Troubleshooting Setup of Omnia
I followed the suggested steps from directions suggested in the Forum:
Unable to use Omnia with Virgin Media cable router in Modem Mode - #8 by gerv
So for anyone else with this problem:
- Switch off the Omnia
- Unplug all Ethernet cables from your VM box except the Omnia (into the Modem mode port)
- Connect to VM box wifi or via Ethernet and use web interface to switch it to Modem mode
- Watch it reboot
5 . Wait until it has finished and the lights calm down
Power on the Omnia
Wait until it has fully booted
Check that you can access the Internet via a cable plugged into the Omnia
