Leadtek WinFast DTV Dongle mini
Ahoj!
Stále hledám a hledám jak zprovoznit svůj DVB-T tuner.
Na starém fóru jsem řešil jak ho rozchodit.
Povedlo se mi ho dostat do stádia kdy v dmesg vidím toto:
usb 1-1.2: new high-speed USB device number 3 using fsl-ehci
usb 1-1.2: dvb_usb_v2: found a ‘Leadtek WinFast DTV Dongle mini’ in warm state
usb 1-1.2: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
DVB: registering new adapter (Leadtek WinFast DTV Dongle mini)
i2c i2c-2: Added multiplexed i2c bus 3
rtl2832 2-0010: Realtek RTL2832 successfully attached
usb 1-1.2: DVB: registering adapter 0 frontend 0 (Realtek RTL2832 (DVB-T))…
Bohužel ve webovém rozhraní nejsou ani TV adapréry a ani žádné MUXy.
ve složce firmware jsem ozkoušel všechny možné kombinace ale už si s tím nějak nevím rady.
lsusb -v
Bus 001 Device 004: ID 048d:9135 Integrated Technology Express, Inc. Zolid Mini DVB-T Stick
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x048d Integrated Technology Express, Inc.
idProduct 0x9135 Zolid Mini DVB-T Stick
bcdDevice 2.00
iManufacturer 0
iProduct 0
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 46
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 4
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
lsmod | grep dvb
dvb_core 70740 3 dvb_usb_v2
dvb_usb_rtl28xxu 14192 0
dvb_usb_v2 12839 1 dvb_usb_rtl28xxu
rc_core 15024 2 dvb_usb_rtl28xxu
