just a (hopefully) quick one: what’s the recommended way to enable logging in lighttpd, e.g to trace failed login attempts? I’m on HBL branch (5.2).
Thanks!
Thanks!
let me rephrase this: currently I’m working on a new banIP version (incl. Turris support). It includes a small utility which monitors the log to receive suspicious “failed logins” from ssh, luci, etc.
ssh in Turris OS is OK but I’ll get no failed logins from luci and/or re-foris. Is there any switch to enable this kind of logging?
Thanks!
P.S. Please no discussion if it’s usefull to open such WEB GUIs to WAN side.
You can check this for logging options:
https://redmine.lighttpd.net/projects/1/wiki/DebugVariables
Btw ssh and Luci by default are available only from LAN if you haven’t allowed incoming connections from wan or other networks.
Since this thread for revived after one year, I need to share some progress regarding it.
This is currently done only for LuCI.
OpenWrt master branch:
OpenWrt 21.02 branch:
Regarding (re)Foris, I also have good news as well available since OpenWrt 21.02.
https://gitlab.nic.cz/turris/turris-auth/-/blob/master/turris_auth/server/__main__.py#L18
