Well if all the video-files are just supported by the client/player by default…no transcoding is needed, however i doubt anybody will change their video files each time to a supported codec
IF there are such guys, then the Omnia is more then well suited for it, but i guess you will also agree with me on that. If else, then we indeed are arguing the same sentiment
What i forgot to mention. If the ARM processor had a GPU then I COULD be well suited, but i did not find anything pointing at that.
Plex is available for slower NAS devices with older ARM architectures.
Transcoding is disabled for such architectures.
Turris Omnia is probably more powerful.
Plex is also available on the new Netgear R9000 router ( quad core ARM at 1.7GHz) with trans-coding.
Everyone has different needs.
And there are multiple options out there.
Hey, I just wanted to say thanks to everyone who’s trying to help me out, it’s very much appreciated.
This week-end I’m going to try to find a shoe that fits my foot (so to speak).
I configured the container in LuCI > LXC Containers: I added what you wrote at the end of the file.
So that would be:
# Template used to create this container: /usr/share/lxc/templates/lxc-download
# Parameters passed to the template: --server api.turris.cz/lxc --no-validate --dist Debian --release Jessie --arch armv7l
# For additional config options, please look at lxc.container.conf(5)
# Distribution configuration
lxc.arch = armv7l
# Container specific configuration
lxc.tty = 4
lxc.pts = 1024
lxc.rootfs = /srv/lxc/OpenMediaVault/rootfs
lxc.utsname = OpenMediaVault
# Network configuration
lxc.network.type = veth
lxc.network.link = br-lan
lxc.network.flags = up
lxc.network.name = eth0
# Block configuration
lxc.cgroup.devices.allow = b 8:0 rwm # sda
lxc.cgroup.devices.allow = b 8:1 rwm # sda1
# Passthrough Printer and USB devices
lxc.mount.entry=/dev/bus/usb dev/bus/usb none bind,optional,create=dir 0 0
lxc.cgroup.devices.allow = c 180:* r
lxc.mount.entry=/dev/usb dev/usb none bind,optional,create=dir 0 0
lxc.cgroup.devices.allow = c 189:* rw
In the terminal I edited the /etc/rc.local file with what you wrote
question: do I have to keep the line ‘exit 0’?
So that would be:
# Put your custom commands here that should be executed once
# the system init finished. By default this file does nothing.
# Code for OpenMediaVault
mknod /dev/sda b 8 0
mknod /dev/sda1 b 8 1
mknod /dev/sda2 b 8 2
mknod /dev/sda3 b 8 3
mknod /dev/sda4 b 8 4
mknod /dev/sdb b 8 16
mknod /dev/sdb1 b 8 17
mknod /dev/sdb2 b 8 18
mknod /dev/sdb3 b 8 19
mknod /dev/sdb4 b 8 20
echo /sys/block/sd? /sys/block/sd?/sd?? | xargs -r -n1 udevadm test
fsck -A
mount -a
# Do I need that line?
exit 0
I don’t know what to do with LXC /etc/apt/sources.list.d/openmediavault.list
question: do I have to create those directories and file (and put the content you wrote in it) or do I have to install a package?
I managed to get in now but it seems there’s no file editing tool installed so I can’t edit /etc/rc.local or create /etc/apt/sources.list.d/openmediavault.list
I tried ‘apt-get install nano’ and ‘apt-get install vim’ but it looks like there’s no connection allowed. Am I missing something in the configuration of the new container?
All newly created containers will have one virtual network card that will be connected to your LAN bridge by default, so it will be just another (this time virtual) computer on your local network and you can treat it as such in regards to IP assignment, port forwarding or firewall setup on your router.
EDIT: I managed to do it without installing anything but using the following commands:
cat > name-of-the-file-you-want-to-edit to add content to a file
touch name-of-the-file-you-want-to-create to create a new empty file
Alright… I won’t give up
As mentioned, I’m unable to run the last command:
apt-get update && apt-get install openmediavault
Reading other posts, I see that @cr0 actually managed to install a Plex Media Server inside a container. Then @radekpribyl said something about using port mapping to redirect port 8022 to port 22 in the LXC container. Could this be my problem?
This is what I’m getting from the Terminal:
root@LXC_NAME:~# apt-get update && apt-get install openmediavault
Err http://packages.openmediavault.org erasmus InRelease
Err http://security.debian.org jessie/updates InRelease
Err http://packages.openmediavault.org erasmus Release.gpg
Temporary failure resolving 'packages.openmediavault.org'
Err http://security.debian.org jessie/updates Release.gpg
Temporary failure resolving 'security.debian.org'
Err http://httpredir.debian.org jessie InRelease
Err http://httpredir.debian.org jessie Release.gpg
Temporary failure resolving 'httpredir.debian.org'
Reading package lists... Done
W: Failed to fetch http://httpredir.debian.org/debian/dists/jessie/InRelease
W: Failed to fetch http://security.debian.org/dists/jessie/updates/InRelease
W: Failed to fetch http://packages.openmediavault.org/public/dists/erasmus/InRelease
W: Failed to fetch http://packages.openmediavault.org/public/dists/erasmus/Release.gpg Temporary failure resolving 'packages.openmediavault.org'
W: Failed to fetch http://security.debian.org/dists/jessie/updates/Release.gpg Temporary failure resolving 'security.debian.org'
W: Failed to fetch http://httpredir.debian.org/debian/dists/jessie/Release.gpg Temporary failure resolving 'httpredir.debian.org'
W: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree
Reading state information... Done
E: Unable to locate package openmediavault
Which errors? If it’s dpkg errors is related to a different package then, if it’s the same package as before i must be a different error… dpkg is used only for installation and other operations on packages. It should not affect correctly installed packages… Please provide the errors and other relevant info.
