hi
i mistakenly deleted the myddns_ipv4 config setting.
i tried to recreate it, but i get no presets for the various ddns providers
and then a failure when trying to get the ip address:
Advanced Settings - IP address source [IPv4]: can not detect local IP. Please select a different Source combination
i tried deleting and reinstalling ddns packages, but config was saved.
You can try to restore the old config.
Use schnapps list to show the available snapshots and use schnapps mount <id> to mount it (replace <id> with the id of the snapshot.
Then you can find the config at /mnt/snapshot-@<id>/etc/config
When finished unmount the snapshot again umount /mnt/snapshot-@<id>
I am experiencing a similar problem when doing an initial configuration, so I do not have a snapshot to restore from.
I enabled the service to run on startup, and tried to configure manually as I had no provider presets. Then I figured out how to get a preset installed, so I installed it. The providers never show in the drop down (even after reboot/service restart) and no matter what I do, I always get the following messages on the config page.
Basic Settings - Custom update-script: unable to update
