Hello, I am trying to set-up a separate WLAN for my guests with a simple password;
I have successfully created PERLUR Guest WLAN on 2,4GHz interface, it is visible and devices can connect to the network. If I configure their IP addresses manually, everything works perfectly, but DHCP is not serving this WLAN… I am trying to set-up a little paranoid configuration here and allow my guests on connect only using HTTP, HTTPS, SSH and Google DNS.
I have following in /etc/config/network
config interface 'guest'
option _orig_ifname 'wlan1-1'
option _orig_bridge 'false'
option proto 'static'
option ipaddr '192.168.0.1'
Following in /etc/config/dhcp
config dhcp 'guest'
option leasetime '12h'
option interface 'guest'
option force '1'
option start '50'
option limit '203'
list dhcp_option '6,8.8.8.8,8.8.4.4'
list dhcp_option '3,192.168.0.1'
and following in /etc/config/firewall
root@turris01:~# cat /etc/config/firewall
config defaults
option syn_flood '1'
option input 'ACCEPT'
option output 'ACCEPT'
option forward 'REJECT'
config zone
option name 'lan'
option forward 'ACCEPT'
option network 'lan'
config zone
option name 'wan'
option input 'REJECT'
option masq '1'
option mtu_fix '1'
option network 'wan wan6'
config forwarding
option src 'lan'
option dest 'wan'
config rule
option name 'Allow-DHCP-Renew'
option src 'wan'
option proto 'udp'
option dest_port '68'
option target 'ACCEPT'
option family 'ipv4'
config rule
option name 'Allow-Ping'
option src 'wan'
option proto 'icmp'
option icmp_type 'echo-request'
config rule
option name 'Allow-IGMP'
option src 'wan'
option proto 'igmp'
config rule
option name 'Allow-DHCPv6'
option src 'wan'
option proto 'udp'
option src_ip 'fe80::/10'
option src_port '547'
option dest_ip 'fe80::/10'
option dest_port '546'
option family 'ipv6'
config rule
option name 'Allow-MLD'
option src 'wan'
option proto 'icmp'
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
config rule
option name 'Allow-ICMPv6-Input'
option src 'wan'
option proto 'icmp'
list icmp_type 'echo-request'
list icmp_type 'echo-reply'
list icmp_type 'destination-unreachable'
list icmp_type 'packet-too-big'
list icmp_type 'time-exceeded'
list icmp_type 'bad-header'
list icmp_type 'unknown-header-type'
list icmp_type 'router-solicitation'
list icmp_type 'neighbour-solicitation'
list icmp_type 'router-advertisement'
list icmp_type 'neighbour-advertisement'
option limit '1000/sec'
config rule
option name 'Allow-ICMPv6-Forward'
option src 'wan'
option dest '*'
option proto 'icmp'
config include
option path '/etc/firewall.user'
config include
option path '/usr/share/firewall/turris'
option reload '1'
config include
option path '/etc/firewall.d/with_reload/firewall.include.sh'
option reload '1'
config include
option path '/etc/firewall.d/without_reload/firewall.include.sh'
option reload '0'
config rule
option src 'wan'
option dest 'lan'
option proto 'esp'
config rule
option src 'wan'
option dest 'lan'
option dest_port '500'
option proto 'udp'
config include 'miniupnpd'
option type 'script'
option path '/usr/share/miniupnpd/firewall.include'
option family 'any'
option reload '1'
config zone
option name 'guest'
option network 'guest'
option output 'REJECT'
config rule
option src 'guest'
option dest 'wan'
option dest_port '80'
option proto 'tcp'
option name 'GUEST_ALLOW_HTTP_WAN'
config rule
option dest 'wan'
option proto 'tcp'
option src 'guest'
option dest_port '443'
option name 'GUEST_ALLOW_HTTPS_WAN'
config rule
option src 'guest'
option dest 'wan'
option name 'GUEST_ALLOW_DNS01_WAN'
option dest_ip '8.8.8.8'
option dest_port '53'
config rule
option src 'guest'
option dest 'wan'
option name 'GUEST_ALLOW_DNS02_WAN '
config rule
option src 'guest'
option dest 'wan'
option name 'GUEST_ALLOW_SSH_WAN'
option proto 'tcp'
option dest_port '22'
config zone
option name 'dmz'
option network 'dmz'
config forwarding
option dest 'wan'
option src 'dmz'
config forwarding
option dest 'dmz'
option src 'lan'
config rule
option src 'wan'
option proto 'tcp'
option name 'ALLOW_SSH_FROM_CZKO'
option src_ip '82.209.54.72/29'
option dest_ip '82.209.54.74'
config rule
option name 'GUEST_ALLOW_DHCP01'
option proto 'udp'
option src 'guest'
option dest_ip '192.168.0.1'
option dest_port '67'
config rule
option enabled '1'
option proto 'udp'
option name 'GUEST_ALLOW_DHCP02'
option src 'guest'
config forwarding
option dest 'guest'
option src 'dmz'
config forwarding
option dest 'guest'
option src 'lan'
root@turris01:~#
But any client connected to the WLAN does not get assigned IP from DHCP, am I missing some DHCP rules?
