHCPINFORM(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 16:38:43 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 16:39:01 info /usr/sbin/cron[5953]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:39:01 info /usr/sbin/cron[5954]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:39:13 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.113 18:8e:d5:00:12:d0
2018-05-24 16:39:13 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.113 18:8e:d5:00:12:d0 TV_Philips_32PFL7406
2018-05-24 16:39:25 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 16:39:25 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 16:40:01 info /usr/sbin/cron[6278]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:40:01 info /usr/sbin/cron[6280]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 16:40:01 info /usr/sbin/cron[6287]: (root) CMD (nethist_stats.lua)
2018-05-24 16:40:01 info /usr/sbin/cron[6288]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 16:41:01 info /usr/sbin/cron[6806]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:42:01 info /usr/sbin/cron[7090]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:42:01 info /usr/sbin/cron[7093]: (root) CMD (nethist_stats.lua)
2018-05-24 16:42:01 info /usr/sbin/cron[7091]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:43:01 info /usr/sbin/cron[7437]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:44:01 info /usr/sbin/cron[7756]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:44:01 info /usr/sbin/cron[7757]: (root) CMD (nethist_stats.lua)
2018-05-24 16:44:03 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 16:44:03 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 16:45:01 info /usr/sbin/cron[8029]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:45:01 info /usr/sbin/cron[8032]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:45:01 info /usr/sbin/cron[8034]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 16:45:01 info /usr/sbin/cron[8035]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 16:45:01 info /usr/sbin/cron[8036]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 16:45:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 16:45:18 info nikola[]: (v42) Establishing connection took 0.609217 seconds
2018-05-24 16:45:18 info nikola[]: (v42) Logrotate took 0.004774 seconds
2018-05-24 16:45:18 info nikola[]: (v42) Syslog parsing took 0.049357 seconds
2018-05-24 16:45:19 info nikola[]: (v42) Session init took 0.761869 seconds
2018-05-24 16:45:19 info nikola[]: (v42) Records parsed: 46
2018-05-24 16:45:19 info nikola[]: (v42) Records after filtering: 33
2018-05-24 16:45:19 info nikola[]: (v42) Records filtering took 0.009890 seconds
2018-05-24 16:45:19 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 16:45:19 info nikola[]: (v42) Sending records took 0.086687 seconds
2018-05-24 16:45:33 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 16:45:33 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 16:45:43 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 16:45:43 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 16:45:59 info ucollect[4497]: Updating filter addresses from version 50905730 to version 50905770 (epoch 4)
2018-05-24 16:46:01 info /usr/sbin/cron[8488]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:46:01 info /usr/sbin/cron[8489]: (root) CMD (nethist_stats.lua)
2018-05-24 16:46:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905730 to version 50905770 (epoch 4)
2018-05-24 16:46:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 16:47:01 info /usr/sbin/cron[8788]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:47:22 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 16:47:22 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 16:48:01 info /usr/sbin/cron[9166]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:48:01 info /usr/sbin/cron[9165]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:48:01 info /usr/sbin/cron[9167]: (root) CMD (nethist_stats.lua)
2018-05-24 16:49:00 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 16:49:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 16:49:00 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 4 times, suppressed by syslog-ng on Omnia
2018-05-24 16:49:00 warning dhcp_host_domain_ng.py[]: Del_lease, hosname check failed
2018-05-24 16:49:00 info dhcp_host_domain_ng.py[]: DHCP delete hostname [del,Tablet_Jarda,192.168.2.106]
2018-05-24 16:49:00 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 16:49:00 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 16:49:01 info /usr/sbin/cron[9643]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:50:01 info /usr/sbin/cron[9751]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:50:01 info /usr/sbin/cron[9752]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 16:50:01 info /usr/sbin/cron[9755]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 16:50:01 info /usr/sbin/cron[9756]: (root) CMD (nethist_stats.lua)
2018-05-24 16:51:01 info /usr/sbin/cron[9882]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:51:01 info /usr/sbin/cron[9881]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:51:26 info ucollect[4497]: Sending 38 flows
2018-05-24 16:51:26 info ucollect[4497]: Sending 36 IPv4 refused connections and 0 IPv6 ones
2018-05-24 16:52:01 info /usr/sbin/cron[10021]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:52:01 info /usr/sbin/cron[10020]: (root) CMD (nethist_stats.lua)
2018-05-24 16:53:01 info /usr/sbin/cron[10122]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:54:01 info /usr/sbin/cron[10225]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:54:01 info /usr/sbin/cron[10226]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:54:01 info /usr/sbin/cron[10227]: (root) CMD (nethist_stats.lua)
2018-05-24 16:54:13 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.113 18:8e:d5:00:12:d0
2018-05-24 16:54:13 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.113 18:8e:d5:00:12:d0 TV_Philips_32PFL7406
2018-05-24 16:54:27 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 16:54:27 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 16:55:01 info /usr/sbin/cron[10367]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:55:01 info /usr/sbin/cron[10368]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 16:55:01 info /usr/sbin/cron[10369]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 16:56:01 info /usr/sbin/cron[10491]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:56:01 info /usr/sbin/cron[10492]: (root) CMD (nethist_stats.lua)
2018-05-24 16:57:01 info /usr/sbin/cron[10594]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 16:57:01 info /usr/sbin/cron[10595]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:57:28 info ucollect[4497]: Started task Ping as PID 10679 and fd 24
2018-05-24 16:57:40 info ucollect[4497]: Finished task Ping, success 1
2018-05-24 16:57:40 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 16:58:01 info /usr/sbin/cron[10738]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:58:01 info /usr/sbin/cron[10740]: (root) CMD (nethist_stats.lua)
2018-05-24 16:58:46 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 16:58:46 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 16:59:01 info /usr/sbin/cron[10844]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 16:59:03 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 16:59:03 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 16:59:44 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 16:59:44 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 17:00:01 info /usr/sbin/cron[10953]: (root) CMD (/usr/share/firewall/turris-download)
2018-05-24 17:00:01 info /usr/sbin/cron[10958]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 17:00:01 info /usr/sbin/cron[10949]: (root) CMD (/usr/bin/get-api-crl)
2018-05-24 17:00:01 info /usr/sbin/cron[10961]: (root) CMD (netmetr --autostart --dwlhist --rwait 1800 &)
2018-05-24 17:00:01 info /usr/sbin/cron[10959]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:00:01 info /usr/sbin/cron[10957]: (root) CMD (/usr/share/server-uplink/registration_code.sh)
2018-05-24 17:00:01 info /usr/sbin/cron[10966]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 17:00:01 info /usr/sbin/cron[10962]: (root) CMD (nethist_stats.lua)
2018-05-24 17:00:01 info /usr/sbin/cron[10968]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 17:00:01 info /usr/sbin/cron[10963]: (root) CMD (/usr/share/server-uplink/contract_valid.sh)
2018-05-24 17:00:01 info /usr/sbin/cron[10965]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:00:01 err server_uplink[]: Failed to download contract status
2018-05-24 17:00:03 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 17:00:52 info nikola[]: (v42) Establishing connection took 0.606147 seconds
2018-05-24 17:00:52 info nikola[]: (v42) Logrotate took 0.005153 seconds
2018-05-24 17:00:52 info nikola[]: (v42) Syslog parsing took 0.057527 seconds
2018-05-24 17:00:53 info nikola[]: (v42) Session init took 0.759110 seconds
2018-05-24 17:00:53 info nikola[]: (v42) Records parsed: 59
2018-05-24 17:00:53 info nikola[]: (v42) Records after filtering: 44
2018-05-24 17:00:53 info nikola[]: (v42) Records filtering took 0.011427 seconds
2018-05-24 17:00:53 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 17:00:53 info nikola[]: (v42) Sending records took 0.090679 seconds
2018-05-24 17:01:01 info /usr/sbin/cron[11197]: (root) CMD (majordomo_db.sh genhour)
2018-05-24 17:01:01 info /usr/sbin/cron[11196]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:01:46 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 17:01:46 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 17:02:01 err server_uplink[]: Failed to get registration code
2018-05-24 17:02:01 info /usr/sbin/cron[11342]: (root) CMD (nethist_stats.lua)
2018-05-24 17:02:01 info /usr/sbin/cron[11341]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:03:01 info /usr/sbin/cron[11442]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:03:01 info /usr/sbin/cron[11443]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:04:01 info /usr/sbin/cron[11583]: (root) CMD (majordomo_locked_precache.sh)
2018-05-24 17:04:01 info /usr/sbin/cron[11582]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:04:01 info /usr/sbin/cron[11584]: (root) CMD (nethist_stats.lua)
2018-05-24 17:05:01 info /usr/sbin/cron[12205]: (root) CMD (/usr/share/firewall/turris)
2018-05-24 17:05:01 info /usr/sbin/cron[12207]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:05:01 info /usr/sbin/cron[12210]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 17:05:01 info /usr/sbin/cron[12211]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 17:05:01 info turris-firewall-rules[]: (v63) IPv4 WAN interface used - 'eth1'
2018-05-24 17:05:01 info turris-firewall-rules[]: (v63) IPv6 WAN interface used - 'lo'
2018-05-24 17:05:02 info turris-firewall-rules[]: (v63) 3524 ipv4 address(es) and 3 ipv6 address(es) were loaded (c83b72d5b03454292e5000b3967bc350), 0 rule(s) overriden, 0 rule(s) skipped
2018-05-24 17:05:59 info ucollect[4497]: Updating filter addresses from version 50905770 to version 50905810 (epoch 4)
2018-05-24 17:06:01 info /usr/sbin/cron[13209]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:06:01 info /usr/sbin/cron[13210]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:06:01 info /usr/sbin/cron[13214]: (root) CMD (nethist_stats.lua)
2018-05-24 17:06:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905770 to version 50905810 (epoch 4)
2018-05-24 17:06:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 17:07:01 info /usr/sbin/cron[13722]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:08:01 info /usr/sbin/cron[13890]: (root) CMD (nethist_stats.lua)
2018-05-24 17:08:01 info /usr/sbin/cron[13889]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:09:01 info /usr/sbin/cron[14116]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:09:01 info /usr/sbin/cron[14118]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:09:13 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.113 18:8e:d5:00:12:d0
2018-05-24 17:09:13 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.113 18:8e:d5:00:12:d0 TV_Philips_32PFL7406
2018-05-24 17:09:29 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 17:09:29 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 17:10:01 info /usr/sbin/cron[14409]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:10:01 info /usr/sbin/cron[14412]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 17:10:01 info /usr/sbin/cron[14411]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 17:10:01 info /usr/sbin/cron[14413]: (root) CMD (nethist_stats.lua)
2018-05-24 17:11:01 info /usr/sbin/cron[14627]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:12:01 info /usr/sbin/cron[14832]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:12:01 info /usr/sbin/cron[14835]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:12:01 info /usr/sbin/cron[14834]: (root) CMD (/usr/sbin/logrotate -s /tmp/logrotate.state /etc/logrotate.conf)
2018-05-24 17:12:01 info /usr/sbin/cron[14836]: (root) CMD (nethist_stats.lua)
2018-05-24 17:12:31 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 17:12:31 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 17:13:01 info /usr/sbin/cron[15251]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:13:37 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 17:13:37 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 17:14:01 info /usr/sbin/cron[15608]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:14:01 info /usr/sbin/cron[15609]: (root) CMD (nethist_stats.lua)
2018-05-24 17:14:03 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 17:14:03 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 17:15:01 info /usr/sbin/cron[15946]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:15:01 info /usr/sbin/cron[15949]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:15:01 info /usr/sbin/cron[15951]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 17:15:01 info /usr/sbin/cron[15952]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 17:15:01 info /usr/sbin/cron[15953]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 17:15:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 17:15:26 info nikola[]: (v42) Establishing connection took 0.647823 seconds
2018-05-24 17:15:26 info nikola[]: (v42) Logrotate took 0.005230 seconds
2018-05-24 17:15:26 info nikola[]: (v42) Syslog parsing took 0.049458 seconds
2018-05-24 17:15:27 info nikola[]: (v42) Session init took 0.756569 seconds
2018-05-24 17:15:27 info nikola[]: (v42) Records parsed: 41
2018-05-24 17:15:27 info nikola[]: (v42) Records after filtering: 28
2018-05-24 17:15:27 info nikola[]: (v42) Records filtering took 0.009716 seconds
2018-05-24 17:15:27 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 17:15:27 info nikola[]: (v42) Sending records took 0.085047 seconds
2018-05-24 17:16:01 info /usr/sbin/cron[16302]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:16:01 info /usr/sbin/cron[16303]: (root) CMD (nethist_stats.lua)
2018-05-24 17:16:11 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 17:16:11 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 17:17:01 info /usr/sbin/cron[16519]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:18:01 info /usr/sbin/cron[16832]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:18:01 info /usr/sbin/cron[16833]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:18:01 info /usr/sbin/cron[16835]: (root) CMD (nethist_stats.lua)
2018-05-24 17:19:01 info /usr/sbin/cron[17127]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:20:01 info /usr/sbin/cron[17377]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 17:20:01 info /usr/sbin/cron[17378]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:20:01 info /usr/sbin/cron[17379]: (root) CMD (nethist_stats.lua)
2018-05-24 17:20:01 info /usr/sbin/cron[17380]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 17:21:01 info /usr/sbin/cron[17630]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:21:01 info /usr/sbin/cron[17631]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Global permanent pool: 3108/4096 (19)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Global batch pool: 0/4096 (0)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Global temporary pool: 156/4096 (3)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Buffer pool for uplink: 4/4096 (1)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Config pool: 4094/8192 (137)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Badconf: 48/4096 (1)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Bandwidth: 2744/4096 (6)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Count: 264/4096 (1)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Fake: 189120/217088 (161)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Fake log: 44/4096 (1)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Flow: 128/4096 (5)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Flow pool: 7496/8192 (156)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Flow conf pool: 844921/888832 (45165)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Fwup: 168/4096 (7)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 1: 0/4096 (0)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 2: 122611/131072 (6568)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Refused: 104/4096 (3)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Refuse pool 1: 0/4096 (0)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Refuse pool 2: 42297/45056 (1802)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Sniff: 44/4096 (3)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Sniffer pool: 0/4096 (0)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats: Spoof: 224/4096 (1)
2018-05-24 17:21:21 info ucollect[4497]: Mempool stats done
2018-05-24 17:21:26 info ucollect[4497]: Sending 46 flows
2018-05-24 17:21:26 info ucollect[4497]: Sending 27 IPv4 refused connections and 0 IPv6 ones
2018-05-24 17:22:01 info /usr/sbin/cron[18173]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:22:01 info /usr/sbin/cron[18174]: (root) CMD (nethist_stats.lua)
2018-05-24 17:23:01 info /usr/sbin/cron[18583]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:24:01 info /usr/sbin/cron[18787]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:24:01 info /usr/sbin/cron[18788]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:24:01 info /usr/sbin/cron[18790]: (root) CMD (nethist_stats.lua)
2018-05-24 17:24:13 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.113 18:8e:d5:00:12:d0
2018-05-24 17:24:13 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.113 18:8e:d5:00:12:d0 TV_Philips_32PFL7406
2018-05-24 17:24:31 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 17:24:31 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 17:25:01 info /usr/sbin/cron[19004]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:25:01 info /usr/sbin/cron[19005]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 17:25:01 info /usr/sbin/cron[19007]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 17:25:59 info ucollect[4497]: Updating filter addresses from version 50905810 to version 50905851 (epoch 4)
2018-05-24 17:26:01 info /usr/sbin/cron[19296]: (root) CMD (nethist_stats.lua)
2018-05-24 17:26:01 info /usr/sbin/cron[19295]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:26:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905810 to version 50905851 (epoch 4)
2018-05-24 17:26:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 17:26:31 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 17:26:31 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 17:27:01 info /usr/sbin/cron[19552]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:27:01 info /usr/sbin/cron[19554]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:28:01 info /usr/sbin/cron[19906]: (root) CMD (nethist_stats.lua)
2018-05-24 17:28:01 info /usr/sbin/cron[19905]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:29:01 info /usr/sbin/cron[20194]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:29:03 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 17:29:03 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 17:30:01 info /usr/sbin/cron[20429]: (root) CMD (/usr/bin/get-api-crl)
2018-05-24 17:30:01 info /usr/sbin/cron[20425]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:30:01 info /usr/sbin/cron[20435]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 17:30:01 info /usr/sbin/cron[20434]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 17:30:01 info /usr/sbin/cron[20436]: (root) CMD (nethist_stats.lua)
2018-05-24 17:30:01 info /usr/sbin/cron[20438]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:30:01 info /usr/sbin/cron[20440]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 17:30:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 17:30:13 info nikola[]: (v42) Establishing connection took 0.618665 seconds
2018-05-24 17:30:13 info nikola[]: (v42) Logrotate took 0.004754 seconds
2018-05-24 17:30:13 info nikola[]: (v42) Syslog parsing took 0.046963 seconds
2018-05-24 17:30:14 info nikola[]: (v42) Session init took 0.767560 seconds
2018-05-24 17:30:14 info nikola[]: (v42) Records parsed: 34
2018-05-24 17:30:14 info nikola[]: (v42) Records after filtering: 24
2018-05-24 17:30:14 info nikola[]: (v42) Records filtering took 0.008243 seconds
2018-05-24 17:30:14 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 17:30:14 info nikola[]: (v42) Sending records took 0.094556 seconds
2018-05-24 17:30:35 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 17:30:35 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 17:31:01 info /usr/sbin/cron[20707]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:32:01 info /usr/sbin/cron[21072]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:32:01 info /usr/sbin/cron[21073]: (root) CMD (nethist_stats.lua)
2018-05-24 17:33:01 info /usr/sbin/cron[21367]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:33:01 info /usr/sbin/cron[21369]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:34:01 info /usr/sbin/cron[21780]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:34:01 info /usr/sbin/cron[21781]: (root) CMD (nethist_stats.lua)
2018-05-24 17:34:20 info updater-supervisor[]: Running pkgupdate
2018-05-24 17:34:27 warning updater[21860]: planner.lua:344 (pkg_plan): Requested package luci-i18n-ddns-en that is missing, ignoring as requested.
2018-05-24 17:34:27 info updater-supervisor[]: pkgupdate reported no errors
2018-05-24 17:35:01 info /usr/sbin/cron[22136]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:35:01 info /usr/sbin/cron[22137]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 17:35:01 info /usr/sbin/cron[22141]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 17:36:01 info /usr/sbin/cron[22404]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:36:01 info /usr/sbin/cron[22405]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:36:01 info /usr/sbin/cron[22407]: (root) CMD (nethist_stats.lua)
2018-05-24 17:37:01 info /usr/sbin/cron[22952]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:38:02 info /usr/sbin/cron[23278]: (root) CMD (nethist_stats.lua)
2018-05-24 17:38:02 info /usr/sbin/cron[23277]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:38:02 info dnsmasq-dhcp[5601]: DHCPINFORM(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 17:38:02 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 17:39:01 info /usr/sbin/cron[23607]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:39:01 info /usr/sbin/cron[23608]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:39:13 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.113 18:8e:d5:00:12:d0
2018-05-24 17:39:13 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.113 18:8e:d5:00:12:d0 TV_Philips_32PFL7406
2018-05-24 17:39:33 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 17:39:33 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 17:40:01 info /usr/sbin/cron[23928]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:40:01 info /usr/sbin/cron[23930]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 17:40:01 info /usr/sbin/cron[23933]: (root) CMD (nethist_stats.lua)
2018-05-24 17:40:01 info /usr/sbin/cron[23934]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 17:40:28 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 17:40:28 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 17:41:01 info /usr/sbin/cron[24266]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:42:01 info /usr/sbin/cron[24580]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:42:01 info /usr/sbin/cron[24582]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:42:01 info /usr/sbin/cron[24583]: (root) CMD (nethist_stats.lua)
2018-05-24 17:43:01 info /usr/sbin/cron[24948]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:43:38 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 17:43:38 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 17:43:38 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 3 times, suppressed by syslog-ng on Omnia
2018-05-24 17:43:38 warning dhcp_host_domain_ng.py[]: Del_lease, hosname check failed
2018-05-24 17:43:38 info dhcp_host_domain_ng.py[]: DHCP delete hostname [del,Fujitsu_kuchyn,192.168.2.120]
2018-05-24 17:43:38 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 17:43:38 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 17:44:01 info /usr/sbin/cron[25327]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:44:01 info /usr/sbin/cron[25329]: (root) CMD (nethist_stats.lua)
2018-05-24 17:44:03 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 17:44:03 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 17:44:59 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 17:44:59 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 17:45:01 info /usr/sbin/cron[25758]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:45:01 info /usr/sbin/cron[25761]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:45:01 info /usr/sbin/cron[25763]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 17:45:01 info /usr/sbin/cron[25762]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 17:45:01 info /usr/sbin/cron[25764]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 17:45:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 17:45:35 info nikola[]: (v42) Establishing connection took 0.608034 seconds
2018-05-24 17:45:35 info nikola[]: (v42) Logrotate took 0.004827 seconds
2018-05-24 17:45:35 info nikola[]: (v42) Syslog parsing took 0.051188 seconds
2018-05-24 17:45:36 info nikola[]: (v42) Session init took 0.756100 seconds
2018-05-24 17:45:36 info nikola[]: (v42) Records parsed: 40
2018-05-24 17:45:36 info nikola[]: (v42) Records after filtering: 28
2018-05-24 17:45:36 info nikola[]: (v42) Records filtering took 0.009262 seconds
2018-05-24 17:45:36 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 17:45:36 info nikola[]: (v42) Sending records took 0.079441 seconds
2018-05-24 17:45:59 info ucollect[4497]: Updating filter addresses from version 50905851 to version 50905890 (epoch 4)
2018-05-24 17:46:01 info /usr/sbin/cron[26268]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:46:01 info /usr/sbin/cron[26269]: (root) CMD (nethist_stats.lua)
2018-05-24 17:46:03 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905851 to version 50905890 (epoch 4)
2018-05-24 17:46:08 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 17:47:01 info /usr/sbin/cron[26497]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:48:01 info /usr/sbin/cron[26743]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:48:01 info /usr/sbin/cron[26744]: (root) CMD (nethist_stats.lua)
2018-05-24 17:48:01 info /usr/sbin/cron[26742]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:49:01 info /usr/sbin/cron[27018]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:50:01 info /usr/sbin/cron[27122]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:50:01 info /usr/sbin/cron[27124]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 17:50:01 info /usr/sbin/cron[27126]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 17:50:01 info /usr/sbin/cron[27127]: (root) CMD (nethist_stats.lua)
2018-05-24 17:51:01 info /usr/sbin/cron[27253]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:51:01 info /usr/sbin/cron[27254]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:51:26 info ucollect[4497]: Sending 33 flows
2018-05-24 17:51:26 info ucollect[4497]: Sending 32 IPv4 refused connections and 0 IPv6 ones
2018-05-24 17:52:01 info /usr/sbin/cron[27395]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:52:01 info /usr/sbin/cron[27396]: (root) CMD (nethist_stats.lua)
2018-05-24 17:53:01 info /usr/sbin/cron[27494]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:54:01 info /usr/sbin/cron[27597]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:54:01 info /usr/sbin/cron[27598]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:54:01 info /usr/sbin/cron[27602]: (root) CMD (nethist_stats.lua)
2018-05-24 17:54:13 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.113 18:8e:d5:00:12:d0
2018-05-24 17:54:13 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.113 18:8e:d5:00:12:d0 TV_Philips_32PFL7406
2018-05-24 17:54:27 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 17:54:27 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 17:54:35 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 17:54:35 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 17:55:01 info /usr/sbin/cron[27740]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:55:01 info /usr/sbin/cron[27742]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 17:55:01 info /usr/sbin/cron[27744]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 17:56:01 info /usr/sbin/cron[27870]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:56:01 info /usr/sbin/cron[27873]: (root) CMD (nethist_stats.lua)
2018-05-24 17:57:01 info /usr/sbin/cron[27974]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:57:01 info /usr/sbin/cron[27973]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 17:58:01 info /usr/sbin/cron[28113]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:58:01 info /usr/sbin/cron[28114]: (root) CMD (nethist_stats.lua)
2018-05-24 17:59:01 info /usr/sbin/cron[28214]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 17:59:03 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 17:59:03 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 17:59:25 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 17:59:25 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 18:00:01 info /usr/sbin/cron[28324]: (root) CMD (/usr/bin/get-api-crl)
2018-05-24 18:00:01 info /usr/sbin/cron[28320]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:00:01 info /usr/sbin/cron[28334]: (root) CMD (nethist_stats.lua)
2018-05-24 18:00:01 info /usr/sbin/cron[28331]: (root) CMD (/usr/share/server-uplink/registration_code.sh)
2018-05-24 18:00:01 info /usr/sbin/cron[28336]: (root) CMD (/usr/share/server-uplink/contract_valid.sh)
2018-05-24 18:00:01 info /usr/sbin/cron[28335]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 18:00:01 info /usr/sbin/cron[28339]: (root) CMD (/usr/share/firewall/turris-download)
2018-05-24 18:00:01 info /usr/sbin/cron[28337]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 18:00:01 info /usr/sbin/cron[28342]: (root) CMD (netmetr --autostart --dwlhist --rwait 1800 &)
2018-05-24 18:00:01 info /usr/sbin/cron[28341]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:00:01 info /usr/sbin/cron[28346]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 18:00:02 err server_uplink[]: Failed to download contract status
2018-05-24 18:00:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 18:00:15 err server_uplink[]: Failed to get registration code
2018-05-24 18:00:21 info nikola[]: (v42) Establishing connection took 2.389526 seconds
2018-05-24 18:00:21 info nikola[]: (v42) Logrotate took 0.004792 seconds
2018-05-24 18:00:21 info nikola[]: (v42) Syslog parsing took 0.044072 seconds
2018-05-24 18:00:22 info nikola[]: (v42) Session init took 0.849230 seconds
2018-05-24 18:00:22 info nikola[]: (v42) Records parsed: 26
2018-05-24 18:00:22 info nikola[]: (v42) Records after filtering: 16
2018-05-24 18:00:22 info nikola[]: (v42) Records filtering took 0.020189 seconds
2018-05-24 18:00:22 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 18:00:22 info nikola[]: (v42) Sending records took 0.174543 seconds
2018-05-24 18:01:01 info /usr/sbin/cron[28571]: (root) CMD (majordomo_db.sh genhour)
2018-05-24 18:01:01 info /usr/sbin/cron[28570]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:01:01 info /usr/sbin/cron[28572]: (root) CMD ((cat /tmp/nethist.stats | sort ; echo "uptime = $(cat /proc/uptime | cut -d. -f1)" ) | logger -p info -t nethist ; rm /tmp/nethist.stats)
2018-05-24 18:01:01 info nethist[]: fs_avg = 26096054.876902
2018-05-24 18:01:01 info nethist[]: fs_max = 26096536
2018-05-24 18:01:01 info nethist[]: fs_min = 26095888
2018-05-24 18:01:01 info nethist[]: fs_samples = 1446
2018-05-24 18:01:01 info nethist[]: fs_sum = 37734895352
2018-05-24 18:01:01 info nethist[]: last_timestamp = 1527177592
2018-05-24 18:01:01 info nethist[]: load_avg = 0.22908022130014
2018-05-24 18:01:01 info nethist[]: load_max = 1.5
2018-05-24 18:01:01 info nethist[]: load_min = 0.07
2018-05-24 18:01:01 info nethist[]: load_samples = 1446
2018-05-24 18:01:01 info nethist[]: load_sum = 331.25
2018-05-24 18:01:02 info nethist[]: mem_buffers_avg = 722477.56846473
2018-05-24 18:01:02 info nethist[]: mem_buffers_max = 738092
2018-05-24 18:01:02 info nethist[]: mem_buffers_min = 686216
2018-05-24 18:01:02 info nethist[]: mem_buffers_samples = 1446
2018-05-24 18:01:02 info nethist[]: mem_buffers_sum = 1044702564
2018-05-24 18:01:02 info nethist[]: mem_cached_avg = 2683.051175657
2018-05-24 18:01:02 info nethist[]: mem_cached_max = 3156
2018-05-24 18:01:02 info nethist[]: mem_cached_min = 1052
2018-05-24 18:01:02 info nethist[]: mem_cached_samples = 1446
2018-05-24 18:01:02 info nethist[]: mem_cached_sum = 3879692
2018-05-24 18:01:02 info nethist[]: mem_free_avg = 277811.72337483
2018-05-24 18:01:02 info nethist[]: mem_free_max = 334272
2018-05-24 18:01:02 info nethist[]: mem_free_min = 186084
2018-05-24 18:01:02 info nethist[]: mem_free_samples = 1446
2018-05-24 18:01:02 info nethist[]: mem_free_sum = 401715752
2018-05-24 18:01:02 info nethist[]: mem_total_avg = 1030984
2018-05-24 18:01:02 info nethist[]: mem_total_max = 1030984
2018-05-24 18:01:02 info nethist[]: mem_total_min = 1030984
2018-05-24 18:01:02 info nethist[]: mem_total_samples = 1446
2018-05-24 18:01:02 info nethist[]: mem_total_sum = 1490802864
2018-05-24 18:01:02 info nethist[]: temp_board_avg = nan
2018-05-24 18:01:02 info nethist[]: temp_board_max = 0
2018-05-24 18:01:02 info nethist[]: temp_board_samples = 0
2018-05-24 18:01:02 info nethist[]: temp_board_sum = 0
2018-05-24 18:01:02 info nethist[]: temp_cpu_avg = nan
2018-05-24 18:01:02 info nethist[]: temp_cpu_max = 0
2018-05-24 18:01:02 info nethist[]: temp_cpu_samples = 0
2018-05-24 18:01:02 info nethist[]: temp_cpu_sum = 0
2018-05-24 18:01:02 info nethist[]: uptime = 168023
2018-05-24 18:02:01 info /usr/sbin/cron[28722]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:02:01 info /usr/sbin/cron[28723]: (root) CMD (nethist_stats.lua)
2018-05-24 18:03:01 info /usr/sbin/cron[28826]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:03:01 info /usr/sbin/cron[28827]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:04:01 info /usr/sbin/cron[28967]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:04:01 info /usr/sbin/cron[28968]: (root) CMD (majordomo_locked_precache.sh)
2018-05-24 18:04:02 info /usr/sbin/cron[28972]: (root) CMD (nethist_stats.lua)
2018-05-24 18:05:01 info /usr/sbin/cron[29555]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:05:01 info /usr/sbin/cron[29554]: (root) CMD (/usr/share/firewall/turris)
2018-05-24 18:05:01 info /usr/sbin/cron[29556]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 18:05:01 info /usr/sbin/cron[29557]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 18:05:01 info turris-firewall-rules[]: (v63) IPv4 WAN interface used - 'eth1'
2018-05-24 18:05:01 info turris-firewall-rules[]: (v63) IPv6 WAN interface used - 'lo'
2018-05-24 18:05:02 info turris-firewall-rules[]: (v63) 3524 ipv4 address(es) and 3 ipv6 address(es) were loaded (c83b72d5b03454292e5000b3967bc350), 0 rule(s) overriden, 0 rule(s) skipped
2018-05-24 18:05:59 info ucollect[4497]: Updating filter addresses from version 50905890 to version 50905931 (epoch 4)
2018-05-24 18:06:01 info /usr/sbin/cron[30354]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:06:01 info /usr/sbin/cron[30355]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:06:01 info /usr/sbin/cron[30356]: (root) CMD (nethist_stats.lua)
2018-05-24 18:06:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905890 to version 50905931 (epoch 4)
2018-05-24 18:06:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 18:07:01 info /usr/sbin/cron[30812]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:07:42 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 18:07:42 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 18:08:01 info /usr/sbin/cron[30989]: (root) CMD (nethist_stats.lua)
2018-05-24 18:08:01 info /usr/sbin/cron[30988]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:09:01 info /usr/sbin/cron[31204]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:09:01 info /usr/sbin/cron[31205]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:09:14 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.113 18:8e:d5:00:12:d0
2018-05-24 18:09:14 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.113 18:8e:d5:00:12:d0 TV_Philips_32PFL7406
2018-05-24 18:09:37 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 18:09:37 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 18:10:01 info /usr/sbin/cron[31508]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 18:10:01 info /usr/sbin/cron[31506]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:10:01 info /usr/sbin/cron[31510]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 18:10:01 info /usr/sbin/cron[31511]: (root) CMD (nethist_stats.lua)
2018-05-24 18:11:01 info /usr/sbin/cron[31720]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:12:01 info /usr/sbin/cron[31925]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:12:01 info /usr/sbin/cron[31929]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:12:01 info /usr/sbin/cron[31927]: (root) CMD (nethist_stats.lua)
2018-05-24 18:12:01 info /usr/sbin/cron[31928]: (root) CMD (/usr/sbin/logrotate -s /tmp/logrotate.state /etc/logrotate.conf)
2018-05-24 18:13:01 info /usr/sbin/cron[32343]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:13:50 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 18:13:50 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 18:14:01 info /usr/sbin/cron[32666]: (root) CMD (nethist_stats.lua)
2018-05-24 18:14:01 info /usr/sbin/cron[32667]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:14:03 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 18:14:03 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 18:15:01 info /usr/sbin/cron[614]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:15:01 info /usr/sbin/cron[617]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:15:01 info /usr/sbin/cron[619]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 18:15:01 info /usr/sbin/cron[621]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 18:15:01 info /usr/sbin/cron[622]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 18:15:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 18:15:44 info nikola[]: (v42) Establishing connection took 0.684176 seconds
2018-05-24 18:15:44 info nikola[]: (v42) Logrotate took 0.004674 seconds
2018-05-24 18:15:44 info nikola[]: (v42) Syslog parsing took 0.044123 seconds
2018-05-24 18:15:45 info nikola[]: (v42) Session init took 0.765511 seconds
2018-05-24 18:15:45 info nikola[]: (v42) Records parsed: 35
2018-05-24 18:15:45 info nikola[]: (v42) Records after filtering: 22
2018-05-24 18:15:45 info nikola[]: (v42) Records filtering took 0.008682 seconds
2018-05-24 18:15:45 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 18:15:45 info nikola[]: (v42) Sending records took 0.083888 seconds
2018-05-24 18:16:01 info /usr/sbin/cron[955]: (root) CMD (nethist_stats.lua)
2018-05-24 18:16:01 info /usr/sbin/cron[954]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:17:01 info /usr/sbin/cron[1219]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:18:01 info /usr/sbin/cron[1440]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:18:01 info /usr/sbin/cron[1442]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:18:01 info /usr/sbin/cron[1444]: (root) CMD (nethist_stats.lua)
2018-05-24 18:19:01 info /usr/sbin/cron[1758]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:20:01 info /usr/sbin/cron[2058]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:20:01 info /usr/sbin/cron[2060]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 18:20:01 info /usr/sbin/cron[2061]: (root) CMD (nethist_stats.lua)
2018-05-24 18:20:01 info /usr/sbin/cron[2062]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 18:21:01 info /usr/sbin/cron[2304]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:21:01 info /usr/sbin/cron[2305]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Global permanent pool: 3108/4096 (19)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Global batch pool: 0/4096 (0)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Global temporary pool: 156/4096 (3)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Buffer pool for uplink: 4/4096 (1)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Config pool: 4094/8192 (137)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Badconf: 48/4096 (1)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Bandwidth: 2744/4096 (6)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Count: 264/4096 (1)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Fake: 189120/217088 (161)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Fake log: 989/4096 (42)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Flow: 128/4096 (5)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Flow pool: 5443/8192 (112)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Flow conf pool: 845592/888832 (45203)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Fwup: 168/4096 (7)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 1: 0/4096 (0)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 2: 123140/131072 (6595)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Refused: 104/4096 (3)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Refuse pool 1: 0/4096 (0)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Refuse pool 2: 30895/32768 (1320)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Sniff: 44/4096 (3)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Sniffer pool: 0/4096 (0)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats: Spoof: 224/4096 (1)
2018-05-24 18:21:21 info ucollect[4497]: Mempool stats done
2018-05-24 18:21:26 info ucollect[4497]: Sending 34 flows
2018-05-24 18:21:26 info ucollect[4497]: Sending 32 IPv4 refused connections and 0 IPv6 ones
2018-05-24 18:21:41 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 18:21:41 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 18:22:01 info /usr/sbin/cron[2772]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:22:01 info /usr/sbin/cron[2773]: (root) CMD (nethist_stats.lua)
2018-05-24 18:23:01 info /usr/sbin/cron[3279]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:24:01 info /usr/sbin/cron[3485]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:24:01 info /usr/sbin/cron[3486]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:24:01 info /usr/sbin/cron[3490]: (root) CMD (nethist_stats.lua)
2018-05-24 18:24:14 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.113 18:8e:d5:00:12:d0
2018-05-24 18:24:14 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.113 18:8e:d5:00:12:d0 TV_Philips_32PFL7406
2018-05-24 18:24:39 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 18:24:39 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 18:25:01 info /usr/sbin/cron[3710]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:25:01 info /usr/sbin/cron[3713]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 18:25:01 info /usr/sbin/cron[3711]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 18:25:59 info ucollect[4497]: Updating filter addresses from version 50905931 to version 50905971 (epoch 4)
2018-05-24 18:26:01 info /usr/sbin/cron[3951]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:26:01 info /usr/sbin/cron[3952]: (root) CMD (nethist_stats.lua)
2018-05-24 18:26:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905931 to version 50905971 (epoch 4)
2018-05-24 18:26:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 18:27:01 info /usr/sbin/cron[4221]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:27:01 info /usr/sbin/cron[4222]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:28:01 info /usr/sbin/cron[4602]: (root) CMD (nethist_stats.lua)
2018-05-24 18:28:01 info /usr/sbin/cron[4601]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:28:15 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 18:28:15 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 18:29:01 info /usr/sbin/cron[4849]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:29:03 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 18:29:03 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 18:30:01 info /usr/sbin/cron[5116]: (root) CMD (/usr/bin/get-api-crl)
2018-05-24 18:30:01 info /usr/sbin/cron[5119]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 18:30:01 info /usr/sbin/cron[5121]: (root) CMD (nethist_stats.lua)
2018-05-24 18:30:01 info /usr/sbin/cron[5122]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 18:30:01 info /usr/sbin/cron[5112]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:30:01 info /usr/sbin/cron[5123]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:30:01 info /usr/sbin/cron[5126]: (root) CMD (/usr/share/haas/register.sh)
2018-05-24 18:30:01 info /usr/sbin/cron[5125]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 18:30:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 18:30:40 info nikola[]: (v42) Establishing connection took 0.610314 seconds
2018-05-24 18:30:40 info nikola[]: (v42) Logrotate took 0.004902 seconds
2018-05-24 18:30:40 info nikola[]: (v42) Syslog parsing took 0.056417 seconds
2018-05-24 18:30:41 info nikola[]: (v42) Session init took 0.769439 seconds
2018-05-24 18:30:41 info nikola[]: (v42) Records parsed: 53
2018-05-24 18:30:41 info nikola[]: (v42) Records after filtering: 39
2018-05-24 18:30:41 info nikola[]: (v42) Records filtering took 0.010516 seconds
2018-05-24 18:30:41 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 18:30:41 info nikola[]: (v42) Sending records took 0.087524 seconds
2018-05-24 18:31:01 info /usr/sbin/cron[5439]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:32:01 info /usr/sbin/cron[5747]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:32:01 info /usr/sbin/cron[5749]: (root) CMD (nethist_stats.lua)
2018-05-24 18:33:01 info /usr/sbin/cron[6112]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:33:01 info /usr/sbin/cron[6111]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:34:01 info /usr/sbin/cron[6349]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:34:01 info /usr/sbin/cron[6351]: (root) CMD (nethist_stats.lua)
2018-05-24 18:35:01 info /usr/sbin/cron[6758]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:35:01 info /usr/sbin/cron[6760]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 18:35:01 info /usr/sbin/cron[6759]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 18:35:08 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 18:35:08 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 18:36:01 info /usr/sbin/cron[7068]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:36:01 info /usr/sbin/cron[7067]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:36:01 info /usr/sbin/cron[7071]: (root) CMD (nethist_stats.lua)
2018-05-24 18:37:01 info /usr/sbin/cron[7446]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:37:43 info hostapd[]: wlan0: STA bc:76:5e:28:f9:75 IEEE 802.11: authenticated
2018-05-24 18:37:43 info hostapd[]: wlan0: STA bc:76:5e:28:f9:75 IEEE 802.11: associated (aid 1)
2018-05-24 18:37:43 info hostapd[]: wlan0: STA bc:76:5e:28:f9:75 RADIUS: starting accounting session CD00EB2DFBEE7725
2018-05-24 18:37:43 info hostapd[]: wlan0: STA bc:76:5e:28:f9:75 WPA: pairwise key handshake completed (RSN)
2018-05-24 18:37:43 info dnsmasq-dhcp[5601]: DHCPDISCOVER(br-lan) bc:76:5e:28:f9:75
2018-05-24 18:37:43 info dnsmasq-dhcp[5601]: DHCPOFFER(br-lan) 192.168.2.106 bc:76:5e:28:f9:75
2018-05-24 18:37:43 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.106 bc:76:5e:28:f9:75
2018-05-24 18:37:43 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.106 bc:76:5e:28:f9:75 Tablet_Jarda
2018-05-24 18:37:43 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 18:37:43 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 18:37:43 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 5 times, suppressed by syslog-ng on Omnia
2018-05-24 18:37:43 info dhcp_host_domain_ng.py[]: DHCP add new hostname [Tablet_Jarda,192.168.2.106]
2018-05-24 18:37:43 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 18:37:44 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 18:38:01 info /usr/sbin/cron[7921]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:38:01 info /usr/sbin/cron[7922]: (root) CMD (nethist_stats.lua)
2018-05-24 18:38:02 info dnsmasq-dhcp[5601]: DHCPINFORM(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 18:38:02 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 18:39:01 info /usr/sbin/cron[8180]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:39:01 info /usr/sbin/cron[8179]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:39:14 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.113 18:8e:d5:00:12:d0
2018-05-24 18:39:14 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.113 18:8e:d5:00:12:d0 TV_Philips_32PFL7406
2018-05-24 18:39:41 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 18:39:41 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 18:40:01 info /usr/sbin/cron[8479]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:40:01 info /usr/sbin/cron[8481]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 18:40:01 info /usr/sbin/cron[8484]: (root) CMD (nethist_stats.lua)
2018-05-24 18:40:01 info /usr/sbin/cron[8485]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 18:41:01 info /usr/sbin/cron[8881]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:42:01 info /usr/sbin/cron[9197]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:42:01 info /usr/sbin/cron[9200]: (root) CMD (nethist_stats.lua)
2018-05-24 18:42:01 info /usr/sbin/cron[9198]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:42:40 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 18:42:40 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 18:43:01 info /usr/sbin/cron[9573]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:44:01 info /usr/sbin/cron[9912]: (root) CMD (nethist_stats.lua)
2018-05-24 18:44:01 info /usr/sbin/cron[9911]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:44:03 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 18:44:03 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 18:45:01 info /usr/sbin/cron[10313]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:45:01 info /usr/sbin/cron[10316]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:45:01 info /usr/sbin/cron[10320]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 18:45:01 info /usr/sbin/cron[10322]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 18:45:01 info /usr/sbin/cron[10318]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 18:45:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 18:45:06 info nikola[]: (v42) Establishing connection took 0.613222 seconds
2018-05-24 18:45:06 info nikola[]: (v42) Logrotate took 0.004735 seconds
2018-05-24 18:45:06 info nikola[]: (v42) Syslog parsing took 0.049458 seconds
2018-05-24 18:45:06 info nikola[]: (v42) Session init took 0.816028 seconds
2018-05-24 18:45:06 info nikola[]: (v42) Records parsed: 44
2018-05-24 18:45:06 info nikola[]: (v42) Records after filtering: 33
2018-05-24 18:45:06 info nikola[]: (v42) Records filtering took 0.009807 seconds
2018-05-24 18:45:07 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 18:45:07 info nikola[]: (v42) Sending records took 0.089393 seconds
2018-05-24 18:45:59 info ucollect[4497]: Updating filter addresses from version 50905971 to version 50906011 (epoch 4)
2018-05-24 18:46:01 info /usr/sbin/cron[10776]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:46:01 info /usr/sbin/cron[10777]: (root) CMD (nethist_stats.lua)
2018-05-24 18:46:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50905971 to version 50906011 (epoch 4)
2018-05-24 18:46:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 18:47:01 info /usr/sbin/cron[11133]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:48:01 info /usr/sbin/cron[11361]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:48:01 info /usr/sbin/cron[11363]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:48:01 info /usr/sbin/cron[11364]: (root) CMD (nethist_stats.lua)
2018-05-24 18:49:01 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 18:49:01 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 18:49:01 info /usr/sbin/cron[11672]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:50:01 info /usr/sbin/cron[11773]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:50:01 info /usr/sbin/cron[11779]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 18:50:01 info /usr/sbin/cron[11775]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 18:50:01 info /usr/sbin/cron[11778]: (root) CMD (nethist_stats.lua)
2018-05-24 18:51:01 info /usr/sbin/cron[11904]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:51:01 info /usr/sbin/cron[11905]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:51:26 info ucollect[4497]: Sending 46 flows
2018-05-24 18:51:26 info ucollect[4497]: Sending 34 IPv4 refused connections and 0 IPv6 ones
2018-05-24 18:52:01 info /usr/sbin/cron[12046]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:52:01 info /usr/sbin/cron[12047]: (root) CMD (nethist_stats.lua)
2018-05-24 18:52:07 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.106 bc:76:5e:28:f9:75
2018-05-24 18:52:07 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.106 bc:76:5e:28:f9:75 Tablet_Jarda
2018-05-24 18:53:01 info /usr/sbin/cron[12145]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:54:01 info /usr/sbin/cron[12255]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:54:01 info /usr/sbin/cron[12257]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:54:01 info /usr/sbin/cron[12258]: (root) CMD (nethist_stats.lua)
2018-05-24 18:54:14 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.113 18:8e:d5:00:12:d0
2018-05-24 18:54:14 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.113 18:8e:d5:00:12:d0 TV_Philips_32PFL7406
2018-05-24 18:54:43 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 18:54:43 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 18:55:01 info /usr/sbin/cron[12398]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 18:55:01 info /usr/sbin/cron[12397]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 18:55:01 info /usr/sbin/cron[12396]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:56:01 info /usr/sbin/cron[12522]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:56:01 info /usr/sbin/cron[12523]: (root) CMD (nethist_stats.lua)
2018-05-24 18:57:01 info /usr/sbin/cron[12623]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 18:57:01 info /usr/sbin/cron[12625]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:57:04 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 18:57:04 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 18:58:01 info /usr/sbin/cron[12759]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:58:01 info /usr/sbin/cron[12760]: (root) CMD (nethist_stats.lua)
2018-05-24 18:58:10 info dnsmasq-dhcp[5601]: DHCPDISCOVER(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 18:58:10 info dnsmasq-dhcp[5601]: DHCPOFFER(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 18:58:10 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 18:58:10 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 18:58:10 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 18:58:10 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 18:58:10 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 6 times, suppressed by syslog-ng on Omnia
2018-05-24 18:58:10 info dhcp_host_domain_ng.py[]: DHCP add new hostname [Fujitsu_kuchyn,192.168.2.120]
2018-05-24 18:58:10 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 18:58:10 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 18:59:01 info /usr/sbin/cron[12867]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 18:59:03 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 18:59:03 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 19:00:01 info /usr/sbin/cron[13004]: (root) CMD (rainbow intensity 6)
2018-05-24 19:00:01 info /usr/sbin/cron[13011]: (root) CMD (/usr/share/firewall/turris-download)
2018-05-24 19:00:01 info /usr/sbin/cron[13012]: (root) CMD (/usr/bin/get-api-crl)
2018-05-24 19:00:01 info /usr/sbin/cron[13014]: (root) CMD (/usr/share/server-uplink/contract_valid.sh)
2018-05-24 19:00:01 info /usr/sbin/cron[12999]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 19:00:01 info /usr/sbin/cron[13017]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:00:01 info /usr/sbin/cron[13018]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 19:00:01 info /usr/sbin/cron[13019]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 19:00:01 info /usr/sbin/cron[13010]: (root) CMD (nethist_stats.lua)
2018-05-24 19:00:01 info /usr/sbin/cron[13022]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 19:00:01 info /usr/sbin/cron[13024]: (root) CMD (/usr/share/server-uplink/registration_code.sh)
2018-05-24 19:00:01 info /usr/sbin/cron[13025]: (root) CMD (netmetr --autostart --dwlhist --rwait 1800 &)
2018-05-24 19:00:01 err server_uplink[]: Failed to download contract status
2018-05-24 19:00:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 19:00:11 err nikola[]: (v42) Exception thrown: failed to initialize crypto library
2018-05-24 19:00:11 err nikola[]: (v42) Exception traceback: [('/usr/bin/nikola', 181, '<module>', 'server = WrappedServer(server_address, ssl_context=ssl_context)'), ('/usr/lib/python2.7/site-packages/nikola/rpc_wrapper.py', 30, '__init__', 'self.serial = binascii.hexlify(serial if serial else atsha204.get_serial())')]
2018-05-24 19:00:17 err server_uplink[]: Failed to get registration code
2018-05-24 19:01:01 info /usr/sbin/cron[13232]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:01:01 info /usr/sbin/cron[13233]: (root) CMD (majordomo_db.sh genhour)
2018-05-24 19:01:47 info dnsmasq-dhcp[5601]: DHCPINFORM(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 19:01:47 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 19:02:01 info /usr/sbin/cron[13374]: (root) CMD (nethist_stats.lua)
2018-05-24 19:02:01 info /usr/sbin/cron[13373]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:02:08 err turris-firewall-rules[]: (v63) Failed to download https://api.turris.cz/firewall/turris-ipsets.gz.sign
2018-05-24 19:03:01 info /usr/sbin/cron[13482]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:03:01 info /usr/sbin/cron[13481]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 19:03:05 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 19:03:05 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 19:04:01 info /usr/sbin/cron[13620]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:04:01 info /usr/sbin/cron[13621]: (root) CMD (majordomo_locked_precache.sh)
2018-05-24 19:04:01 info /usr/sbin/cron[13625]: (root) CMD (nethist_stats.lua)
2018-05-24 19:05:01 info /usr/sbin/cron[14245]: (root) CMD (/usr/share/firewall/turris)
2018-05-24 19:05:01 info /usr/sbin/cron[14247]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:05:01 info /usr/sbin/cron[14248]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 19:05:01 info /usr/sbin/cron[14249]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 19:05:01 info turris-firewall-rules[]: (v63) IPv4 WAN interface used - 'eth1'
2018-05-24 19:05:01 info turris-firewall-rules[]: (v63) IPv6 WAN interface used - 'lo'
2018-05-24 19:05:02 info turris-firewall-rules[]: (v63) 3524 ipv4 address(es) and 3 ipv6 address(es) were loaded (c83b72d5b03454292e5000b3967bc350), 0 rule(s) overriden, 0 rule(s) skipped
2018-05-24 19:05:59 info ucollect[4497]: Updating filter addresses from version 50906011 to version 50906051 (epoch 4)
2018-05-24 19:06:01 info /usr/sbin/cron[15013]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 19:06:01 info /usr/sbin/cron[15015]: (root) CMD (nethist_stats.lua)
2018-05-24 19:06:01 info /usr/sbin/cron[15014]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:06:02 info ucollect[4497]: Updating ipset turris_100FA4E0_lb_a_4_X from version 50906011 to version 50906051 (epoch 4)
2018-05-24 19:06:07 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 19:07:01 info /usr/sbin/cron[15470]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:08:01 info /usr/sbin/cron[15648]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:08:01 info /usr/sbin/cron[15649]: (root) CMD (nethist_stats.lua)
2018-05-24 19:09:01 info /usr/sbin/cron[15877]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 19:09:01 info /usr/sbin/cron[15878]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:09:14 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.113 18:8e:d5:00:12:d0
2018-05-24 19:09:14 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.113 18:8e:d5:00:12:d0 TV_Philips_32PFL7406
2018-05-24 19:09:44 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 19:09:44 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 19:10:01 info /usr/sbin/cron[16159]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:10:01 info /usr/sbin/cron[16160]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 19:10:01 info /usr/sbin/cron[16163]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 19:10:01 info /usr/sbin/cron[16164]: (root) CMD (nethist_stats.lua)
2018-05-24 19:11:01 info /usr/sbin/cron[16385]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:11:28 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 19:11:28 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d Tablet_Jirina
2018-05-24 19:12:01 info /usr/sbin/cron[16584]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 19:12:01 info /usr/sbin/cron[16586]: (root) CMD (/usr/sbin/logrotate -s /tmp/logrotate.state /etc/logrotate.conf)
2018-05-24 19:12:01 info /usr/sbin/cron[16589]: (root) CMD (nethist_stats.lua)
2018-05-24 19:12:01 info /usr/sbin/cron[16590]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:13:01 info /usr/sbin/cron[17009]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:13:09 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.120 00:19:99:f9:40:18
2018-05-24 19:13:09 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.120 00:19:99:f9:40:18 Fujitsu_kuchyn
2018-05-24 19:14:01 info /usr/sbin/cron[17326]: (root) CMD (nethist_stats.lua)
2018-05-24 19:14:01 info /usr/sbin/cron[17325]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:14:03 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4
2018-05-24 19:14:03 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.118 b0:e8:92:37:5f:b4 Epson_XP-700_printer
2018-05-24 19:15:01 info /usr/sbin/cron[17683]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 19:15:01 info /usr/sbin/cron[17687]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 19:15:01 info /usr/sbin/cron[17689]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 19:15:01 info /usr/sbin/cron[17686]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2018-05-24 19:15:01 info /usr/sbin/cron[17692]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:15:02 info nikola[]: (v42) recognized WAN interfaces: eth1, lo
2018-05-24 19:15:26 info nikola[]: (v42) Establishing connection took 0.659920 seconds
2018-05-24 19:15:26 info nikola[]: (v42) Logrotate took 0.004745 seconds
2018-05-24 19:15:26 info nikola[]: (v42) Syslog parsing took 0.077994 seconds
2018-05-24 19:15:27 info nikola[]: (v42) Session init took 0.767753 seconds
2018-05-24 19:15:27 info nikola[]: (v42) Records parsed: 87
2018-05-24 19:15:27 info nikola[]: (v42) Records after filtering: 62
2018-05-24 19:15:27 info nikola[]: (v42) Records filtering took 0.012715 seconds
2018-05-24 19:15:27 info nikola[]: (v42) {u'msg': u'Data were inserted into work queue.'}
2018-05-24 19:15:27 info nikola[]: (v42) Sending records took 0.051738 seconds
2018-05-24 19:16:01 info /usr/sbin/cron[18050]: (root) CMD (nethist_stats.lua)
2018-05-24 19:16:01 info /usr/sbin/cron[18049]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:16:37 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.114 50:af:73:14:b6:58
2018-05-24 19:16:37 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.114 50:af:73:14:b6:58 Forex
2018-05-24 19:17:01 info /usr/sbin/cron[18272]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:18:01 info /usr/sbin/cron[18483]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 19:18:01 info /usr/sbin/cron[18485]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:18:01 info /usr/sbin/cron[18486]: (root) CMD (nethist_stats.lua)
2018-05-24 19:19:01 info /usr/sbin/cron[18847]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:20:01 info /usr/sbin/cron[19124]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:20:01 info /usr/sbin/cron[19123]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 19:20:01 info /usr/sbin/cron[19129]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 19:20:01 info /usr/sbin/cron[19128]: (root) CMD (nethist_stats.lua)
2018-05-24 19:21:01 info /usr/sbin/cron[19385]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:21:01 info /usr/sbin/cron[19384]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Global permanent pool: 3108/4096 (19)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Global batch pool: 0/4096 (0)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Global temporary pool: 156/4096 (3)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Buffer pool for uplink: 4/4096 (1)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Config pool: 4094/8192 (137)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Badconf: 48/4096 (1)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Bandwidth: 2744/4096 (6)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Count: 264/4096 (1)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Fake: 189120/217088 (161)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Fake log: 1075/4096 (44)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Flow: 128/4096 (5)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Flow pool: 9753/12288 (202)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Flow conf pool: 846925/888832 (45274)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Fwup: 168/4096 (7)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 1: 0/4096 (0)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: FWUp set pool 2: 123615/131072 (6621)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Refused: 104/4096 (3)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Refuse pool 1: 0/4096 (0)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Refuse pool 2: 71666/73728 (3038)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Sniff: 44/4096 (3)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Sniffer pool: 0/4096 (0)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats: Spoof: 224/4096 (1)
2018-05-24 19:21:21 info ucollect[4497]: Mempool stats done
2018-05-24 19:21:24 info hostapd[]: wlan0: STA c0:11:73:18:3f:8d WPA: group key handshake completed (RSN)
2018-05-24 19:21:26 info ucollect[4497]: Sending 61 flows
2018-05-24 19:21:26 info ucollect[4497]: Sending 39 IPv4 refused connections and 0 IPv6 ones
2018-05-24 19:22:01 info /usr/sbin/cron[19884]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:22:01 info /usr/sbin/cron[19885]: (root) CMD (nethist_stats.lua)
2018-05-24 19:22:08 info dhcp_host_domain_ng.py[]: DHCPv4 new lease
2018-05-24 19:22:08 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 19:22:08 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 4 times, suppressed by syslog-ng on Omnia
2018-05-24 19:22:08 warning dhcp_host_domain_ng.py[]: Del_lease, hosname check failed
2018-05-24 19:22:08 info dhcp_host_domain_ng.py[]: DHCP delete hostname [del,Tablet_Jarda,192.168.2.106]
2018-05-24 19:22:08 debug dnsmasq-script[5601]: uci: Entry not found
2018-05-24 19:22:08 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 19:23:01 info /usr/sbin/cron[20100]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:23:11 warning []: Unable to use //tmp//yin2yang.xsl (No such file or directory).
2018-05-24 19:23:11 warning []: YANG format data models will not be available via get-schema.
2018-05-24 19:23:11 warning []: Unable to get tty (Not a tty) to get the client's hostname (session 20139).
2018-05-24 19:23:31 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2018-05-24 19:23:31 warning dhcp_host_domain_ng.py[16404]: Last message 'Add_lease, hostname ' repeated 4 times, suppressed by syslog-ng on Omnia
2018-05-24 19:23:31 info dhcp_host_domain_ng.py[]: Refresh kresd leases
2018-05-24 19:24:01 info /usr/sbin/cron[20392]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-05-24 19:24:01 info /usr/sbin/cron[20393]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:24:01 info /usr/sbin/cron[20394]: (root) CMD (nethist_stats.lua)
2018-05-24 19:24:14 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.113 18:8e:d5:00:12:d0
2018-05-24 19:24:14 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.113 18:8e:d5:00:12:d0 TV_Philips_32PFL7406
2018-05-24 19:24:46 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.111 00:0e:9e:05:23:2b
2018-05-24 19:24:46 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.111 00:0e:9e:05:23:2b Topfield_SRP-2411
2018-05-24 19:25:01 info /usr/sbin/cron[20718]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-05-24 19:25:01 info /usr/sbin/cron[20719]: (root) CMD (majordomo_db.sh downsize)
2018-05-24 19:25:01 info /usr/sbin/cron[20720]: (root) CMD (/etc/init.d/haas-proxy enabled && /etc/init.d/haas-proxy check_fw)
2018-05-24 19:25:06 err ucollect[4497]: Too many pings not answered on api.turris.cz:5679, reconnecting
2018-05-24 19:25:06 info ucollect[4497]: Reconnecting to api.turris.cz:5679 now
2018-05-24 19:25:06 info ucollect[4497]: Socat started
2018-05-24 19:25:06 err ucollect[4497]: Error from socat: 2018/05/24 19:25:06 socat[20769] E connect(5, AF=10 [2001:1488:ac15:ff80:0000:0000:0000:0101]:5679, 28): Permission denied
2018-05-24 19:25:06 warning ucollect[4497]: Remote closed the uplink api.turris.cz:5679, reconnecting
2018-05-24 19:25:06 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 19:25:06 warning ucollect[4497]: Reconnecting too often, waiting a little while
2018-05-24 19:25:06 info ucollect[4497]: Going to reconnect to api.turris.cz:5679 after 2 seconds
2018-05-24 19:25:08 info ucollect[4497]: Reconnecting to api.turris.cz:5679 now
2018-05-24 19:25:08 info ucollect[4497]: Socat started
2018-05-24 19:25:09 warning ucollect[4497]: epoll_wait on 4 interrupted, retry
2018-05-24 19:25:09 info ucollect[4497]: Activating plugin Count
2018-05-24 19:25:09 info ucollect[4497]: Activating plugin Sniff
2018-05-24 19:25:09 info ucollect[4497]: Activating plugin Flow
2018-05-24 19:25:09 info ucollect[4497]: Activating plugin Refused
2018-05-24 19:25:09 info ucollect[4497]: Activating plugin Bandwidth
2018-05-24 19:25:09 info ucollect[4497]: Activating plugin Fake
2018-05-24 19:25:09 info ucollect[4497]: Activating plugin Fwup
2018-05-24 19:25:09 info ucollect[4497]: Activating plugin Spoof
2018-05-24 19:25:09 info ucollect[4497]: Received configuration 49828441 (max. 5000 flows, 1800000 ms timeout)
2018-05-24 19:25:09 info ucollect[4497]: Refused config version not changed from 3
2018-05-24 19:25:54 info dnsmasq-dhcp[5601]: DHCPREQUEST(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
2018-05-24 19:25:54 info dnsmasq-dhcp[5601]: DHCPACK(br-lan) 192.168.2.115 c0:11:73:18:3f:8d
