Collected errors:
- pkg_run_script: package “udpxy” postinst script returned status 255.
- opkg_configure: udpxy.postinst returned 255.
Co je to za chybu?
Při odstrěnění SW mám hlášky:
Command failed: Not found
WARNING: You probably just removed a package that was installed as part of a user list or the basic system. This package will return durring the next updater run. We suggest you disable the user list instead.
Mám Turris 1.0, Verze Turris: 3.6.2
