Hi all,
I have a omnia 2020 from few days. i have configured the router and during two day is running fine.
But during one days is seem to be not working and reboot it without effect.
I connect my laptop to the serial cable and i can see the following message in loop
BootROM - 1.73
Booting from SPI flash
BootROM: Bad header at offset D4000000
BootROM: Bad header at offset D4200000
so i decided to recover from seria
following this documentation https://docs.turris.cz/hw/omnia/serial-boot/
i use the following file for booting u-boot
u-boot-omnia_2020-09-07-6dd804d7-1_arm_cortex-a9_vfpv3-d16.ipk
but a the end of kwboot command i get Protocol Error :
kwboot -t -b uboot-devel -B 115200 /dev/ttyUSB0
Sending boot message. Please reboot the target…
Sending boot image…
0 % […]
1 % […]
2 % […]
3 % […]
4 % […]
5 % […]
6 % […]
8 % […]
9 % […]
10 % […]
11 % […]
12 % […]
13 % […]
14 % […]
15 % […]
17 % […]
18 % […
U-Boot SPL 2015.10-rc2 (Feb 18 2021 - 06:30:42)
High speed PHY - Version: 2.0
SERDES0 card detect: PEX
Initialize Turris board topology
Detected Device ID 6820
board SerDes lanes topology details:
| Lane # | Speed | Type |
| 0 | 5 | PCIe0 |
| 1 | 5 | USB3 HOST0 |
| 2 | 5 | PCIe1 |
| 3 | 5 | USB3 HOST1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
poll_op_execute: TIMEOUT
:** Link is Gen1, check the EP capability
PCIe, Idx 0: remains Gen1
PCIe, Idx 1: remains Gen1
PCIe, Idx 2: detected no link
DDR3 Training Sequence - Ver TIP-1.29.0
Memory config in EEPROM: 0x02
fDDR3 Training Sequence - Switching XBAR Window to FastPath Window
DDR3 Training Sequence - Ended Successfully
U-Boot 2019.07 (Sep 25 2019 - 14:41:57 +0000), Build: jenkins-turris-os-packages-kittens-omnia-876
SoC: MV88F6820-A0 at 1600 MHz
DRAM: 2 GiB (800 MHz, 32-bit, 2T, ECC not enabled)
Disabling MCU watchdog… disabled
WDT: Started with servicing (60s timeout)
MMC: mv_sdh: 0
Loading Environment from SPI Flash… SF: Detected mx25l6405d with page size 256 Bytes, erase size 4 KiB, total 8 MiB
OK
Model: Turris Omnia
Turris Omnia:
RAM size: 2048 MiB
Serial Number: 0000000E000033C6
fRegdomain set to **
Net: eth0: ethernet@70000, eth1: ethernet@30000, eth2: ethernet@34000
Hit any key to stop autoboot: 3 +xmodem: Protocol error
For information i have UART USB TTL cable.
I have check all other topic but i’m not able to fix my issue.
