Compex WLE200N2-23
I tried replacing the included WLE200N2 WiFi card with WLE200N2-23 (which is a higher-power version of the same card), however Omnia doesn’t appear to detect it (it’s not mentioned in dmesg, nor is it seen with lspci after pciutils are installed). I know that the card is a bit problematic - it wouldn’t work in PCEngines APU2 board either, but it does work in an Atom mini-ITX board that I have - is there any chance for it to work with Omnia?
fuck, got the same one :frowning:
not exactly, AR9287 vs AR9283 (plus the WLE200N2-23 has by far the best RX-specs of all 2.4GHz cards, that’s why i bought it)
any messages in the kernel log?
Here’s the bootlog - apparently even the bootloader doesn’t see it:
U-Boot SPL 2015.10-rc2 (Aug 18 2016 - 20:43:35)
High speed PHY - Version: 2.0
SERDES0 card detect: SATA
Initialize Turris board topology
Detected Device ID 6820
board SerDes lanes topology details:
 | Lane #  | Speed |  Type       |
 |   0    |  6   |  SATA0       |
 |   1    |  5   |  USB3 HOST0  |
 |   2    |  5   |  PCIe1       |
 |   3    |  5   |  USB3 HOST1  |
 |   4    |  5   |  PCIe2       |
 |   5    |  0   |  SGMII2      |
poll_op_execute: TIMEOUT
:** Link is Gen1, check the EP capability
PCIe, Idx 1: remains Gen1
PCIe, Idx 2: detected no link
DDR3 Training Sequence - Ver TIP-1.29.0
Memory config in EEPROM: 0x02
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
DDR3 Training Sequence - Ended Successfully
U-Boot 2015.10-rc2 (Aug 18 2016 - 20:43:35 +0200), Build: jenkins-omnia-master-23
SoC:   MV88F6820-A0
       Watchdog enabled
I2C:   ready
SPI:   ready
DRAM:  2 GiB (ECC not enabled)
Enabling Armada 385 watchdog.
Disabling MCU startup watchdog.
Regdomain set to **
MMC:   mv_sdh: 0
SF: Detected S25FL164K with page size 256 Bytes, erase size 64 KiB, total 8 MiB
*** Warning - bad CRC, using default environment
PCI:
  00:01.0     - 168c:003c - Network controller
Model: Marvell Armada 385 GP
Board: Turris Omnia SN: 0000000B00004D84
Regdomain set to **
SCSI:  MVEBU SATA INIT
Target spinup took 0 ms.
SATA link 1 timeout.
AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
flags: 64bit ncq led only pmp fbss pio slum part sxs
Net:   neta2
Hit any key to stop autoboot:  0
Setting bus to 1
BOOT eMMC FS
BtrFS init: Max node or leaf size 4096
2422192 bytes read in 344 ms (6.7 MiB/s)
16772 bytes read in 171 ms (95.7 KiB/s)
Kernel image @ 0x1000000 [ 0x000000 - 0x24f5b0 ]
## Flattened Device Tree blob at 02000000
   Booting using the fdt blob at 0x2000000
   Loading Device Tree to 0fff8000, end 0ffff183 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.13-05df79f63527051ea0071350f86faf76-7 (beast@slave01) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r49274) ) #1 SMP Mon Sep 5 13:01:10 CEST 2016
[    0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Turris Omnia
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] PERCPU: Embedded 11 pages/cpu @eedcb000 s13696 r8192 d23168 u45056
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 522560
[    0.000000] Kernel command line: earlyprintk console=ttyS0,115200 rootfstype=btrfs rootdelay=2 root=b301 rootflags=subvol=@,commit=5 rw cfg80211.freg=**
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 2070740K/2097152K available (5074K kernel code, 167K rwdata, 1248K rodata, 260K init, 203K bss, 26412K reserved, 0K cma-reserved, 1310720K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0634e6c   (6324 kB)
[    0.000000]       .init : 0xc0635000 - 0xc0676000   ( 260 kB)
[    0.000000]       .data : 0xc0676000 - 0xc069fcc4   ( 168 kB)
[    0.000000]        .bss : 0xc069fcc4 - 0xc06d2cbc   ( 204 kB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] mvebu_mbus: [Firmware Warn]: deprecated mbus-mvebu Device Tree, suspend/resume will not work
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[    0.000000] L2C-310 D prefetch enabled, offset 1 lines
[    0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[    0.000000] L2C-310 Coherent cache controller enabled, 16 ways, 1024 kB
[    0.000000] L2C-310 Coherent: CACHE_ID 0x410054c9, AUX_CTRL 0x56070001
[    0.000000] Switching to timer-based delay loop, resolution 40ns
[    0.000003] sched_clock: 32 bits at 25MHz, resolution 40ns, wraps every 85899345900ns
[    0.000010] clocksource: armada_370_xp_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
[    0.000154] Calibrating delay loop (skipped), value calculated using timer frequency.. 50.00 BogoMIPS (lpj=250000)
[    0.000162] pid_max: default: 32768 minimum: 301
[    0.000214] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000219] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000484] Initializing cgroup subsys io
[    0.000492] Initializing cgroup subsys memory
[    0.000504] Initializing cgroup subsys devices
[    0.000509] Initializing cgroup subsys freezer
[    0.000517] Initializing cgroup subsys net_cls
[    0.000526] CPU: Testing write buffer coherency: ok
[    0.000638] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.000661] Setting up static identity map for 0x8280 - 0x82d8
[    0.000748] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
[    0.000836] mvebu-pmsu: Initializing Power Management Service Unit
[    0.001312] Booting CPU 1
[    0.001482] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.001513] Brought up 2 CPUs
[    0.001518] SMP: Total of 2 processors activated (100.00 BogoMIPS).
[    0.001521] CPU: All CPU(s) started in SVC mode.
[    0.003315] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.003392] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.003447] xor: measuring software checksum speed
[    0.099896]    arm4regs  :  2778.400 MB/sec
[    0.199896]    8regs     :  1851.600 MB/sec
[    0.299896]    32regs    :  1666.000 MB/sec
[    0.299900] xor: using function: arm4regs (2778.400 MB/sec)
[    0.299914] pinctrl core: initialized pinctrl subsystem
[    0.300336] NET: Registered protocol family 16
[    0.300855] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.321508] cpuidle: using governor ladder
[    0.324159] mvebu-pmsu: CPU hotplug support is currently broken on Armada 38x: disabling
[    0.324168] mvebu-pmsu: CPU idle is currently broken on Armada 38x: disabling
[    0.520218] raid6: int32x1  gen()   155 MB/s
[    0.690001] raid6: int32x1  xor()   213 MB/s
[    0.860054] raid6: int32x2  gen()   255 MB/s
[    1.030023] raid6: int32x2  xor()   229 MB/s
[    1.199944] raid6: int32x4  gen()   284 MB/s
[    1.369953] raid6: int32x4  xor()   190 MB/s
[    1.539973] raid6: int32x8  gen()   369 MB/s
[    1.709919] raid6: int32x8  xor()   214 MB/s
[    1.709922] raid6: using algorithm int32x8 gen() 369 MB/s
[    1.709925] raid6: .... xor() 214 MB/s, rmw enabled
[    1.709928] raid6: using intx1 recovery algorithm
[    1.710625] clocksource: Switched to clocksource armada_370_xp_clocksource
[    1.711068] NET: Registered protocol family 2
[    1.711368] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    1.711408] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    1.711468] TCP: Hash tables configured (established 8192 bind 8192)
[    1.711543] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    1.711566] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    1.711667] NET: Registered protocol family 1
[    1.712137] futex hash table entries: 512 (order: 3, 32768 bytes)
[    1.712535] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.712543] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    1.712986] bounce: pool size: 64 pages
[    1.713020] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    1.713028] io scheduler noop registered
[    1.713035] io scheduler deadline registered (default)
[    1.713425] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
[    1.713756] irq: Cannot allocate irq_descs @ IRQ48, assuming pre-allocated
[    1.713905] irq: Cannot allocate irq_descs @ IRQ80, assuming pre-allocated
[    1.714238] mvebu-pcie soc:pcie-controller: PCI host bridge to bus 0000:00
[    1.714247] pci_bus 0000:00: root bus resource [io  0x1000-0xfffff]
[    1.714252] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
[    1.714258] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.714546] PCI: bus0: Fast back to back transfers disabled
[    1.714552] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.714559] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.714564] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.714615] PCI: bus1: Fast back to back transfers enabled
[    1.714878] PCI: bus2: Fast back to back transfers disabled
[    1.714935] PCI: bus3: Fast back to back transfers enabled
[    1.714984] pci 0000:00:02.0: BAR 8: assigned [mem 0xe0000000-0xe02fffff]
[    1.714991] pci 0000:00:01.0: PCI bridge to [bus 01]
[    1.715000] pci 0000:02:00.0: BAR 0: assigned [mem 0xe0000000-0xe01fffff 64bit]
[    1.715012] pci 0000:02:00.0: BAR 6: assigned [mem 0xe0200000-0xe020ffff pref]
[    1.715017] pci 0000:00:02.0: PCI bridge to [bus 02]
[    1.715022] pci 0000:00:02.0:   bridge window [mem 0xe0000000-0xe02fffff]
[    1.715028] pci 0000:00:03.0: PCI bridge to [bus 03]
[    1.715131] mv_xor f1060800.xor: Marvell shared XOR driver
[    1.740903] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[    1.740996] mv_xor f1060900.xor: Marvell shared XOR driver
[    1.780894] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[    1.781047] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    1.781975] console [ttyS0] disabled
[    1.802045] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 22, base_baud = 15625000) is a 16550A
[    2.570706] console [ttyS0] enabled
[    2.594495] f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 23, base_baud = 15625000) is a 16550A
[    2.604274] m25p80 spi0.0: s25fl164k (8192 Kbytes)
[    2.609134] 2 ofpart partitions found on MTD device spi0.0
[    2.614641] Creating 2 MTD partitions on "spi0.0":
[    2.619442] 0x000000000000-0x000000100000 : "U-Boot"
[    2.624758] 0x000000100000-0x000000800000 : "Rescue system"
[    2.631068] libphy: Fixed MDIO Bus: probed
[    2.635378] libphy: orion_mdio_bus: probed
[    2.640623] mvneta f1030000.ethernet eth0: Using hardware mac address d8:58:d7:00:2f:b2
[    2.649409] mvneta f1034000.ethernet eth1: Using hardware mac address d8:58:d7:00:2f:b3
[    2.658201] mvneta f1070000.ethernet eth2: Using hardware mac address d8:58:d7:00:2f:b4
[    2.666451] armada38x-rtc f10a3800.rtc: rtc core: registered f10a3800.rtc as rtc0
[    3.180729] i2c /dev entries driver
[    3.184987] at24 1-0054: 8192 byte 24c64 EEPROM, writable, 1 bytes/write
[    3.191769] i2c i2c-0: Added multiplexed i2c bus 1
[    3.196633] i2c i2c-0: Added multiplexed i2c bus 2
[    3.201505] i2c i2c-0: Added multiplexed i2c bus 3
[    3.206370] i2c i2c-0: Added multiplexed i2c bus 4
[    3.211243] i2c i2c-0: Added multiplexed i2c bus 5
[    3.216108] i2c i2c-0: Added multiplexed i2c bus 6
[    3.220978] i2c i2c-0: Added multiplexed i2c bus 7
[    3.227782] i2c i2c-0: Added multiplexed i2c bus 8
[    3.232597] pca954x 0-0070: registered 8 multiplexed busses for I2C mux pca9547
[    3.240085] sdhci: Secure Digital Host Controller Interface driver
[    3.246286] sdhci: Copyright(c) Pierre Ossman
[    3.250814] sdhci-pxav3 f10d8000.sdhci: No vmmc regulator found
[    3.256749] sdhci-pxav3 f10d8000.sdhci: No vqmmc regulator found
[    3.300623] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
[    3.308069] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.323107] NET: Registered protocol family 10
[    3.328067] NET: Registered protocol family 17
[    3.332551] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    3.345206] Bridge firewalling registered
[    3.349226] 8021q: 802.1Q VLAN Support v1.8
[    3.353483] Registering SWP/SWPB emulation handler
[    3.358891] Btrfs loaded
[    3.362078] mvsw61xx 10.mvsw61xx: Found MV88E6176 at f1072004.mdio-mi:10
[    3.368796] mvsw61xx 10.mvsw61xx: Using indirect addressing
[    3.383562] mmc0: MAN_BKOPS_EN bit is not set
[    3.390982] mmc0: new high speed MMC card at address 0001
[    3.396627] mmcblk0: mmc0:0001 H8G4a▒ 7.28 GiB
[    3.401268] mmcblk0boot0: mmc0:0001 H8G4a▒ partition 1 4.00 MiB
[    3.407276] mmcblk0boot1: mmc0:0001 H8G4a▒ partition 2 4.00 MiB
[    3.413307] mmcblk0rpmb: mmc0:0001 H8G4a▒ partition 3 4.00 MiB
[    3.419162] armada38x-rtc f10a3800.rtc: setting system clock to 2016-10-22 17:35:32 UTC (1477157732)
[    3.420225]  mmcblk0: p1
[    3.431685] Waiting 2 sec before mounting root device...
[    5.440836] UBIFS error (pid: 1): cannot open "ubi0:rootfs", error -19
[    5.449639] BTRFS: device fsid 0730a135-8c70-4db0-808b-3802a4a06638 devid 1 transid 286 /dev/root
[    5.459338] BTRFS info (device mmcblk0p1): disk space caching is enabled
[    5.466063] BTRFS: has skinny extents
[    5.473952] BTRFS: detected SSD devices, enabling SSD mode
[    5.510622] VFS: Mounted root (btrfs filesystem) on device 0:13.
[    5.516760] Freeing unused kernel memory: 260K (c0635000 - c0676000)
[    5.571153] init: Console is alive
[    5.926457] usbcore: registered new interface driver usbfs
[    5.932019] usbcore: registered new interface driver hub
[    5.937375] usbcore: registered new device driver usb
[    5.944848] exFAT: Version 1.2.9
[    5.967094] JFS: nTxBlock = 8192, nTxLock = 65536
[    6.042996] SGI XFS with security attributes, no debug enabled
[    6.053859] SCSI subsystem initialized
[    6.068202] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    6.075087] ehci-platform: EHCI generic platform driver
[    6.080754] ehci-orion: EHCI orion driver
[    6.084875] orion-ehci f1058000.usb: EHCI Host Controller
[    6.090297] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
[    6.097953] orion-ehci f1058000.usb: irq 39, io mem 0xf1058000
[    6.120638] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
[    6.126830] hub 1-0:1.0: USB hub found
[    6.130619] hub 1-0:1.0: 1 port detected
[    6.135724] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    6.144808] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[    6.154255] scsi host0: ahci-mvebu
[    6.157833] scsi host1: ahci-mvebu
[    6.161357] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 44
[    6.169293] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 44
[    6.520622] ata2: SATA link down (SStatus 0 SControl 300)
[    6.720611] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    6.733579] ata1.00: ATA-8: KINGSTON SMS200S3120G, 608ABBF0, max UDMA/133
[    6.740384] ata1.00: 234441648 sectors, multi 1: LBA48 NCQ (depth 31/32)
[    6.752064] ata1.00: configured for UDMA/133
[    6.756514] scsi 0:0:0:0: Direct-Access     ATA      KINGSTON SMS200S BBF0 PQ: 0 ANSI: 5
[    6.765058] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
[    6.772679] sd 0:0:0:0: [sda] Write Protect is off
[    6.777521] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    6.787308] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    6.793830] uhci_hcd: USB Universal Host Controller Interface driver
[    6.800831] orion_wdt: Initial timeout 171 sec
[    6.809230] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    6.814582] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
[    6.822182] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
[    6.830752] xhci-hcd f10f0000.usb3: irq 46, io mem 0xf10f0000
[    6.836772] hub 2-0:1.0: USB hub found
[    6.840543] hub 2-0:1.0: 1 port detected
[    6.844582] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    6.849910] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
[    6.857465] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[    6.865804] hub 3-0:1.0: USB hub found
[    6.869574] hub 3-0:1.0: 1 port detected
[    6.873660] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    6.878991] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
[    6.886595] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
[    6.895161] xhci-hcd f10f8000.usb3: irq 47, io mem 0xf10f8000
[    6.901151] hub 4-0:1.0: USB hub found
[    6.904920] hub 4-0:1.0: 1 port detected
[    6.908943] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    6.914279] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
[    6.921811] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[    6.930130] hub 5-0:1.0: USB hub found
[    6.933905] hub 5-0:1.0: 1 port detected
[    6.939273] usbcore: registered new interface driver usb-storage
[    7.574915] init: - preinit -
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[   10.625560] mount_root: mounting /dev/root
[   10.630565] BTRFS info (device mmcblk0p1): disk space caching is enabled
[   10.637781] mount_root: loading kmods from internal overlay
[   10.856663] block: attempting to load /etc/config/fstab
[   10.862759] block: extroot: not configured
[   10.869408] procd: - early -
[   10.984351] random: jshn urandom read with 22 bits of entropy available
Failed to connect to ubus
[   11.454299] procd: - watchdog -
[   11.457693] procd: - ubus -
[   12.463170] procd: - init -
Please press Enter to activate this console.
[   12.524790] marvell-cesa f1090000.crypto: CESA device successfully registered
[   12.535428] NET: Registered protocol family 38
[   12.554061] md: linear personality registered for level -1
[   12.559958] md: raid0 personality registered for level 0
[   12.566107] md: raid1 personality registered for level 1
[   12.572458] md: raid10 personality registered for level 10
[   12.578363] async_tx: api initialized (async)
[   12.586431] md: raid6 personality registered for level 6
[   12.591778] md: raid5 personality registered for level 5
[   12.597101] md: raid4 personality registered for level 4
[   12.604686] FS-Cache: Loaded
[   12.608056] md: multipath personality registered for level -4
[   12.615257] NET: Registered protocol family 8
[   12.619626] NET: Registered protocol family 20
[   12.628856] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[   12.639905] Key type dns_resolver registered
[   12.647940] NET: Registered protocol family 33
[   12.652408] Key type rxrpc registered
[   12.656077] Key type rxrpc_s registered
[   12.664063] kAFS: Red Hat AFS client v0.1 registering.
[   12.669255] FS-Cache: Netfs 'afs' registered for caching
[   12.711805] RPC: Registered named UNIX socket transport module.
[   12.717742] RPC: Registered udp transport module.
[   12.722468] RPC: Registered tcp transport module.
[   12.727181] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   12.738757] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[   12.749344] RxRPC: Registered security type 2 'rxkad'
[   12.766847] tun: Universal TUN/TAP device driver, 1.6
[   12.771936] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[   12.782533] sit: IPv6 over IPv4 tunneling driver
[   12.791084] gre: GRE over IPv4 demultiplexor driver
[   12.796760] ip_gre: GRE over IPv4 tunneling driver
[   12.818054] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   12.826248] PPP generic driver version 2.4.2
[   12.832901] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   12.841828] cryptodev: driver 1.8 loaded.
[   12.848996] Loading modules backported from Linux version master-2015-12-03-0-g1677f62
[   12.856955] Backport generated by backports.git backports-20151120-0-g906a6b3
[   12.879814] cfg80211: World regulatory domain updated:
[   12.884987] cfg80211:  DFS Master region: unset
[   12.889353] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   12.899149] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   12.907195] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   12.916617] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[   12.924644] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   12.934150] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[   12.943660] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   12.951776] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   12.959798] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   12.986193] pci 0000:00:02.0: enabling device (0140 -> 0142)
[   12.992267] ath10k_pci 0000:02:00.0: pci irq msi interrupts 1 irq_mode 0 reset_mode 0
[   13.164447] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
[   13.174844] ath10k_pci 0000:02:00.0: Falling back to user helper
[   13.184585] firmware ath10k!cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[   13.201374] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[   13.210650] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
[   13.220166] ath10k_pci 0000:02:00.0: firmware ver 10.2.4.70-2 api 5 features no-p2p crc32 b722ec09
[   13.269278] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
[   13.279755] ath10k_pci 0000:02:00.0: Falling back to user helper
[   13.289416] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
[   13.298401] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[   14.427453] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[   14.514572] cfg80211: Regulatory domain changed to country: US
[   14.520439] cfg80211:  DFS Master region: FCC[   14.523339] u32 classifier
[   14.523340]     input device check on
[   14.523341]     Actions configured
[   14.534493] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   14.544288] cfg80211:   (2402000 KHz - 2467000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[   14.552321] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (N/A)
[   14.561832] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[   14.571342] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm), (0 s)
[   14.579450] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[   14.587480] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[   14.595878] Mirror/redirect action on
[   14.604690] netem: version 1.3
[   14.615218] fuse init (API version 7.23)
[   14.630818] usbcore: registered new interface driver cdc_wdm
[   14.639706] Ebtables v2.0 registered
[   14.644677] ip_tables: (C) 2000-2006 Netfilter Core Team
[   14.656689] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[   14.814161] Netfilter messages via NETLINK v0.30.
[   14.819737] PPP MPPE Compression module registered
[   14.825082] NET: Registered protocol family 24
[   14.833131] usbcore: registered new interface driver ums-alauda
[   14.839904] usbcore: registered new interface driver ums-cypress
[   14.846836] usbcore: registered new interface driver ums-datafab
[   14.853652] usbcore: registered new interface driver ums-freecom
[   14.860520] usbcore: registered new interface driver ums-isd200
[   14.867452] usbcore: registered new interface driver ums-jumpshot
[   14.874396] usbcore: registered new interface driver ums-karma
[   14.881427] usbcore: registered new interface driver ums-sddr09
[   14.888244] usbcore: registered new interface driver ums-sddr55
[   14.895190] usbcore: registered new interface driver ums-usbat
[   14.907119] usbcore: registered new interface driver usbserial
[   14.913011] usbcore: registered new interface driver usbserial_generic
[   14.919579] usbserial: USB Serial support registered for generic
[   14.930259] xt_time: kernel timezone is -0000
[   14.948469] usbcore: registered new interface driver cdc_ether
[   14.958743] ctnetlink v0.93: registering with nfnetlink.
[   14.967650] usbcore: registered new interface driver qmi_wwan
[   14.974557] usbcore: registered new interface driver rndis_host
[   14.990212] usbcore: registered new interface driver option
[   14.995856] usbserial: USB Serial support registered for GSM modem (1-port)
[   15.003476] usbcore: registered new interface driver qcserial
[   15.009267] usbserial: USB Serial support registered for Qualcomm USB modem
Router Turris successfully started.
It seems the card has some bits flipped in its eeprom. It gets detected as a mSATA device. This may cause it to not run at all on the PCengines boards which run coreboot. You atom board may ignore this info because it uses a proprietary bios which simply ignores this.
A option for both devices (Turris Omnia and PCengines APU2) would be to recompile the bootloader.
Have you tried using it in another Slot? Only the first slot has this kind of intelligence.
I’ve got a 120GB Kingston mSATA SSD in the slot nearest to the CPU; WLE200N2-23 is in the slot furthest from the CPU (the one that’s empty when Omnia was shipped).
Actually the mSATA / PCI detection is based on MSATAIND (physical) signal (pin 43) on the first PCIe connector. The bootloader reads the value (which is actually connected to the MCU and we have to read it indirectly over I2C). So the SATA indication might be caused either by bad wiring of the PCIe card that indicates mSATA by grounding the MSATAIND pin (we have seen PCIe cards with this pin grounded) or it is actually an mSATA SSD in the first PCIe connector. Which is most likely this case, according to the next ender’s message.
Anyway, if the card works in some PCIe slot in Turris Omnia and does not work in others, then there are two options: a) You might have badly soldered PCIe connector or b) there might me a problem in PCI initialization or mSATA/PCIe detection. It the card does not work in any PCIe slot, then it seems that it is simply incompatible with the PCIe root complex in Armada 385 SoC and there is not much what we can do now. Somebody could try to debug it, but it is probably going to take some time. And a PCIe protocol analyzer, the PCIe card schematic and a functional specification are most likely to be needed for such a job and I do not have neither of them.
Does someone know about any other high power cards with single band 2.4 Ghz b/g/n 2x2? I thought about getting a WLE200N2-23, too. Unfortunately the shipping costs etc. are quite high and now there are this compatibility issues.
Thank you.
Any news on compatibility with WLE200N2-23?
Another lurker waiting for some news.
