Have a strange problem in a LXC container on upgrading:
Preparing to unpack .../libc6_2.31-13+deb11u2_armhf.deb ...
ERROR: Your kernel version indicates a revision number
of 255 or greater. Glibc has a number of built in
assumptions that this revision number is less than 255.
If you\'ve built your own kernel, please make sure that any
custom version numbers are appended to the upstream
kernel number with a dash or some other delimiter.
dpkg: error processing archive /var/cache/apt/archives/libc6_2.31-13+deb11u2_armhf.deb (--unpack):
new libc6:armhf package pre-installation script subprocess returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
TurrisOS: 5.3.4 974161d7f891cc1a76c390258db2fac59a4d115c / LuCI branch git-22.023.38255-88b4c07 with kernel version: 4.14.262
Revision number with 262 causes the error.
OS in the container is Devuan (Debian fork without SystemD), but should concern all debian based Linux systems!?
Any hints to solve this?
