My filesystem has just turned read only. I can’t edit anything.
I have seen other people have same issues, but they fixed this problem by re-flashing. I have tried to go to a previous snapshot, but no salvation in that.
I have A LOT of options i do not want to lose, including a LXC that is up and running with A LOT of configurations.
Anybody a solution that is already known but i have somehow missed it?
root@K-Router:~# mount
/dev/mmcblk0p1 on / type btrfs (ro,relatime,ssd,space_cache,commit=5,subvolid=271,subvol=/@)
proc on /proc type proc (rw,noatime)
sysfs on /sys type sysfs (rw,noatime)
none on /sys/fs/cgroup type cgroup (rw,relatime,cpuset,cpu,cpuacct,blkio,memory,devices,freezer,net_cls)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
tmpfs on /dev type tmpfs (rw,relatime,size=512k,mode=755)
devpts on /dev/pts type devpts (rw,relatime,mode=600,ptmxmode=000)
debugfs on /sys/kernel/debug type debugfs (rw,noatime)
mountd(pid4018) on /tmp/run/mountd type autofs (rw,relatime,fd=5,pgrp=4016,timeout=60,minproto=5,maxproto=5,indirect)
LXC containers you should have on external device (usb flash drive, hard drive and so on).
See it here how you can move it from internal storage to somewhere else
Configuration it depends, what you want and what you would like to backup.
Most configuration files should be located in /etc/config
Re-flashing in the sense of going back to factory defaults right? As my schnaps list is empty…
root@K-Router:~# schnapps list
mount: wrong fs type, bad option, bad superblock on /dev/mmcblk0p1,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so.
# | Type | Date | Description
ERROR: cannot find real path for ‘/mnt/.snapshots/@ 5’: No such file or directory
5 | single | |
ERROR: cannot find real path for ‘/mnt/.snapshots/@ 7’: No such file or directory
7 | single | |
ERROR: cannot find real path for ‘/mnt/.snapshots/@ 12’: No such file or directory
12 | single | |
ERROR: cannot find real path for ‘/mnt/.snapshots/@ 138’: No such file or directory
138 | single | |
ERROR: cannot find real path for ‘/mnt/.snapshots/@ 139’: No such file or directory
139 | single | |
ERROR: cannot find real path for ‘/mnt/.snapshots/@ 140’: No such file or directory
140 | single | |
ERROR: cannot find real path for ‘/mnt/.snapshots/@ 141’: No such file or directory
141 | single | |
ERROR: cannot find real path for ‘/mnt/.snapshots/@ 142’: No such file or directory
142 | single | |
ERROR: cannot find real path for ‘/mnt/.snapshots/@ 143’: No such file or directory
143 | single | |
ERROR: cannot find real path for ‘/mnt/.snapshots/@ 144’: No such file or directory
144 | single | |
ERROR: cannot find real path for ‘/mnt/.snapshots/@ 145’: No such file or directory
145 | single | |
ERROR: cannot find real path for ‘/mnt/.snapshots/@ 146’: No such file or directory
146 | single | |
ERROR: cannot find real path for ‘/mnt/.snapshots/@ 147’: No such file or directory
147 | single | |
ERROR: cannot find real path for ‘/mnt/.snapshots/@ 148’: No such file or directory
148 | single | |
ERROR: cannot find real path for ‘/mnt/.snapshots/@ 149’: No such file or directory
149 | single | |
ERROR: cannot find real path for ‘/mnt/.snapshots/@ 150’: No such file or directory
150 | single | |
ERROR: cannot find real path for ‘/mnt/.snapshots/@ 151’: No such file or directory
151 | single | |
ERROR: cannot find real path for ‘/mnt/.snapshots/@152’: No such file or directory
152 | single |
Hmm, well my LXC container is on my SSD. Majordomo even is also on my SSD. What runs on my eMMC is only the OS itself and some scripts. A few days ago we did experience a power outage through the whole city and some neighboring villages that lasted 2-3 hours.
The other thing that i often experience is when i disable/enable some interfaces Turris Omnia crashes/reboots. This however has happened AT LEAST 6 months or longer.
Today i finally found the time to do what it needed to be done. Everything so far succeeded, i am only stuck with LXC. How do i recover everything?
/etc/lxc/lxc.conf
lxc.lxcpath = /mnt/LXC/K-Router-LXC/
command “mount”
root@K-Router:/etc/lxc# mount
/dev/mmcblk0p1 on / type btrfs (rw,noatime,ssd,space_cache,commit=5,subvolid=256,subvol=/@)
/dev/sda1 on /mnt/majordomo type btrfs (rw,relatime,ssd,space_cache,subvolid=5,subvol=/) /dev/sda2 on /mnt/LXC type btrfs (rw,relatime,ssd,space_cache,subvolid=5,subvol=/)
mountd(pid4150) on /tmp/run/mountd type autofs (rw,relatime,fd=5,pgrp=4146,timeout=60,minproto=5,maxproto=5,indirect)
cd & ls
root@K-Router:/etc/lxc# cd /mnt/LXC/K-Router-LXC/
root@K-Router:/mnt/LXC/K-Router-LXC# ls
K-Router-LXC K-Router-LXC.log rootfs
/etc/config/lxc-auto
#config container #option name container1
# How long to give container to shutdown gracefully before killing it
# Default 300s #option timeout 30
# Commnads to run before starting container #list command ‘/bin/command --option’ #config container #option name container2 #option timeout 60
config container
option name K-Router-LXC
option timeout 60
It just won’t detect. I rebooted multiple times. Maybe i am missing some package or so?
In the future there maybe other people who fall in the same situation as i have and many before me.
Here a quick how to tutorial.
Step 1: Backup your configuration files. In my case the eMMC was READ-only so i could not mount even a USB-Drive. I first tried “SCP”-command through SSH, however somehow because the eMMC was still READ-ONLY i could not make it work. When typing “mount” you can see at the beginning of each line what mount-points are still writeable (RW). In my case my external(internal) drive where i had my LXC running was still writeable. So i made some directories and copied all “/etc/config” content to that backup directory on my internal drive. I also just incase copied the crontab as i had added some content to it. (fstrim lines for example) and some files in my root directory.
Step 2: When everything was backedup to another drive instead of the eMMC, i copied the medkit to the USB drive (used ext4 filesystem for the USB-drive) and put in the FRONT USB of the Turris Omnia.
Step 3: I then pushed and kep pushing the reset butting until LED 4 was burning (number 2 LED) and released it. It directly started to re-flash the entire eMMC. In maybe 1-2 minutes it was apparently already done.
Step 4: The Omnia should now be re-flashed and the router IP is by default 192.168.1.1. Go and type this in the webbrowser and you will reach Floris (default webinterface of the Omnia). Follow the entire wizard.
Step 5: removed
Step 6: When this was done i went to mount points and mounted the partitions and pressed save & apply.
Step 7: I then used ssh and copied all the content of the /etc/config directory i backed up previously in step 1 to /etc/config. Remember the mountpoint will propable be sda1 or sda2 this time. REMEMBER it will rewrite all the files/directories in the /etc/config directory without warning you. When this was done, i restarted the Turris Omnia and many configurations where back to the old. However certain software was still missing. Then again i SSh to the omnia and typed “updater.sh”. It then started to install all the missing software packages (for example LXC and many more).
Step 8: If you have done step 7, do again take a good look what you are missing in packages. In my case some packages were still missing so i had to re-install them manually. In myc case packages such as ath9k-firmware to get a USB-wifi-dongle working again and mwan3 package.
Step 9: If you were running a LXC like me, you have to change some settings now to make it work again. Go to /etc/lxc/lxc.config and change the directory to that of what you previously had on your internal SSD. If nothing is still detected give it a reboot and things should work.
Oke, i fixed it. I decided to create another VM from scratch to see if the directory is right. That went well and the new VM had a “config” file, while my original VM did not have. I had made that VM back when i just got the Omnia.
So when seeing the new VM had a “config” file that contained information (network setting, name etc) of the VM, i copied that file to my original VM and changed the settings. Send a reboot command and everything worked fine.
Just backed up my config before and restored it afterwards. Just needed to start and enable mysqld to access nextcloud (installed to external HD) and set up DDNS and VPN again.
OOh well, then having Nextcloud in LXC you will have more benefits as EVERYTHING is written and read from SSD leaving flash storage (eMMC) for the real basic things (routing, internet, VPN…etc).
I am running my Nextcloud in Ubuntu Xenial LXC using repositories to have many packages up to date.
