In case it helps anyone, after freshly installing turris with a medkit and changing my ip to the 192.168.0.1 range, I was having a bit of DNS trouble with some of my devices. I noticed that under advanced settings in interfaces/DHCP, the DHCP Options was still advertising 192.168.1.1. I’m not testing, but that seems to have cleared up some of the confusion. Now my devices don’t have trouble accessing the internet.
The takeaway is, if you change your ip range, check the DHCP settings to make sure everything else matches.
Cheers,
Chris
