Is it possible to do factory reset (and select the mode) from the command line? I’d prefer that to reset button woodo (especially on MOXes).
It‘s somehow possible:
schnapps rollback factory
reboot
If you want to override factory image you can upload/download a medkit to your router and then run
schnapps import -f medkit-XXX.tar.gz
prior to the commands above.
In any case schnapps
creates a snapshot of the current state of your router to which you can go back using
schnapps rollback XXX
reboot
Where XXX is the snapshot id that was printed by schnapps (or get it by schnapps list
Nice, would be great to add it to the documentation…
