I’m going to retry the hbd build that I was having issues with Build error in uboot-tools using turris-build with hbd
I then decided to try to build hbs. I discovered that I was missing some dependencies on my host, namely gcc-multilib and possibly g+±multilb.
So I checked out v4.0 branch of turris-build and did
mkdir build
cd build
../compile_pkgs -t omnia -j1
This ran for a while and failed:
make[2] -C package/system/turris-version compile
make[2] -C package/utils/e2fsprogs host-compile
make[2] -C package/utils/e2fsprogs compile
make[2] -C package/utils/f2fs-tools compile
make[2] -C package/utils/usbutils compile
WARNING: Makefile 'package/feeds/turrispackages/foris-controller-data_collect-module/Makefile' has a dependency on 'ucollect-meta', which does not exist
WARNING: Makefile 'package/feeds/luci/luci-app-cshark/Makefile' has a dependency on 'cshark', which does not exist
WARNING: Makefile 'package/feeds/turrispackages/nfacct/Makefile' has a dependency on 'iptables-mod-nfacct', which does not exist
WARNING: Makefile 'package/feeds/packages/python-requests/Makefile' has a dependency on 'chardet', which does not exist
WARNING: Makefile 'package/feeds/packages/seafile-seahub/Makefile' has a dependency on 'simplejson', which does not exist
WARNING: Makefile 'package/feeds/packages/seafile-seahub/Makefile' has a dependency on 'chardet', which does not exist
WARNING: Makefile 'package/feeds/packages/seafile-seahub/Makefile' has a dependency on 'pytz', which does not exist
WARNING: Makefile 'package/feeds/turrispackages/suricata-monitor/Makefile' has a dependency on 'python-bottle', which does not exist
WARNING: Makefile 'package/feeds/turrispackages/turris-netboot/Makefile' has a dependency on 'uboot-mkimage', which does not exist
WARNING: Makefile 'package/feeds/turrispackages/turris-netboot/Makefile' has a build dependency on 'openssh-utils', which does not exist
WARNING: Makefile 'package/feeds/turrispackages/turris-netboot/Makefile' has a build dependency on 'openssh-client', which does not exist
WARNING: Makefile 'package/feeds/turrispackages/turris-translations/Makefile' has a build dependency on 'gettext-tools', which does not exist
WARNING: Makefile 'package/feeds/turrispackages/unbound/Makefile' has a dependency on 'unbound-control', which does not exist
WARNING: Makefile 'package/feeds/turrispackages/unbound/Makefile' has a build dependency on 'libexpat', which does not exist
make[1] package/index
make -r package/index: build failed. Please re-run make with -j1 V=s or V=sc for a higher verbosity level to see what's going on
/home/dhylands/turris-build/build/include/toplevel.mk:216: recipe for target 'package/index' failed
make: *** [package/index] Error 1
So I then ran:
make -j1 V=s
and it reported (snipped a bunch):
make[2]: Entering directory '/home/dhylands/turris-build/build'
rm -rf /home/dhylands/turris-build/build/staging_dir/packages/mvebu
mkdir -p /home/dhylands/turris-build/build/staging_dir/packages/mvebu
ln -s /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/*.ipk /home/dhylands/turris-build/build/staging_dir/packages/mvebu; ln -s /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/*.ipk /home/dhylands/turris-build/build/staging_dir/packages/mvebu; ln -s /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/luci/*.ipk /home/dhylands/turris-build/build/staging_dir/packages/mvebu; ln -s /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/*.ipk /home/dhylands/turris-build/build/staging_dir/packages/mvebu; ln -s /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/*.ipk /home/dhylands/turris-build/build/staging_dir/packages/mvebu;
find /home/dhylands/turris-build/build/staging_dir/target-arm_cortex-a9+vfpv3_musl_eabi/root-mvebu -type d | xargs -r chmod 0755
rm -rf /home/dhylands/turris-build/build/build_dir/target-arm_cortex-a9+vfpv3_musl_eabi/root-mvebu /home/dhylands/turris-build/build/build_dir/target-arm_cortex-a9+vfpv3_musl_eabi/root.orig-mvebu
mkdir -p /home/dhylands/turris-build/build/build_dir/target-arm_cortex-a9+vfpv3_musl_eabi/root-mvebu/tmp
IPKG_NO_SCRIPT=1 IPKG_INSTROOT=/home/dhylands/turris-build/build/build_dir/target-arm_cortex-a9+vfpv3_musl_eabi/root-mvebu TMPDIR=/home/dhylands/turris-build/build/build_dir/target-arm_cortex-a9+vfpv3_musl_eabi/root-mvebu/tmp /home/dhylands/turris-build/build/staging_dir/host/bin/opkg --offline-root /home/dhylands/turris-build/build/build_dir/target-arm_cortex-a9+vfpv3_musl_eabi/root-mvebu --force-postinstall --add-dest root:/ --add-arch all:100 --add-arch arm_cortex-a9_vfpv3:200 install \
/home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/base-files_194.2-19e29fc204_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/uboot-envtools_2018.03-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-gpio-button-hotplug_4.14.109-2-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kernel_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-scsi-core_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-crypto-acompress_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-crypto-crc32c_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-crypto-hash_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-fs-btrfs_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-fs-ext4_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-fs-vfat_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-fuse_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-i2c-core_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-hid_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-hid-generic_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-input-core_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-input-evdev_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-ledtrig-heartbeat_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-lib-crc-ccitt_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-lib-crc16_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-lib-crc32c_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-lib-lzo_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-lib-zstd_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-lib-raid6_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-lib-xor_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-lib-zlib-inflate_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-lib-zlib-deflate_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-nf-reject_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-nf-reject6_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-nf-ipt_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-nf-ipt6_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-ipt-core_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-nf-conntrack_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-nf-conntrack6_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-nf-nat_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-nf-flow_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-ipt-conntrack_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-ipt-offload_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-ipt-ipset_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-ipt-nat_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-ip6tables_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-nfnetlink_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-nf-conntrack-netlink_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-udptunnel4_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-udptunnel6_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-vxlan_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-iptunnel_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-veth_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-slhc_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-ppp_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-pppox_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-pppoe_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-nls-base_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-nls-cp437_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-nls-iso8859-1_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-nls-utf8_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-sound-core_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-usb-core_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-usb-uhci_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-usb-ohci_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-usb-ehci_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-usb2_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-usb-storage_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-usb-hid_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-usb3_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-ath_4.14.109+2017-11-01-10-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-ath10k_4.14.109+2017-11-01-10-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-ath9k_4.14.109+2017-11-01-10-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-ath9k-common_4.14.109+2017-11-01-10-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-cfg80211_4.14.109+2017-11-01-10-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/kmod-mac80211_4.14.109+2017-11-01-10-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/libc_1.1.19-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/libgcc_7.3.0-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/libatomic_7.3.0-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/libstdcpp_7.3.0-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/libpthread_1.1.19-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/librt_1.1.19-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/iptables_1.6.2-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/ip6tables_1.6.2-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/libip4tc_1.6.2-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/libip6tc_1.6.2-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/libxtables_1.6.2-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/libiwinfo_2018-07-31-65b8333f-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/libiwinfo-lua_2018-07-31-65b8333f-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/iwinfo_2018-07-31-65b8333f-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/fstools_2018-12-28-af93f4b8-3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/fwtool_1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/mtd_23_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/targets/mvebu/cortexa9/packages/ubi-utils_2.0.2-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/strace_4.22-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/ath10k-firmware-qca988x_2018-05-12-952afa49-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/wireless-regdb_2017-10-20-4343d359_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libelf1_0.169-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libintl-full_0.19.8.1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/gettext-tools_0.19.8.1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libgmp_6.1.2-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libevent2_2.0.22-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libiconv-full_1.11.1-3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libjson-c_0.12.1-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libmnl_1.0.4-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libnetfilter-conntrack_2017-07-25-e8704326-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libnfnetlink_1.0.1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libnl-tiny_0.1-5_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libubox_2018-07-25-c83a84af-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libblobmsg-json_2018-07-25-c83a84af-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/jshn_2018-07-25-c83a84af-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libjson-script_2018-07-25-c83a84af-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libusb-1.0_1.0.22-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/liblzo_2.10-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/terminfo_6.1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libncurses_6.1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libnettle_3.4-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libopenssl_1.0.2q-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/openssl-util_1.0.2q-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libpopt_1.16-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libsysfs_2.1.0-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/sysfsutils_2.1.0-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libuclient_2018-11-24-3ba74ebc-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/uclient-fetch_2018-11-24-3ba74ebc-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/zlib_1.2.11-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/firewall_2018-08-13-1c4d5bcd-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/netifd_2019-01-31-a2aba5c7-2.1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/odhcp6c_2018-07-14-67ae6a71-15_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/dnsmasq-full_2.80-1.5_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/wpad_2018-05-21-62566bc2-5_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/hostapd-common_2018-05-21-62566bc2-5_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/odhcpd-ipv6only_1.15-3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/ppp_2.4.7-12_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/ppp-mod-pppoe_2.4.7-12_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/umdns_2018-01-02-78974417-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/curl_7.60.0-3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libcurl_7.60.0-3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/ethtool_4.19-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/ip-full_4.16.0-8_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/iputils-ping_20101006-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/iw-full_4.14-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/ca-certificates_20190110-1_all.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/ca-bundle_20190110-1_all.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/openwrt-keyring_2018-05-18-103a32e9-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/opkg_2019-01-18-7708a01a-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/procd_2018-03-28-dfb68f85-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/rpcd_2018-11-28-3aa81d0d-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/turris-version_4.0-alpha5_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/ubox_2018-02-14-128bc35f-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/logd_2018-02-14-128bc35f-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libubus_2018-10-06-221ce7e7-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libubus-lua_2018-10-06-221ce7e7-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/ubus_2018-10-06-221ce7e7-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/ubusd_2018-10-06-221ce7e7-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/uci_2018-08-11-4c8b4d6e-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libuci_2018-08-11-4c8b4d6e-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libuci-lua_2018-08-11-4c8b4d6e-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/usign_2015-07-04-ef641914-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/busybox_1.28.4-3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libbz2_1.0.6-4_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/bzip2_1.0.6-4_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/e2fsprogs_1.44.1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libcomerr_1.44.1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libss_1.44.1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libext2fs_1.44.1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libf2fs_1.10.0-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/mkf2fs_1.10.0-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/jsonfilter_2018-02-04-c7e938d6-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/liblua_5.1.5-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/lua_5.1.5-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/usbutils_007-9_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libblkid_2.32-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/base/libuuid_2.32-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/luci/luci_git-19.092.04480-9b6bc1d-1_all.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/luci/luci-app-firewall_git-19.092.04480-9b6bc1d-1_all.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/luci/luci-base_git-19.092.04480-9b6bc1d-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/luci/luci-lib-ip_git-19.092.04480-9b6bc1d-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/luci/luci-lib-json_git-19.092.04480-9b6bc1d-1_all.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/luci/luci-lib-jsonc_git-19.092.04480-9b6bc1d-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/luci/luci-lib-nixio_git-19.092.04480-9b6bc1d-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/luci/luci-mod-admin-full_git-19.092.04480-9b6bc1d-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/luci/luci-mod-rpc_git-19.092.04480-9b6bc1d-1_all.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/luci/luci-proto-ipv6_git-19.092.04480-9b6bc1d-1_all.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/luci/luci-proto-ppp_git-19.092.04480-9b6bc1d-1_all.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/luci/luci-theme-bootstrap_git-19.092.04480-9b6bc1d-1_all.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/luci/liblucihttp_2018-05-18-cb119ded-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/luci/liblucihttp-lua_2018-05-18-cb119ded-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/luci/rpcd-mod-rrdns_20170710_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/at_3.1.20-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/libattr_20170915-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/btrfs-progs_4.15.1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/glib2_2.58.1-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/libgnutls_3.5.19-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/haveged_1.9.4-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/libhavege_1.9.4-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/i2c-tools_3.1.2-3.6-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/libkmod_20-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/libldns_1.6.17-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/libcap_2.25-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/libdbi_0.9.0-4_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/libedit_20170329-3.1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/libffi_3.2.1-3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/libuv_1.19.2-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/lm-sensors_3.3.5-4_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/libsensors_3.3.5-4_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/logrotate_3.10.0-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/luajit_2017-01-17-71ff7ef-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/luasec_0.6-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/luasocket_3.0-rc1-20130909-4_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/msmtp_1.6.6-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/ntpdate_4.2.8p11-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-client_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-moduli_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-client-utils_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-keygen_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-server_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-sftp-client_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-sftp-server_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-client_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-moduli_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-client-utils_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-keygen_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-server_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-sftp-client_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-sftp-server_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-client_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-moduli_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-client-utils_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-keygen_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-server_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-sftp-client_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-sftp-server_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-client_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-moduli_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-client-utils_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-keygen_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-server_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-sftp-client_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-sftp-server_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-client_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-moduli_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-client-utils_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-keygen_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-server_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-sftp-client_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-sftp-server_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-client_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-moduli_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-client-utils_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-keygen_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-server_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-sftp-client_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-sftp-server_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-client_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-moduli_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-client-utils_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-keygen_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-server_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-sftp-client_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/openssh-sftp-server_7.7p1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/pciutils_3.5.6-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/libpcre_8.41-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/python-multiprocessing_2.7.15-3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/python-logging_2.7.15-3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/python-base_2.7.15-3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/python-light_2.7.15-3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/python3-base_3.6.7-3.6-3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/python3-light_3.6.7-3.6-3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/syslog-ng_3.20.1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/tar_1.30-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/wget_1.19.5-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/xz-utils_5.2.4-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/liblzma_5.2.4-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/packages/xz_5.2.4-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/c-rehash_1.7-3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/cert-backup_12_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/cznic-cacert-bundle_37_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/cznic-repo-keys_4.1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/cznic-repo-keys-test_4.1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/dnssec-rootkey_0.0.2-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/knot-libs_2.7.6-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/knot-libzscanner_2.7.6-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/knot-dig_2.7.6-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/knot-resolver_3.2.1-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/l10n_supported_1.3-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/libatsha204_29.2-3.6-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/lighttpd_1.4.50-5_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/lighttpd-mod-redirect_1.4.50-5_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/lighttpd-mod-alias_1.4.50-5_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/lighttpd-mod-cgi_1.4.50-5_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/lighttpd-mod-openssl_1.4.50-5_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/lighttpd-mod-fastcgi_1.4.50-5_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/lighttpd-mod-proxy_1.4.50-5_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/lighttpd-mod-setenv_1.4.50-5_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/lighttpd-https-cert_5_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/localrepo_0.1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/luci-lighttpd_1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/nethist_14_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/omnia-support_4.14.109-1-aadfab6a911661536f00a00bf11d3539_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/oneshot_0_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/pkglists_1.0.3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/python3-uci_0.4.2-3.6-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/resolver-conf_0.0.1-29_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/schnapps_1.7-3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/server-uplink_5_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/socat_1.7.3.2-4_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/start-indicator_0_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/switch-branch_2.1.5-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/thermometer_3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/turris-utils_1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/turris-webapps_1-5_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/libunbound_1.9.1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/update_mac_2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/updater-ng_62.1-3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/updater-opkg-wrapper_0.1-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/updater-supervisor_1.0.1-3.6-1_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/create_notification_59-2_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/userspace_time_sync_4_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/vixie-cron_7-3_arm_cortex-a9_vfpv3.ipk /home/dhylands/turris-build/build/bin/packages/arm_cortex-a9_vfpv3/turrispackages/watchdog_adjust_6_arm_cortex-a9_vfpv3.ipk
Installing base-files (194.2-19e29fc204) to root...
Installing libgcc (7.3.0-1) to root...
Installing libc (1.1.19-1) to root...
Installing libubox (2018-07-25-c83a84af-2) to root...
Installing libuci (2018-08-11-4c8b4d6e-1) to root...
Installing libnl-tiny (0.1-5) to root...
....snip....
Installing openssh-server (7.7p1-1) to root...
Installing openssh-sftp-client (7.7p1-1) to root...
Installing openssh-sftp-server (7.7p1-1) to root...
Package openssh-client (7.7p1-1) installed in root is up to date.
Package openssh-moduli (7.7p1-1) installed in root is up to date.
Package openssh-client-utils (7.7p1-1) installed in root is up to date.
....snip....
Configuring kmod-ath9k-common.
Configuring updater-opkg-wrapper.
Configuring ppp-mod-pppoe.
Configuring dnsmasq-full.
Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for kmod-gpio-button-hotplug:
* kernel (= 4.14.109-1-aadfab6a911661536f00a00bf11d3539.0)
* opkg_install_cmd: Cannot install package kmod-gpio-button-hotplug.
* satisfy_dependencies_for: Cannot satisfy the following dependencies for kmod-scsi-core:
* opkg_install_cmd: Cannot install package kmod-scsi-core.
* satisfy_dependencies_for: Cannot satisfy the following dependencies for kmod-crypto-acompress:
....snip....
* opkg_install_cmd: Cannot install package kmod-usb3.
* satisfy_dependencies_for: Cannot satisfy the following dependencies for kmod-ath:
* opkg_install_cmd: Cannot install package kmod-ath.
* satisfy_dependencies_for: Cannot satisfy the following dependencies for kmod-ath10k:
* opkg_install_cmd: Cannot install package kmod-ath10k.
* satisfy_dependencies_for: Cannot satisfy the following dependencies for kmod-ath9k:
* opkg_install_cmd: Cannot install package kmod-ath9k.
package/Makefile:65: recipe for target 'package/install' failed
make[2]: *** [package/install] Error 255
make[2]: Leaving directory '/home/dhylands/turris-build/build'
package/Makefile:104: recipe for target '/home/dhylands/turris-build/build/staging_dir/target-arm_cortex-a9+vfpv3_musl_eabi/stamp/.package_install' failed
make[1]: *** [/home/dhylands/turris-build/build/staging_dir/target-arm_cortex-a9+vfpv3_musl_eabi/stamp/.package_install] Error 2
make[1]: Leaving directory '/home/dhylands/turris-build/build'
/home/dhylands/turris-build/build/include/toplevel.mk:216: recipe for target 'world' failed
make: *** [world] Error 2
