Hello there!
I just started using a Mox Router and experienced that after directly updating the device to latest version (5.1.10) with Foris, Foris and Reforis stopped working after reboot. Luci and the start page is still working fine.
When calling either of them, it responds with 500 or 503. When looking at CPU usage, both cores are on 100% most of the time (2.28, 2.25, 2.26).
Also, it seems that both Foris and ReForis are on restarting loop.
Some log from lighttpd:
2021-03-09 15:36:10: (gw_backend.c.468) unlink /tmp/fastcgi.foris-config.socket-0 after connect failed: Connection refused 2021-03-09 15:36:12: (gw_backend.c.324) child exited: 1 unix:/tmp/fastcgi.reforis.socket-0 2021-03-09 15:36:13: (gw_backend.c.468) unlink /tmp/fastcgi.reforis.socket-0 after connect failed: Connection refused 2021-03-09 15:36:14: (http-header-glue.c.1286) read(): Connection reset by peer 10 11 2021-03-09 15:36:14: (gw_backend.c.2125) response not received, request sent: 943 on socket: unix:/tmp/fastcgi.foris-config.socket-0 for /foris/config?, closing connection 2021-03-09 15:36:14: (gw_backend.c.324) child exited: 1 unix:/tmp/fastcgi.foris-config.socket-0 2021-03-09 15:36:14: (gw_backend.c.468) unlink /tmp/fastcgi.foris-config.socket-0 after connect failed: Connection refused
Also, some packages seem to not be updated or found (since I can’t install them with opkg)
root@turris:~# pkgupdate INFO:Target Turris OS: 5.1.10 WARN:Requested package luci-i18n-sqm-en that is missing, ignoring as requested. WARN:Requested package luci-i18n-sqm-de that is missing, ignoring as requested. WARN:Requested package foris-pakon-plugin-l10n-de that is missing, ignoring as requested. WARN:Requested package foris-storage-plugin-l10n-de that is missing, ignoring as requested. WARN:Requested package reforis-data-collection-plugin-l10n-de that is missing, ignoring as requested. WARN:Requested package reforis-diagnostics-plugin-l10n-de that is missing, ignoring as requested. WARN:Requested package reforis-openvpn-plugin-l10n-de that is missing, ignoring as requested. WARN:Requested package reforis-snapshots-plugin-l10n-de that is missing, ignoring as requested.
I did not found any solution in existing threads working and I am not really sure where to start.
Does someone have an idea on how to solve or better debug into this issue?
