Hi all,
I try to use my Technicolor modem on bridge mode with my Turris Omnia.
- I set the coaxial modem on bridge mode and disable the wifi (2,4 and 5ghz).
- Factory reset on the Turris Omnia
- Reboot the technicolor modem and only the Turris Omnia plug on it on 1st port
- Set up the Turris Omnia… don’t work
What do I miss?
Best regards,
Jckbrtn
try different port on the cablemodem
try to put cable modem first on, then TO
( assume you have the DHCP on WAN port on ? )
also, if it is more complicated, look at syslog in Luci, see what goes wrong where? )
hagrid
3
what does it mean that it does not work?
Does the modem/TO detect at least the physical link?
Do you see any traffic on WAN interface with tcpdump
Are you able to ping the modem?
Hi Dikkehenk,
I think I used the LAN port on TO and not de WAN port.
I will try tomorrow!
Thanks,
Jckbrtn
This is my fault. I thought I shouldn’t use the WAN port on Turris Omnia.
All is working now!
system
Closed
6
