Turris Omnia - rtrom01
Turris OS 3.9.6
Kernel 4.4.119-082ea0f4a4e204b99821bedcb349ed54-0
unbound 1.6.8
The issue as described below seems to be stemming from forward_upstream
(see bottom for unbound common config) which is not a relevant syntax for unbound, instead if a forwarder is set than in an extra file containing unbound syntax which uci apparently cannot handle
/foris/config/main/dns/
Remote Exception: Internal error Uci record was not found ‘resolver.common.forward_upstream’.(‘<class ‘foris_controller.exceptions.UciRecordNotFound’>’)
> Remote request
> {"action": "get_settings", "kind": "request", "data": {}, "module": "dns"}
> Stack trace
> Traceback (most recent call last):
> File "/usr/lib/python2.7/site-packages/foris_controller/message_router.py", line 99, in process_message
> data = module_instance.perform_action(message["action"], message.get("data", {}))
> File "/usr/lib/python2.7/site-packages/foris_controller/module_base.py", line 60, in perform_action
> res = action_function(data)
> File "/usr/lib/python2.7/site-packages/foris_controller_modules/dns/__init__.py", line 36, in action_get_settings
> return self.handler.get_settings()
> File "/usr/lib/python2.7/site-packages/foris_controller/utils.py", line 100, in inner
> res = func(*args, **kwargs)
> File "/usr/lib/python2.7/site-packages/foris_controller_modules/dns/handlers/openwrt.py", line 42, in get_settings
> return OpenwrtDnsHandler.uci_dns_cmds.get_settings()
> File "/usr/lib/python2.7/site-packages/foris_controller_backends/dns/__init__.py", line 41, in get_settings
> get_option_named(resolver_data, "resolver", "common", "forward_upstream"))
> File "/usr/lib/python2.7/site-packages/foris_controller_backends/uci/__init__.py", line 77, in get_option_named
> raise UciRecordNotFound(config, section=section, option=option)
> UciRecordNotFound: Uci record was not found 'resolver.common.forward_upstream'.
/etc/config/resolver
config resolver 'common'
list interface '0.0.0.0'
# list interface '::0' # disabled if no ipv6 on the lan
option port '53'
option keyfile '/etc/root.keys'
# option verbose '0'
option verbose '1' # increased of above original (testing)
# option msg_buffer_size '4096'
option msg_buffer_size '8192' # increased of above original (performance)
# option msg_cache_size '20M'
option msg_cache_size '50M' # increased of above original (performance)
option net_ipv6 '0'
option net_ipv4 '1'
# option prefered_resolver 'kresd' # disable knot (don't forget to stop knot and prevent autostart, best to remove from it from the system/autoupdate)
option prefered_resolver 'unbound' # enable unbound
# option ignore_root_key '0' # porbably not relevant for unbound
option prefetch 'yes'
option static_domains '1'
option dynamic_domains '1'
# option forward_upstream '0' # irrelevant for unbound (see /etc/unbound/unbound_ext.conf)
