when I use “Custom Commands” pipe
smartctl -a / dev / sda | grep Temp | cut -d “” -f 2.37
I get refunded …
# smartctl -a /dev/sda "|" grep Temp "|" cut "-d " -f "2,37"
smartctl 6.5 2016-05-07 r4318 [armv7l-linux-4.4.13-05df79f63527051ea0071350f86faf76-9] (localbuild)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=======> INVALID ARGUMENT TO -f: 2,37
=======> VALID ARGUMENTS ARE: old, brief, hex[,id|val] <=======
Use smartctl -h to get a usage summary
How do I do I specify “Custom Commands” to dotstal same dump when I run the command ssh.
Thank you
David
PS: The drive is connected via SATA and ssh works properly.
