Dear experts, since a couple of days, I have problems with DNS forwarding.
Please note that I’m just a user (I can ssh to my Turris Omnia to follow instructions but they have to be pretty literal, step-by-step commands).
This is my version as reported by Foris:
Device Turris Omnia - RTROM01
Serial number 47244687325
Turris OS version 3.8
Kernel version 4.4.87-cb5e816fa6b1a6b5342df69755869d71-2
So here are my symptoms:
- My Android device can connect to WiFi but says “Connected, no Internet”.
- My laptop could connect, but couldn’t resolve any addresses - I had to manually enter Google’s 8.8.8.8 in the connection settings to be able to post here.
So I saw this post which mentions to do this:
root@turris:~# cat /var/resolv.conf.auto
# Interface wan
nameserver 192.168.0.1
nameserver 59.86.160.27
nameserver 125.213.172.129
But when I try ping, this happens:
root@turris:~# ping google.com
ping: bad address 'google.com'
Or this:
root@turris:~# nslookup google.com 59.86.160.27
Server: 59.86.160.27
Address 1: 59.86.160.27
nslookup: can't resolve 'google.com': Try again
On the Foris DNS connection test, these are the results:
Test type Status
IPv4 connectivity OK
IPv4 gateway connectivity Error
IPv6 connectivity Error
IPv6 gateway connectivity OK
DNS Error
DNSSEC Error
I am not sure what is going on or how I can fix it. Any help would be appreciated.
