Collectd - rrdtools - NUT - graphs missing
  1. Have two UPS in NUT, but there is only settings for one UPS :frowning:
  2. There is only first graph in stats - with Voltages:
Don’t know, why there aren’t anymore graphs.
There are correct and exist data from NUT/UPS:
root@turris:~# upsc eaton650
battery.capacity: 9.00
battery.charge: 100
battery.charge.low: 20
battery.charge.restart: 0
battery.charger.status: resting
battery.energysave: no
battery.energysave.delay: 300
battery.energysave.load: 5
battery.protection: yes
battery.runtime: 954
battery.type: PbAc
battery.voltage: 13.1
battery.voltage.nominal: 12
device.mfr: EATON
device.model: 5P 650
device.serial: G114D51283
device.type: ups
driver.name: usbhid-ups
driver.parameter.pollfreq: 30
driver.parameter.pollinterval: 2
driver.parameter.port: auto
driver.parameter.synchronous: no
driver.parameter.vendorid: 0463
driver.version: 3.5.1-7-g608273f
driver.version.data: MGE HID 1.39
driver.version.internal: 0.41
input.current: 0.00
input.frequency: 49.9
input.frequency.extended: no
input.frequency.nominal: 50
input.sensitivity: normal
input.transfer.boost.low: 184
input.transfer.high: 294
input.transfer.low: 160
input.transfer.trim.high: 265
input.voltage: 234.6
input.voltage.extended: no
input.voltage.nominal: 230
outlet.1.autoswitch.charge.low: 0
outlet.1.delay.shutdown: 65535
outlet.1.delay.start: 3
outlet.1.desc: PowerShare Outlet 1
outlet.1.id: 1
outlet.1.status: on
outlet.1.switchable: yes
outlet.2.autoswitch.charge.low: 0
outlet.2.delay.shutdown: 65535
outlet.2.delay.start: 6
outlet.2.desc: PowerShare Outlet 2
outlet.2.id: 2
outlet.2.status: on
outlet.2.switchable: yes
outlet.desc: Main Outlet
outlet.id: 0
outlet.switchable: no
output.current: 0.60
output.frequency: 49.9
output.frequency.nominal: 50
output.powerfactor: 0.71
output.voltage: 234.3
output.voltage.nominal: 230
ups.beeper.status: enabled
ups.delay.shutdown: 20
ups.delay.start: 30
ups.efficiency: 88
ups.firmware: 02.10.0020
ups.load: 25
ups.load.high: 105
ups.mfr: EATON
ups.model: 5P 650
ups.power: 141
ups.power.nominal: 650
ups.productid: ffff
ups.realpower: 101
ups.realpower.nominal: 420
ups.serial: G114D51283
ups.shutdown: enabled
ups.start.auto: yes
ups.start.battery: yes
ups.start.reboot: yes
ups.status: OL
ups.test.interval: 2592000
ups.test.result: Done and passed
ups.timer.shutdown: -1
ups.timer.start: -1
ups.type: offline / line interactive
ups.vendorid: 0463
Why is in Turris version 4.10.8-3? There is 5.7.1 on Collectd website:
https://collectd.org/
There are data in rrd files! I tried for example:
rrdtool dump current-output.rrd >> aa.xml
and in file are:
			<!-- 2017-02-13 09:43:00 CET / 1486975380 --> <row><v> 6.0000000000e-01 </v></row>
			<!-- 2017-02-13 09:43:30 CET / 1486975410 --> <row><v> 6.0000000000e-01 </v></row>
			<!-- 2017-02-13 09:44:00 CET / 1486975440 --> <row><v> 6.0000000000e-01 </v></row>
			<!-- 2017-02-13 09:44:30 CET / 1486975470 --> <row><v> 6.0000000000e-01 </v></row>
			<!-- 2017-02-13 09:45:00 CET / 1486975500 --> <row><v> 6.0000000000e-01 </v></row>
Next:
rrdtool dump percent-load.rrd >> bb.xml
  	<!-- 2017-02-13 09:43:30 CET / 1486975410 --> <row><v> 2.4600000000e+01 </v></row>
  	<!-- 2017-02-13 09:44:00 CET / 1486975440 --> <row><v> 2.4400000000e+01 </v></row>
  	<!-- 2017-02-13 09:44:30 CET / 1486975470 --> <row><v> 2.5000000000e+01 </v></row>
  	<!-- 2017-02-13 09:45:00 CET / 1486975500 --> <row><v> 2.5000000000e+01 </v></row>
  	<!-- 2017-02-13 09:45:30 CET / 1486975530 --> <row><v> 2.5000000000e+01 </v></row>
As i am not using nut plugin, i am not so familiar with it, but there is a bit different lua script at master : https://github.com/openwrt/luci/blob/master/applications/luci-app-statistics/luasrc/statistics/rrdtool/definitions/nut.lua
You can also play with it a bit. Like try each graph-type individually return { voltages, currents, percentage, temperature, timeleft } . Now you know voltages are working…so pick next one comment the others (+alter that return line accordingly) and reload that stat-page, repeat for each one.
I installed Nut and Nut plugin for Collectd and I get no graph at all: rrd files contain only “Not A Number” (NaN) values.
This is very weird because if I enable CSV plugin, nut CSV files do contain correct values. (And I get graphs for all other plugins.)
So I guess the problem lies between nut and rrd but I don’t know where to look.
Any piece of advice?
Nut version is too old in Turris :frowning:
Collectd is too old… How do we get not so old versions?
