Conflicts between configs
I can observe from time to time conflict between configs. During installation installer will detect change in original config and create -opkg file. In my etc folder I can see these files:
dhcp
dhcp-opkg
firewall
firewal-opkg
firewal-turris
foris
foris-opkg
etc.
How to deal with this situation? Shold I after creation of -opkg config manualy review changes and merge possible config updates into config file? Is this an issue? How do you deal with these mismatches?
Manual control and editing.
try vim -O file file-opkg (that’s a capital letter O). Will open vim with both files so you can do a visual comparison between the two. In my experience most of the time your file (the non-opkg file) will have a lot of additional configuration information in it because you set whatever it is up, so there really is nothing for you to do. I delete the -opkg files after I do a comparison. For those new to vim you can use hjkl to move around, ctrl-w ctrl-w to jump between panes.
Yep, but most aren’t installed by default, vim is.
diff -y file file-opkg
