Your system WOULD NOT let me put 3 URLs in the text of the message. So, I added spaces to get the bug filed. If you look below, you see that the error message occurred on exactly the URL you indicated…
This seems that you are trying to build old version of Turris OS. Just checkout some newer version first. It looks like pre 4.0.2 versions as we moved some repositories as part of internal cleanup around and updated URLs in packages.
This is the sequence of events that I went through
mkdir ~/turris
cd ~/turris
git clone https://gitlab.labs.nic.cz/turris/turris-build.git
cd ~/turris/turris-build
git checkout $(git tag | sort | tail -1)
./compile_pkgs -j2 -a V=s -s /home/casey/signcert/server.key -t omnia
According to the log, it would appear that git checkout picked up version 4.14.137
Note: checking out ‘89808e211cd5ef5989bd0becb8cd45f9340610ff’.
You are in ‘detached HEAD’ state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
git checkout -b new_branch_name
HEAD is now at 89808e2… kernel: bump 4.14 to 4.14.137
Is there another specific version I should be checking out?
Ok I think that the problem is in $(git tag | sort | tail -1). Can you please tell me what distribution are you running and also post output of git tag | sort? And also git tag | sort -V?
Edit: anyway that commit in OpenWrt is more than year old so there is something wrong with your checkout for sure.
For me v4.0-beta9 wins which probably isn’t what you want. Well, who says that sort just sorts versions the way you expect (by default)? EDIT: with sort -V it gets 4.0.5, i.e. the “right” answer.
