TOS 3.10
Below MTU setting for LAN appears not being appplied
config interface 'lan'
option ifname 'eth0 eth2'
option force_link '1'
option type 'bridge'
option proto 'static'
option ipv6 '0'
option delegate '0'
option stp '1'
option mtu '9000'
output from ip link show
br-lan/eth0/eth2 is all the same:
mtu 1500
the mtu for an empty (unbonded) bridge can not exceed 1500 howver the bidge automatically inherits the smallest MTU integer of its enslaved devices. Hence setting the MTU of the devices to be enslaved will adjust the bridge’s MTU (9000 for jumbo frames) once bonded.
Without enslaving the wifi cards into br-lan
it is feasible to raise the mtu
Summary
option mtu '9000'
config interface 'eth0'
option mtu '9000'
option ifname 'eth0'
option proto 'none'
config interface 'eth2'
option mtu '9000'
option ifname 'eth2'
option proto 'none'
Changing the wlan mtu appears to be prevented by a bug however Tos 3.10.3 - wifi mtu settings neglected
