this is addressed to the maintainers:
I had yesterday had my router/ap day which means I updated any device in two households to the latest versions. Once again my MOX was stuck in some reboot mode, where I couldn’t get it running anymore (don’t know if filesystem got corrupted, but this anyways happens every now and then (in serveral months)). I would have loved a good integration in SCHNAPS like it is on TO, but the blinking/pressing scheme on MOX does not work well for me - but I am used to that and have a good manual what to enter where to have it running again in <1 hour. But this time I took configuration backups from any router and ap (3 in household one and another 2 in household two) and was somewhat flabbergasted that in the allnew reforis GUI there is no option to download/create this backup but only in foris.
So here’s my question: Why didn’t you integrate this option while you removed it from the luci-GUI? Yes, SCHNAPS is powerful, but if I have to retrieve my storage (microSD in my case) because of a failure there is after foris is removed someday currently no standard option to backup configuration of a MOX. (side remark: yes, SCHNAPS snapshots can be downloaded, but not via GUI - at least not yet). Or will this option be moved to foris in the future?
Best,
ssdnvv
