Apparently, there was a “DDNS client” in Turris 1.1 but I can’t find it now and I need it because it doesn’t work properly my Optical Fiber router
Thank you in advance by your help
The relevant packages
would appear as available in the M repo https://repo.turris.cz/hbs/mox/packages
Did you search for ddns, either via cmd or LuCI?
Thank you!
Some instructions / GUIDE to install and use them?
CMD or LuCI doesn’t matter. I’d like to use simplest way
